Buying Used 05 Landcruiser Sahara
Submitted: Monday, Nov 09, 2009 at 13:19
Damo never buy a pat
Could anyone give me an insight into what pitfalls there could be when purchasing a one owner second hand 05 V8 auto Landcruiser Sahara with 159k's.
Would appreciate any feedback
Thankyou
Reply By: ajd - Monday, Nov 09, 2009 at 15:29
If it's yellow it could be a lemon!!
390609
Follow Up By: Damo never buy a pat - Monday, Nov 09, 2009 at 22:41
Thanks' ajd
658460
Reply By: Member - Shane D (QLD) - Monday, Nov 09, 2009 at 17:33
Earlier IFS models where prone to cracking around a major
suspension component and may of been subject to recal , I think the fault was rectified by '05 but it something you may wish to follow up on.
There where a number of other recall also applicable to 100series, such as brake caliper bolts, and wiring loom under the dash board.
I have an late '05 (upgraded model) but has live axle and has had both recal's done but I'm a bit
grey on IFS models (that one will be 'cos it's a V8).
Shane
390627
Follow Up By: Damo never buy a pat - Monday, Nov 09, 2009 at 22:43
Thanks' for the info Shane will check it all out
658462
Follow Up By: Member - Graham H (QLD) - Tuesday, Nov 10, 2009 at 00:17
People harp on about the front control arm problem.
This occured about 2002 and was limited to certain vin numbers when a Robot welder had a hissy fit for a short time.
2005 models including yours and
mine are fine.
There should be two recall stickers on the pillar when u open drivers door.
One is for the wiring loom above the brake pedal and one is for front rotor bolts.
If the car has had Toyota
services they should have been done at that time.
Only prob you will have is keeping hand in pocket for
fuel if towing.
LOL Go the diesels
658479
Follow Up By: Who was that again? (Vic) - Tuesday, Nov 10, 2009 at 07:37
Damo, the Update 100 Series is supposed to be from September 05, but I guess there can always be a hangover from that date, with some cars sold afterwards. I agree with Graham on the diesel/petrol issue. Ready to pull your wallet out often.
658498
Follow Up By: Member - Graham H (QLD) - Tuesday, Nov 10, 2009 at 11:22
Check which version of maps are in the navigator The newest version 15 I think is over $400 from Toyotasan.
The update model didnt alter much LED Tail lights was the most obvious one.
If towing its advisable to fit Polyairs to counteract the self levelling
suspension
Have heard of injectors playing up a bit.
Have a look on Lcool which you have to join to read.
658527
Reply By: Member - Axle - Monday, Nov 09, 2009 at 20:17
Piston slap, and bottom end problems have occured with some, listen to it very carefully on cold start up whilst idling,then check oil pressure on idle after a good run.
Cheers Axle.
390654
Follow Up By: Damo never buy a pat - Monday, Nov 09, 2009 at 22:44
Thanks' Axle, will do as you have said.
Damo
658464
Reply By: TerraFirma - Monday, Nov 09, 2009 at 21:29
My wifes 1998 Model GXV V8 has done 290,000kms and still drives beautifully, although she has a 200 series now. The engines are brilliant. I doubt a Sahara has been used heavily off road so if you get the vehicle checked before purchase you will have yourself a nice car. With the GXV we had to replace the ECU which was $2k apart from that nothing ever went wrong apart from globes here and there. They are very
well made and very reliable.
390673
Follow Up By: Damo never buy a pat - Monday, Nov 09, 2009 at 22:46
That was some good klm's for a car that still drives beautifully. I bet the 200 series is nice.
Thanks; for the info
Damo
658465
