Poly air bag pressures?
Gidday
I have a Prado with quite a bit of gear added to it. Occasionally I also tow a camper van, which weighs approx 1.3t loaded.
I’d be interested to hear what pressures others are using.
Kim
Reply By: George_M - Monday, Nov 09, 2009 at 14:58
Hi Kim
I use 8psi around town and unloaded.
On a long trip with a full load in the back and on top (no trailer - yet) I've used up to 17psi to keep everything level. The vehicle would be pretty close to gvm in this configuration.
On one trip I went as high as 25psi - I had a slow leak, and this pressure was sufficient to get me through the day. Probably not ideal for any period of time.
George
Come any closer and I'll rip your throat out!
AnswerID: 390604
Reply By: Member - Troll 81 (QLD) - Monday, Nov 09, 2009 at 15:05
Just read on their website the max should be 30psi. I used to run about 25psi when I was loaded up.
Don't use them anymore since I have a leak in both
AnswerID: 390605
Reply By: DesF - Monday, Nov 09, 2009 at 15:12
Hi , I have them in the Pajero NF rear coils, and I run about 15lb when loaded for a desert run, tents, fridge, genny etc etc, and I find 18lb sufficient for the loaded van ( Jayco Eagle) with the load leveling bars on,
I just run them at 5lb empty, have had them 9 years now and no probs.
Cheers Des,
AnswerID: 390606
Reply By: jeep cherokee - Monday, Nov 09, 2009 at 15:17
I used to have the black Poly Air bags on the rear of my Jeep and ran them at 40 psi to keep the caravan level. Min pressure specified was 10 psi to prevent the bags from pinching when deflated and max was 100psi. Trial and error really.
AnswerID: 390607
Reply By: Member - Uncle (NSW) - Monday, Nov 09, 2009 at 16:28
Hiya Kim
on the trip last year with the camper on 20 psi. Found it was a good all round pressure, but round town 8 to 10 psi.
cheers mate unc
AnswerID: 390615
Follow Up By: Kim and Damn Dog - Monday, Nov 09, 2009 at 19:16
Gidday Unc
That's pretty much what I was thinking.
Kim
FollowupID: 658404
Follow Up By: Member - Uncle (NSW) - Monday, Nov 09, 2009 at 20:01
Kim, we found that sometimes when driving into Port Hedland from the station, in the Patrol, we still had the 20 psi in the polys. With the weight of the patrol, it still didn't seem to skatey in the R-send on the gravel, if ya know what I mean.
cheers Unc
FollowupID: 658416
Reply By: cobber - Monday, Nov 09, 2009 at 18:09
Hi Kim, I run mine at 20psi when towing the (Van 2000kg) and a load in the back of the Landcruiser100 series............have just returned from a 17,000kms to Queensland and back to WA, no problems...............at home with out all the gear in the Cruiser run them at 10psi............i have had them for 4 years now and very happy with them
AnswerID: 390633
Reply By: Members Paul and Melissa (VIC) - Monday, Nov 09, 2009 at 20:54
Me 3, bout 8 PSI around town and 20-25 when loaded to the hilt.
AnswerID: 390664
Reply By: Mark Howlett - Monday, Nov 09, 2009 at 22:22
Hi Kim,
We have a 98 Prado and towed a Trak Shak camper for 6 months last year with our 2 kids. I already had medium duty Old Man Emu coils but with drawers in the back with tools, recovery gear, fridge, food etc AND towing the fully loaded trailer we needed some help. The Polyairs fixed that, I ran them at their max of 30psi and had no dramas. Around town know I use 5 to 10 psi.
Mark.
AnswerID: 390682
Reply By: Member - Robert G (WA) - Wednesday, Nov 11, 2009 at 10:06
In my LC100 I run 6psi most times and 15-25psi when loaded and/or towing. I try and follow the manufacturers guidelines when possible and pump em up to 30psi before I load up, then deflate them till I am level again after loading, But I do forget sometimes and it doesn't seem to matter if you pump em up after.
I use a small bike pump cause they don't take much air and would be easy to overinflate with a compressor (mine polyairs have a max 30psi rating).
AnswerID: 390845
