2 way fridge problem
Submitted: Monday, Nov 09, 2009 at 14:57
Member - Julie P (VIC)
G'day - we have had our Bushman 2 way fridge for about 5 years - never let us down until recently - it ran the battery down and we couln't understand why, as we were putting power back in continuously from the solar panels, and had heaps of sun power. Anyway what we have discovered is that it running on all the time - not going back to its usual "sit"mode - as we are travelling this is a bit of a dilemma - we have been using it as a freezer. We feel it is the thermostat, and are taking it to a recommended repairer tomorrow - we only twigged to the problem when we were camped in a national
park, extremely quiet, and we could hear it just running on. Luckily we didn't lose any food, still had the little freezer in the van as back up. Anyone else had this happen?
jules
Reply By: you eat the bear - Monday, Nov 09, 2009 at 17:55
Hi, Jules
I've got a Bushman of about the same vintage and (touch wood) no issues so far.
It does use a pair of AA batteries to control the thermostat. This is completely separate to the power required to run the fridge.
This may be a dumb question but have you checked/changed these?
Steve
390632
Follow Up By: Member - Julie P (VIC) - Monday, Nov 09, 2009 at 20:20
Thanks for that Steve - whereabouts are these batteries on the fridge?
Jules
658419
Follow Up By: kcandco - Monday, Nov 09, 2009 at 20:53
Hi Jules
The batteries are located right next to the lcd temperature display. I find
mine only last a year or so (alkaline). The lid to the batteries is similar to that found on tv remotes etc.
regards Kc
658427
Follow Up By: kcandco - Monday, Nov 09, 2009 at 20:56
Hi Julie
Do you check the set temperature every time you turn the bushman on. I sometimes find
mine has reset itself to -18 so always check it every time I turn the fridge on. Im not sure if that is because the batteries are getting low.
regards Kc
658428
Follow Up By: Member - Julie P (VIC) - Monday, Nov 09, 2009 at 20:58
Thanks for help - have checked (put new batteries in and checked it) no different - so looks like it is the repairer tomorrow (220k round trip!!)
Kalbar to
Burleigh Heads - hope the rain stops. It has been belting down here in
Kalbar - we are staying at the
show grounds with a
lake view - truck got bogged here this morning - funny thing - belonged to Queensland Transport Dept - needed tractor to drag it out ha - ha!!
658429
Follow Up By: Member - Vince B (NSW) - Tuesday, Nov 10, 2009 at 15:37
Hi Julie.
Good luck with the
Burleigh Heads repairer. My mate's fridge is still under warranty & it is going back for the third time,
Cheers.
Vince
658571
Follow Up By: kcandco - Tuesday, Nov 10, 2009 at 17:35
Hi Julie
When you find out the fault please post again... it may help one of us in the future.
regards Kc
658591
