2006 Nissan Patrol Problem
Submitted: Monday, Nov 09, 2009 at 16:35
ThreadID: 73639 Views:23735 Replies:22 FollowUps:29
Hoping someone could maybe help me out?
Has anyone had any problems with the new Nissan Patrol St Guiv?
My Nissan has just died, the turbo, inter cooler and engine has just blown up. I have looked after this vehicle and it was in great condition for the amount of Kms it has on it. But I'm just wondering if anyone else has had any issues. I have put 246 500 km's on this vehicle in 3.5 years with no problems till now.....
Any comments would be great. Cheers
Reply By: Member - Angus E (NSW) - Monday, Nov 09, 2009 at 16:43
Which motor is in it?
AnswerID: 390617
Follow Up By: Michael ( Moss Vale NSW) - Monday, Nov 09, 2009 at 20:19
Whadya reckon??? Michael
FollowupID: 658418
Reply By: Woolbroker - Monday, Nov 09, 2009 at 16:51
The Nissan Patrol Wagon has the 3 ltr - 4 cyl.
AnswerID: 390618
Follow Up By: Time - Monday, Nov 09, 2009 at 21:20
Commonly known as
FollowupID: 658436
Follow Up By: Geoff (Newcastle, NSW) - Monday, Nov 09, 2009 at 22:02
They have their own,
Geoff,
FollowupID: 658452
Reply By: putrol - Monday, Nov 09, 2009 at 16:53
if its a 3.0ltr it was just a matter of time
but if its a 4.2 ltr very strange as they are pretty bullet proof
sorry but you did ask for any comments
AnswerID: 390619
Follow Up By: Woolbroker - Monday, Nov 09, 2009 at 16:59
What do you think is the main problem with the 3.0 ltr motor as there are plenty of these Patrols on the road in QLD...
FollowupID: 658393
Reply By: ajd - Monday, Nov 09, 2009 at 17:00
What do you mean by blown up?
AnswerID: 390622
Reply By: Woolbroker - Monday, Nov 09, 2009 at 17:06
The damage to the vechile is requireing a new turbo and inter cooler and motor as the No. 3 cyl has no compression, the turbo has blown out the bearings and the inter cooler has a hole blown through it....
AnswerID: 390624
Reply By: Member -Dodger - Monday, Nov 09, 2009 at 17:09
For a 3 ltr Patrol you did very well getting that sort of k's out of it without a problem and in 3.5 years you certainly like to drive.
The three ltr is known as the grenade just go over to the Patrol forum and ask this question then see how many answers you get.
Just re-engine the thing.
Best of luck in the rebuild.
Cheers Dodg.
AnswerID: 390625
Follow Up By: Woolbroker - Monday, Nov 09, 2009 at 17:47
Yes, well someone should tell Nissan that the 3.0 ltr is a grenade and probably warn the other drivers that are out there driving these vehicles....
FollowupID: 658400
Follow Up By: mowing - Monday, Nov 09, 2009 at 19:35
Woolbroker, Nissan are very well aware of the problems with this motor but as they made it they are not going to advertise the fact.
Mark
FollowupID: 658413
Follow Up By: Michael ( Moss Vale NSW) - Monday, Nov 09, 2009 at 20:29
Nissan never made rubbish engines until Renault took them over.. Renault have not done the Nissan brand any favours !! Michael
FollowupID: 658421
Follow Up By: Blaze (Berri) - Tuesday, Nov 10, 2009 at 02:55
Michael thats true about Renault not doing Nissan any favours, the problem stems from the fact that Nissan tried to short cut it and buy a motor in that runs fine in Europe on cleaner Diesel, but failed to cut the mustard here.
IMHO I don't think Nissan can go blaming Renault for it's problems. They should have designed and made a engine themselves that was euro3 and 4 compliant as its their brand that is taking the flack.
And the fact that they bury their heads in the sand to the problems for warranty etc over a 6 or more year period is just plain bad PR.
FollowupID: 658494
Follow Up By: Michael ( Moss Vale NSW) - Tuesday, Nov 10, 2009 at 07:43
Blaze, that may be so but if Nissan was still on its own, it may have had a different outcome, likely to still source engines from within. Michael
FollowupID: 658503
Follow Up By: Blaze (Berri) - Tuesday, Nov 10, 2009 at 11:40
I watched a program on Nissan the other day, about how they were nearly bankrupted and the joined with Renault to get them viable again. The estimated overall savings of $1.7 billion by 2002.
Now this all worked fine, but if then they started getting the problems at about 100,000k mark with the new 3ltr, so they did a patch job to try to overcome this. Since then it has been one patch and denial after another, not from Renault, but from Nissan. Sure their profits until the recent Global downturn were good but I question the PR.
Would I buy a Nissan?? Sure if I was in the market for a large 4X4! Would I leave the 3ltr motor in it? Not a chance! I would use the money saved buying a Nissan compared to a Toyota and fit a better power plant.
If I wasn't in need of the size of either of these 2 larger vehicles I would simply buy a Pajero, and have no warrranty issues. ;-)
FollowupID: 658532
Reply By: chisel - Monday, Nov 09, 2009 at 17:42
Just google "ZD30 grenade patrol" or similar. Although this is maybe the first I've heard of a 2006 blowing up.
AnswerID: 390629
Reply By: Member - Angus E (NSW) - Monday, Nov 09, 2009 at 17:44
Woolbroker
See this link for reference document re the ZD30 motor.
http://users.on.net/~aschulze/ZD30/ZD30%20Y61%20Reference%20Document%20-%20BW.pdf
I recently upgraded from a 2005 ZD30 to a 2006 4.2 Turbo diesel. I would suggest looking at putting a 4.2 motor in, rather than replacing with the inherently unreliable 3 litre motor. If you can pick up a low kilometre 4.2TD motor second hand, there is a little bit of work involved in getting it in.
A friend had a similar issue and got Monaro 4WD in Canberra (or Queanbeyan?) to do it for him. I think the motor was sourced from WA.
Angus
AnswerID: 390630
Follow Up By: Woolbroker - Monday, Nov 09, 2009 at 20:34
Thanks for the link Angus, Yep looks like some people have some good suggestions for Nissan to take on board.
FollowupID: 658423
Reply By: 120scruiser (NSW) - Monday, Nov 09, 2009 at 19:54
Sounds like a 3.0 litre to me and the saga continues.
AnswerID: 390648
Reply By: Member - John (Vic) - Monday, Nov 09, 2009 at 20:14
Do a search on this site for ZD30 or Nissan 3.0 litre motors and spend the next 3 weeks reading the issues.
Nothing new, its the same old engine and all those owners who buy the newer model think the problems are over are kidding themselves.
AnswerID: 390653
Follow Up By: Blaze (Berri) - Tuesday, Nov 10, 2009 at 11:25
Couldn't agree more John, We keep hearing the problem was only pre 2002, then pre 2004, then pre 2005 and 2006 and so on, as each model gets to the horried hundreds (hundred thousand K's) we all start to see failures. So now in their wisdom I believe they are going to fit a V6, man if they couldn't get a straight 4 cylinder to work heaven help any buyers of the V6.
How would you like to be one of the first buyers of the new power plant, with the warranty track record that Nissan has also, I would factore in that its a cheaper vehicle than the Toyota and buy a replacement power plant as of day one, chances are you will sell the original motor pretty soon to another Nissan Owner.. LOL.
FollowupID: 658528
Reply By: Woolbroker - Monday, Nov 09, 2009 at 21:07
Evening blogers thanks for the comments, problem is I was landed with this vehicle a Nissan....... when I started my new career. The amount of km's I do is around the average 210 kms per day 7 days a week. I didn't like the vehicle at first but it grew on me as it would being a company car and being supplied as part of my employment package.
Truth is I have gone out of my way to look after this vehicle and that’s probably why I've done 246 500 kms in 3.5 years without any problems.
The firm I work for have another Nissan like mine at Longreach and they are very much in two minds on what to do with the vehicle as it has around 210 000 kms on the clock. It may all so go bang… before it is sold but could anyone suggested what to look for prior to this sort of issue happening again? I do have a few thoughts that come to mind but we may have a true 3.0 ltr Nissan guru out their with some interesting do’s and don’ts……….Cheers and thanks for all the comments to date.
AnswerID: 390669
Follow Up By: psproule - Monday, Nov 09, 2009 at 21:22
Read the document mentioned further up the thread for answers to your questions. It is now very well documented and well known about. Through various forum readings I would estimate at least one a week goes pop. There have been other reports of post 2006 models, despite Nissan proclaiming that they fixed it in 2002 odd.
Further, you can head over to www.patrol4x4.com/forum/ and commiserate with all the rest of the "ZD30 goes bang" crew. There are hundereds sadly.
it's interesting the affect this seems to have had on resale values. ZD30 powered patrols seem to be worth nothing second hand (compared to new cost) but the 4.2 is actually appreciating.
Pat
FollowupID: 658437
Follow Up By: Geoff (Newcastle, NSW) - Monday, Nov 09, 2009 at 22:21
Wooly,
I'm going to take your name literally to be a man of the land, I'm going to believe your screen name is exactly your occupation.
I've a mate who by the above definition could be described as "Grain Broker" or at least the maintenance manager for the cryptic organistion.
As far as he's concerned for protecting his maintenance budget burning the lot of the ZD30 Patrols they own would be cheaper.
He signs off purchase orders regularly replacing clutches, dual mass flywheels, injector pumps, heads, pistons, long and short motors. The whole kit and kaboodle from 3 years ago to the latest model and Nissan always seem to have an out.
His organisation also has an out, don't buy another one! That should save Nissan a heap of money on warranty and truck loads of paper writing letters to deny warranty!
Geoff
Geoff,
FollowupID: 658456
Reply By: S&N - Monday, Nov 09, 2009 at 22:35
you asked "but could anyone suggested what to look for prior to this sort of issue happening again?"
I have a suggestion of what to look for, and its an easy one......if it has 3.0 stamped on the back, its a faulty patrol!
AnswerID: 390687
Reply By: Damo never buy a pat - Tuesday, Nov 10, 2009 at 08:10
Woolbroker,
I am feeling your pain as I know what you are going through. I have within the last month just paid $14k to get my patrol back from a full re-build as a similar problem occured with mine. Most of the earlier problems (up to 03 model) as I led to believe should have been resolved as they were pistons 1 & 2 and not enough oil within the motor to accomodate a highly strung little 3 ltr motor.
The problem with my 05 model was what they call a MAF (mass airflow sensor) which is between your air filter and your motor, this stopped working and as a result the boost problems occured and everything started to happen while I was driving with out my knowledge until it was to late. There is no warning when this MAF sensor goes so as a result I have now installed a Boost gauge with in the cabin to pre warn me. I am not saying that this is what caused yours to go BANG but it sounds very familier.
What you will be looking at will be a new short or long motor from nissan (don't bother asking for assistance as they are so good at throwing a dummy pass) the bad thing for you at the moment is that there is none in the country long or short, so a full rebuild or as a previous person has suggested I would put a 4.2ltr in. Mine is going perfectly now but for how long that is the question, I have lost all faith in Nissan 3.0ltr motors and I am as we communicate looking for a Landcruiser.
I hope this has been of some help to you and if there are any more questions please email back and I will endeavour to answer for you.
Have a good day
Damo (never buy a patrol)
AnswerID: 390710
Follow Up By: OREJAP - Tuesday, Nov 10, 2009 at 09:29
In relation to motors blowing up & what signs or symptoms are there prior to it actually happening I experienced two engine failures in turbo diesel Jackaroo's. A 2002 & a 2003 model...no warning just loss of power,shudder,stop. Temp gauge into the red. Patrols, I do not know everything about only that there was some mention on forums that the motor never had enough oil in the first place (As presented in new models by Nissan) & a larger sump was put on to accomodate the extra oil the vehicle required. As far as I am concerned my advice would be to purchase a good reliable vehicle with great engineering and that's a 2003 to a 2009 3.2Did Pajero Auto. They pull like a train & a great comfortable car to drive. I owned a GU & thought it was great value for money. It was a very good vehicle and suited our needs admirably. We went everywhere in it. When it was time to sell (before the Km's got too high) I drove the Pajero diesel & IMHO for towing,general driving (80% on road) the vehicle is way in front of the patrol. The new NT Pajero is better again than previous models with the new auto,motor & excellent roadside assist & warranty for 5 years & 10 years on engine & g/box. I think the new Patrol in late 2010 has a V6 Renault diesel......now that WILL be interesting...I don't know where it is being made,assembled or what Nissan are doing!!! Probably, Spain, Thailand someone mentioned on another forum Nissan have set up a huge complex in India...the new vehicle might not be called a Patrol it could be....Rajah or Taj Mahalmobile!!!
FollowupID: 658512
Follow Up By: brushmarx - Tuesday, Nov 10, 2009 at 10:54
I may well be wrong, but I thought the larger sump (more oil) was probably required, but Nissan opted to supply a shorter dipstick so more oil had to be added to register. Miles cheaper than sump replacement, but not efficient.
This may have been an urban myth, but sounded like a cheap cop out.
FollowupID: 658518
Follow Up By: Member - Graham H (QLD) - Tuesday, Nov 10, 2009 at 11:30
That is supposed to have been the fix prior to my 2003 .
BUT mine still only took the original amount of oil so dont really know.
FollowupID: 658530
Reply By: Outbacktourer - Tuesday, Nov 10, 2009 at 10:13
Woolbroker, there has been a firm mentioned in the past in relation to these threads that does a reasonably priced rebuild on these engines ($5-7K range). My advice would be to get it rebuilt and install a pyro (EGT) and boost gauge in the cabin to look for irregular activity. Boost should vary between 5-17psi depending on load and if EGT gets too high liftum right foot.
As the original owner of a 2002 3.0Di with currently 120Km on the clock I have followed these exposions since the beginning. It seems to me overboosting caused by MAF sensor failure is the most common problem, unfortunately the computer does not seem to be able to detect it so you need to do it yourself. Only use OEM air filters and change at 20K not 40K that the schedule says. Also have the MAF sensor cleaned periodically.
I find the vehicle an excellent performer and most comfortable to drive over long distances and the rougher the road the better. Mine has been all over Australia trouble free. I put the fitting of gauges to monitor the engine in the same category as fitting dtronic to it (which I have) or a larger turbo and exhaust on a 4.2.
Almost every vehicle is a compromise and has issues that need to be managed, this is an obvious and serious one unfortunately, but one that can be monitored and prevented. The 2006 Sahara I had used to drop it's bum to the ground with a half assed load in the back and something on the draw bar so i had to fit polyairs, Toyota did not want to know.
OT
AnswerID: 390726
Reply By: TerraFirma - Tuesday, Nov 10, 2009 at 14:15
Can I ask is it very unusual for a Nissan 3 Litre Diesel not to be aware of the reputation of his vehicles engines, in this case the infamous Nissan Time Bomb?
This poor owner seemed surprised and it must be tragic to find out like this on these forums.
Sad to hear for anyone who has looked after and taken pride in their vehicle when this happens, will say he got more KM's than most, you perhaps a success story?
AnswerID: 390745
Follow Up By: HGMonaro - Wednesday, Nov 11, 2009 at 09:48
Most people don't know these type of forums exist. The number of ZD30 owners who visit these place compared to the number of ZD30's sold would be small. It's a worry that there about 250 reported cases (on the document that flies around), how many more are out there that don't get reported on a website... more that that's on that list I'd say. Luv to see the Nissan files on the issue... pretty thick folder I bet! I've talked to ZD30 owners and they haven't heard of the problem (remember Nissan isn't telling anyone or even owning up to it!) and were genuinely surprised as before they go BANG they are all pretty happy with their vehicles.
FollowupID: 658670
Reply By: PhilZD30Patrol - Tuesday, Nov 10, 2009 at 16:07
Woolbroker
Sorry to hear about the engine problems
I have a 2001 ZD30 with 185,000 kms on the clock.
I have not had any engine problems, it still runs as good as ever.
Regarding claims that all 3 litre Patrols blow engines, this is simply not true. Unfortunately too many have failed prematurely and Nissan Australia have not done the right thing.
I have travelled 32,000 kms in the last 2 years around Oz on all sorts of roads. I am amazed at how many 3 litre ZD30 Patrols are out there in the bush. When I ask who has had engine failures I find very few.
I agree those who have are to many. If you added up all the genuine first hand accounts listed on various web sites it would total a small ( but unacceptable) percentage of the total ZD30s now in Oz.
I don't accept that Patrols have other excessive reliability issues other the engine failures. Toyota Landcruisers have their own problems and are not as reliable as some would have us believe. Remember that they cost megga bucks more to purchase and are thirstier on the diesel than our humble Patrols.
I think that some, but definitely not all, ZD30 failures may be caused by poor servicing issues. The original 2000/01 books recommended 15,000 kms engine oil and filter changes. I have seen a copy of a service Nissan Service bulletin recommending 5,000 kms engine oil and filter changes using 10w - 40 semi synthetic CF-4 oil or better. Nissan didn't bother to advise us private owners.
Any way hope you have some luck getting it all fixed up
AnswerID: 390766
Follow Up By: Woolbroker - Tuesday, Nov 10, 2009 at 17:12
Phil,
Well.... thanks for the comments but at the moment I haven't got to many good things to say about the 3.0 ltr ZD30 motor or Nissan. But as I mentioned before, they do grow on you....and I have had Landcruiser's all my working life.
This 2006 3.0 ltr St Guiv Manual Nissan Patrol Wagon has been looked after and the service book has been full for some time now. It is 3.5 years old with 246 500 kms on the clock... Phil.. 3.5 years..old.. I had a client say to me just last week 'have you got a new Patrol' ... this vehicle was in top shape the Nissan dealer that has preformed all I mean all the services commented on how good of a run I have had out of this Patrol and it was only serviced a fortnight ago. The service manager commented on it and said it may need some new shocks at it's next service which would have been a good idea.
Since last Friday morning when it went bang I have probably talked to more than 100 people and they all know about the Patrol.
I know of four new owners and I have pre warned them to sell before the warranty runs out. Thats probably all they can do and hope the vehicles don't go bang before then. Phil best of luck with your Patrol and I do hope you are saving for the repairs...but their is simply to many people stating the obvious.
Cheers Woolbroker
FollowupID: 658589
Follow Up By: Outbacktourer - Tuesday, Nov 10, 2009 at 20:48
Phil, you need to get at least a boost gauge and preferably a EGT. The service schedule does not cover replacement of th MAF sensor that seems to be main cause of issues. Apparently the early MAF's were worse than the later ones but if they fail you want to know about it..
OT
FollowupID: 658617
Follow Up By: Member - Bucky - Wednesday, Nov 11, 2009 at 04:40
PhilZD30Patrol
Better go back and read your owner's manual.
It's rather unfortunate that people misinterprit (spelling) it, and mind you, you have to be a corporate lawyer, to know where to look, but it's all there.
I had a 2003 ZD30 TD motor in my Navara, and in the manual oil quality, viscosity, and interval changing are clearly stated.
Now being a rather keen "home mechanic", and doing most of my own servicing, I was rather taken back, by the complexity of the manual, so I enlisted help from a mechanic mate of mine, who showed me the info I needed.
Wow, I recon I was lucky, because I was ready to put the wrong oils in her..
"Oil's ain't oils" is very true these days.
Neither is coolants, only genuine Nissan coolants, will not void the warranty, and that is not written exactly as it should be either, as you have to read that between the lines.
Bring back the simple stuff again !
Bucky
FollowupID: 658649
Reply By: Member - A J- Wednesday, Nov 11, 2009 at 13:27
Woolbroker - when you took your vehicle back to the dealer who serviced it, did he advise that the problem with the motor was well known or not?
Would he advise you to purchase another Nissan with a 3.o l motor?.
A J
AnswerID: 390865
Follow Up By: Woolbroker - Wednesday, Nov 11, 2009 at 14:42
A J, yes you do wonder sometimes who service's the vehicle when there in the shop as I have always made sure the air clearer has been changed after picking up the vehicle. I'm probably a customer that checks the obvious serviceable items but when it comes to the internal running of the motor etc you would like to think your Nissan Service Department are on top of that...
as you do pay for it. My last service cost was $1090.00. (30/10/09)
A Nissan dealer has been servicing my vehicle since it was brought brand new and I have the service book to prove it. At no time ever has the Nissan service department raised any issues about the 3.0 ltr motor only the opposite saying the vehicle is going well and it's all in good order.
And yes the Nissan dealer I go to would recommend to anyone to buy a 3.0 ltr Nissan Patrol as they have new and second vehicles in the yard all the time.
But they may not sell as many when the word gets out about my Patrol (small town talk) and all the comments that are posted on this forum who would buy one.
Woolbroker
FollowupID: 658697
Reply By: Damo1970 - Wednesday, Nov 11, 2009 at 23:35
Well here we go again, mass scare mongering by people that really have no idea or no personal experience - the old mate of a mate told me syndrome.
Woolbroker's problem, whilst disappointing, is hardly a reason to jump on the bandwagon. So he had a turbo failure that probably caused the engine failure - the vehicle has done a quarter of a million k's, not the first vehicle of that vintage to have a mechanical failure........
I am in the middle of a trip around Australia & my pitiful little 3.0L hand grenade has lugged a combined total of 6 tonne around this amazing country of ours - so far we've covered 40,000km without a hint of a problem.
When we left i took it upon myself to do a little survey. Whenever i came across a 3.0L Patrol owner towing a caravan i asked them a few questions. First, have you ever had any engine failures & second, do you persoanlly know of anyone who has had an engine failure.
Of 53 people surveyed, one had an engine failure on a 2000 model with 211,000km on the clock & 1 owner knew of someone who had had a failure.
Another bloke i spoke to was on his 4th 3.0L Patrol & loved them, towing his 3 tonne Kedron van around the country.
To me, real life experiences of those that are out there using their vehicles are worth a hell of a lot more than slagging off by people sitting behind a desk with nothing better to do.
It would not surprise me at all if some of the comments above are by the serial "bag the Patrol" brigade - their's plenty of them out there
AnswerID: 390946
Follow Up By: Member - John (Vic) - Wednesday, Nov 11, 2009 at 23:58
Go and have a look at the Patrol forum and ask the Nissan owners on there if its bull.
Then again it may hurt if you suddenly find more than one Nissan owner actually slagging off about the car they spent good money on that has gone bang!!
FollowupID: 658776
Follow Up By: Damo1970 - Thursday, Nov 12, 2009 at 02:05
LOL
Never said there wasn't or hasn't been an issue but it is nowhere near as bad as what some will have you believe.
For people to say "your patrol WILL blow up, only a matter of time" is just ridiculous & childish
FollowupID: 658784
Follow Up By: Outbacktourer - Thursday, Nov 12, 2009 at 08:23
Damo, you have been getting it all wrong...if you want to know about the 3.0Di problem you ask Toyota owners, not Nissan owners, that way you will find out much more about it!!
OT
FollowupID: 658792
Follow Up By: Damo1970 - Thursday, Nov 12, 2009 at 11:01
Yep, you're spot on there
FollowupID: 658807
Reply By: whitiepatrol4x4 - Thursday, Nov 12, 2009 at 14:19
Hi Woolbroker,
Outbacktourer has provided good advice.
As an owner of a series III Di 3.0 Patrol, I think that the problem with your turbo is unfortunate, it is even more unfortunate that it has taken out your aftercooler and motor.
The turbo is made by Garrett and is a GT2052V, these are very good turbos and your mishap is certainly not common on these motors. The turbos like any other mechanical part needs to be looked after and the best way of doing that is by using good oil and allowing the turbo to cool down prior to shutting off the motor (ideally wait until the temps are 200c after turbo).
The "blow up" problem that a few members on other forums enjoy blowing out of proportion (pardon the pun) can be typically contributed to a faulty MAF sensor.
This is not a "Nissan" thing, it is the same on all high tech diesels that do not have an EGT sensor feeding information back to the ECU.
Prevention is always better than the cure so by installing EGT and boost gauges, we are able to see if ever the electronics are not working correctly and we are able to catch all problems (except real mechanical ones like yours) before it causes damage to the motor.
The challenge is really to advise all who have these high tech motors to install the two gauges - then keep on enjoying the truck...
Another thing that we should all be weary of is the implementation of EGR on these type of motors. EGR is not bad per say but when mixed with blowby oil, the exhaust particles turn into goop and slowly block the intake manifold which is very bad for a diesel.
There is a simple fix for this as well, install a good quality blowby catch can. If you have had your vehicle for a while, then I would suggest that a clean of the intake manifold would also be required (throttle body and inlet of the intake manifold can be accessed and cleaned without too much difficulty).
The 3ltr motor is a good design and members from another forum that have striped them down after 260Ks have found the internals to have minimal wear, the problem was a hole in the piston due to a failed MAF sensor:
"Just my thoughts from what I found when I pulled mine down after the problem
at 263,000K
wear in bore - too small to measure
twist in head - less than 1/2 thou
intake and exhaust manifolds also less than 1/2 thou twist.
big ends - not run in yet. Numbers still readable on shells.
mains - identical with the new ones, thickness, ovality and yaw. no wear there at all.
So with new engine australia pistons, and a weather eye being kept on the maf (with a spare in the glove box) I reckon she's good for at least 1,000,000 K "
As you can see, the motor is good but the electronics are what can let it down - by installing a boost and EGT gauge, it won't get the chance.
Here is a link to a page that shows Site Link what Ks are possible with this motor.
Whitie
AnswerID: 390994
Follow Up By: Woolbroker - Thursday, Nov 12, 2009 at 17:42
Whitie,
Obviously allot of people like their Nissan vehicle's no shame in that at all and most of you know what is needed to stop the problems and also anyone reading these forums do too. It's good stuff..... I even had a chap give me a link to a manual that fixes allot of the problems that's great also..and really it's not until the sh_ _ hits the fan when we all hear the stories or even listen at all.
Look I'm not trying blame anyone for my Nissan blowing up as I have tried to do my best and look after the vehicle as it is a necessity to have a well maintained vehicle for the line of work I'm in.
Many blogers have made mention to allot of good points and I appreciate all the comments but I can't see pass the fact that Nissan need to give the Nissan owners and prospective purchases all the facts about potential problems or even give them some good service advice. It is very disappointing when so many people tell you that "mate your vehicle should do 300 000 kms + and it doesn't, but maybe they would if everyone is told the facts.
Nissan service advice needed or Nissan problems will keep happening.
Our company can't get out of them quick enough sorry..
FollowupID: 658852
Follow Up By: whitiepatrol4x4 - Thursday, Nov 12, 2009 at 18:26
Totally understand and agree with you Woolbroker, unfortunatelly most Nissan service departments (or choose another manufacturer) do not know the benefits of the gauges - some will even scare you away from them saying that it will void the warrante if you install them... I do not think that they will be advocating them any time soon :(
If your problem was caused solely by the turbo, the gauges may or may not have helped but a Garrett turbo blowing in this manner is not something that you hear about often. Usually, there will be some indication that the turbo is going and you will typically hear it unless the problem was caused by oil starvation to the bearings, this may be caused by (amongst other things) not allowing the turbo to cool down before shutting the motor off.
I am just letting you know that this is not purely a Nissan thing, most (jf not all) of the diesels that are high tech at the moment still do not have an EGT sensor feeding back into the ECU and are using a similar turbo - if there is no EGT sensor, then you need to install it yourself. This is the number one mod in the states when you purchase a diesel, it is just not known here I guess?
Most if not all new diesels are also using EGR to help meet the stringent polution laws so IMHO a blowby catch can is also required.
Gone are the days of the purely mechanical diesel motors, the new V8 Toyo has about twice the amount of sensors as does the Nissan 3ltr CRD but I have not seen an EGT sensor on it either.
Whatever you get into, if it is a turbo diesel and has electronics - put an EGT gauge and a blowby catch can on it. You will be well on the way to be able to enjoy lots of trouble free Ks with that setup.
FollowupID: 658855
Reply By: keithw-qld - Friday, Nov 13, 2009 at 16:23
very common problem, my brother in law has had 2 patrols, and both had engine failures, 3ltr turbo diesels.conrod let go and went through the block in the last one.
AnswerID: 391136
Reply By: Shearer - Saturday, Nov 14, 2009 at 16:59
Hey does anyone know of a ZD30 motor with low kms at all.
We had a motor with 1700 kms for $7900 out of a right off but... it's the latest motor and apparently it will not fit as apparently there was a motor update in 2006 and my May 2006 made Nissan Patrol Wagon has the earlier motor.
(This may have been the problem the older motor???)
Eng No. ZD30052629K Vin/Chas JN1TESY61A0386620 5 speed manual.
Cheers Woolbroker
AnswerID: 391202
Follow Up By: whitiepatrol4x4 - Saturday, Nov 14, 2009 at 21:52
Are you refering to when the motor was changed from a Direct Injection (Di) to the Common Rail (CRD) motor?
If so, then it will fit as it is essentially the same motor but they also changed a few other things that hang off the motor such as the ECU, MAF, injection pump. fuel filter and aftercooler.
Have you looked into rebuilding your motor? Engine Australia sell full rebuild kits for around $1700.
A few members of the Patrol 4x4 forum have used this kit and have been very happy with the quality of the parts.
Whitie
FollowupID: 659087
Reply By: Nugget6 - Saturday, Nov 14, 2009 at 22:43
gday mate,
i have felt your pain and will never buy another Nissan.
just burn it, it's easier.....
cheers.
AnswerID: 391227
