Tyre Gauge - which one
Submitted: Thursday, Nov 12, 2009 at 11:53
ThreadID: 73708 Views:8344 Replies:13 FollowUps:11
Can anyone recommend a tyre pressure gauge and whether it should be digital or otherwise?
After an accurate gauge for my son for xmas gift.
Thanks.
Russ
Life-often hell but never boring.
Reply By: Member - steve. B... (NSW) - Thursday, Nov 12, 2009 at 13:00
Hi Prickle...
Bob Jane sells a Digital one. They gave me one when I purchased my last set of tyres.
Steve. B...
AnswerID: 390986
Reply By: Member - COLIN D (VIC) - Thursday, Nov 12, 2009 at 13:00
A Really good one is the Longacre liquid filled dial with needle $150.00
You can buy them at Revolution race gear , i think they have stores in S.A as well AS Melb.
Colin
AnswerID: 390987
Reply By: ben_gv3 - Thursday, Nov 12, 2009 at 13:05
How much do you want to spend?
The ARB EZ Deflator is a good one, the DrAir equivalent is half the price.
FWIW I have a digital one which I got on special at Jaycar. It seems accurate enough and has an inbuilt light which is useful. Was only a few $$$.
I think it's very hard to find a super accurate gauge without spending a lot of $$$. It's more important to have consistent readings.
AnswerID: 390988
Follow Up By: Member - Allan B (QLD) - Thursday, Nov 12, 2009 at 15:58
I use the Jaycar digital tyre gauge and find it to be accurate and well-made.
At $19.95 it is good value.
I also carry a basic "stick" gauge just in case.
In general, a good quality digital gauge will be more accurate and more reliable than a stick or dial gauge of the same price. And they are very convenient to use as they hold the reading to allow removal from the tyre to read.
FollowupID: 658840
Reply By: Robnicko - Thursday, Nov 12, 2009 at 14:09
I got a good one from tyrepower years ago.
It is the Jamec-Pem Brand and has been very reliable.
$25 I paid
AnswerID: 390991
Follow Up By: River Swaggie - Friday, Nov 13, 2009 at 00:26
Hav the same and there about $43 bucks now from Bursons,I also have the vehicle one to blow up tyres (they also use in Servo's too)...English made and totally accurate..
FollowupID: 658913
Reply By: Moose - Thursday, Nov 12, 2009 at 14:34
Have you looked at thread 73681? Discusses accuracy of gauges.
AnswerID: 390996
Follow Up By: Member - Prickle (SA) - Thursday, Nov 12, 2009 at 14:47
Moose,
Yes, thanks, that was the thread that prompted me to post mine, prior to me beginning my search.
Russ
FollowupID: 658827
Reply By: Member - Scoof (SA) - Thursday, Nov 12, 2009 at 14:35
I have a digital tyre gauge I got it from a John Deer tractor agent it's about 12 years old, fits in the glove box . No bolky hoses just a small black plastic animal 40mm wide by about150mm long.
I got it when I use to race speedway the pits were always dark and it was hard to see a normal dail gauge this one beeps when it has taken the tyre pressure, so you can walk over to the light and read it or just stand up and read it.
I would recomend it.
Cheers Scoof .
AnswerID: 390997
Reply By: Member - Porl - Thursday, Nov 12, 2009 at 14:41
As with above, if you want a really good one go the places where pressure means the most.
I would go to a motorcyle store, if the tyres aren't round or over inflated then it makes a big difference to a bike.
I still find my Michelin dial gauge accurate and it is 20 years old now, bought the best I could at the time for my motorcycle years.
AnswerID: 390998
Reply By: Robin Miller - Thursday, Nov 12, 2009 at 15:13
The bushranger 3:1 is probably the best all round device at a resonable price ($30), and used by others on this site following reccomendation.
It is widely available from camping / 4wd stores.
Reasons for its long success are that it has linear dial gauge with a max of 60psi
which allows a good reading at down to below 10 psi , and allows repeatable results.
It uses a screw on fitting , not push on.
Its also a deflator.
For Higher PSI readings I carry an ARB digital item, and its good practise to carry
2 guages.
Note digital ones usually need batteries at the wrong time.
Note - Push on guages often end up damaged as a result of excessive push on force.
One source of many is
http://www.downundercamping.com.au/home.php?cat=312
AnswerID: 391006
Reply By: brushmarx - Thursday, Nov 12, 2009 at 15:40
I purchased a Bushranger digital from TJM, and it fell apart. The free replacement also fell apart.
I no longer have a Bushranger digital gauge, just a $25 Supercheap old fashioned dial that seems to work fine.
AnswerID: 391012
Follow Up By: pickle - Thursday, Nov 12, 2009 at 15:54
Not as silly as what it sounds.
I did a detailed test on nine different tyre guages digital and non priced from $6 - $50 and the Supercheap job came up the most accurate. That would be the one with the protective case.
Dave Howard
Technical Officer
Pajero 4wd Club of Vic
FollowupID: 658838
Reply By: ABR - SIDEWINDER - Thursday, Nov 12, 2009 at 19:10
Hi Russ
Email me your address and I will send you one for free.
Derek from ABR
AnswerID: 391031
Follow Up By: ben_gv3 - Thursday, Nov 12, 2009 at 21:17
Now how's that for service. :-) Top stuff Derek.
FollowupID: 658889
Follow Up By: ABR - SIDEWINDER - Friday, Nov 13, 2009 at 08:39
Thanks, I tried sending Russ a PM but it seems business members are blocked from doing this.
Derek
FollowupID: 658926
Follow Up By: ben_gv3 - Friday, Nov 13, 2009 at 10:58
That unit looks very similar to the Bushranger/DrAir versions though.
FollowupID: 658938
Follow Up By: Member - Prickle (SA) - Friday, Nov 13, 2009 at 15:37
As stated above, cannot beat that for service.
Thanks for the offer Derek, email has been sent, I have used the email address on your web page so hope that this works.
Russ.
Russ
FollowupID: 658957
Reply By: Member - Flynnie (NSW) - Thursday, Nov 12, 2009 at 20:56
Best one is the one that works when you want it to work.
Had a few digitals including a Michelin. Got rather frustrated with finicky nature of them. Made up my mind to go retro and get an analogue gauge. Got a VDO. It has been great. It just works great for me.
Image Could Not Be Found
From the photo you can see it has kilopascal reading around the outside and psi around the inside of the dial. It holds the reading until the reset button is depressed. It is just visible in the photo on the body not far from the 20 cent piece. You can feel the click of it having taken a reading. Very positive and consistent in operation.
It comes with a protective cover and from memory was somewhere between $30 and $40 earlier this year from New England Instrument Company Tamworth.
Highly recommended.
AnswerID: 391041
Follow Up By: Richard Kovac - Friday, Nov 13, 2009 at 02:01
Flynnie
I'm with you, had two over the years 30 and they are about the best you can buy.
First on the rubber tube rotted and I replace it with two o-rings (to seal on valve stem). it is now my spare.
I have a new one that is in Doug's Tub
Richard
FollowupID: 658917
Follow Up By: Member - Flynnie (NSW) - Saturday, Nov 14, 2009 at 00:10
My VDO gauge lives in a Doug's tub as well. This is a great bit of gear for 70 series cruisers. Makes the glovebox so much more useful.
Flynnie
FollowupID: 659002
Reply By: Member - Prickle (SA) - Friday, Nov 13, 2009 at 15:39
Thanks to everyone for your responses and to Derek for his offer.
RB
Russ
AnswerID: 391131
Reply By: splits - Friday, Nov 13, 2009 at 16:42
I bought a $24 Lumen about 5 years ago after reading a gauge testing article in a major motoring magazine. About 15 gauges ranging from dial to the pencil types were checked. One test consisted of dropping them onto concrete 10 times from a height of 1 metre.
Only two passed all tests. One was the Lumen and another was one with a name starting with S but I can not remember what it was. Both sold for about the same price.
I have checked it many times over the years against service station gauges that looked new and so far it has always read the same.
AnswerID: 391137
Follow Up By: Member - Ed. C. (QLD) - Friday, Nov 13, 2009 at 21:34
I reckon the one starting with 'S' would have been the Stetho-gauge...
A cheapy, but a goodie, every review that I've ever seen has rated them very highly..
I've had a few of 'em for quite a while now, and they consistently record within a cat's whisker of each other.. that's good enough for me ;-))
Confucius say.....
FollowupID: 658986
