Help with Hema Navigator
Submitted: Friday, Nov 13, 2009 at 09:31
Member -Dodger
The battery life in my Hema only lasts 3 days when turned off.
I have used the Quit exit button on the 4wd part and the exit part on the Street section.
However no matter which way I turn it off it seems the battery is flat after around three days idle.
I checked the archives but found no usefull info.
Also same for the Ozie site.
Reply By: DIO - Friday, Nov 13, 2009 at 10:10
Suggest that you contact
HEMA for their thought on the matter. After all, they are the manufacturers of the product. Good luck with it.
391093
Reply By: Member - Matt & Caz H (QLD) - Friday, Nov 13, 2009 at 11:18
Hi Dodger
We to have a hema navigator - same thing, when off battery runs out.
391107
Reply By: Tony MD - Friday, Nov 13, 2009 at 11:31
This may be relevant to the Hema Navigator, it is relevant to some PDA units.
Leaving a memory card - SD or similar will cause battery drain, even when the unit is turned off. Likewise, it could be possible that wireless functions (bluetooth, infra red or 80211b/g) are infact still operational when the unit is turned off?
Try the card removal first.
Cheers, Tony.
391109
Reply By: Member - Oldplodder (QLD) - Friday, Nov 13, 2009 at 11:41
Have a similar problem with my PDA.
If I use the power button and turn it 'off', it will last about 3 days because in reality it goes into sleep mode. Start up is pretty quick, only a few seconds.
If I hold down the power button for more than 3 seconds, I get a prompt about 'shutdown', and if I tap yes, the battery then lasts for a couple of weeks. Start up takes a while as the system boots from nothing.
391111
Reply By: ExplorOz Team - Adele - Friday, Nov 13, 2009 at 12:06
Hi Dodger,
I just thought I'd let you know that the current Hema Navigator (version 1)never actually turns off, it only has a "sleep mode" (which still uses the battery.) Due to customer feedback about this feature, the new Hema Navigator 5" (released soon) will actually turn off completely, not in "sleep mode".
I hope this helps with your enquiry.
Regards,
Adele Scala (Online
Shop Manager)
391115
Reply By: CJ - Saturday, Nov 14, 2009 at 10:02
Dodger it is normal.
I recall actually reading it in the manual when I bought it.
CJ
391185
