Towbar for a Isuzu Play MU 4X4 Deisel wagon
Submitted: Friday, Nov 13, 2009 at 19:41
poppyg2
Hi fellow 4x4ers. I live in
Perth and have just been given an 1994 Isuzu MU 4X4 Diesel wagon, however it does not have a towbar. Does anyone know where I could purchase one of if there are other vehicles that may fit. A desperately need one to go
camping. cheers
Reply By: RV Powerstream P/L - Friday, Nov 13, 2009 at 20:08
Poppy
Holden Rodeo 88 to 96.
Ian
391152
Follow Up By: Isuzumu - Friday, Nov 13, 2009 at 20:36
Sorry Ian the Rodeo ones need to be modified to fit, I know as we had to build a tow bar for my MU today, but Poppy what do you want to tow?, in weight that is. There is one available which bolts straight on the back four bolts, but only good for around 750 KGs even though it is rated to 1200 KGs
The Rodeo ones are to wide and with our MUs the hangers on the left springs are to far back.
658979
Follow Up By: poppyg2 - Friday, Nov 13, 2009 at 21:07
Isuzumu. 750kg max camper trailer fully loaded. so it would suffice.. poppy
658981
Follow Up By: Isuzumu - Friday, Nov 13, 2009 at 21:39
I willl have a look in the morning and get some no's off it for you and post back here, have one here but would cost more to post then to buy lol
658988
Follow Up By: Isuzumu - Friday, Nov 13, 2009 at 21:41
Forgot to add go to www.clubisuzu.com for all the info you need on your MU my user name is Isuzumu1
658989
Follow Up By: RV Powerstream P/L - Saturday, Nov 14, 2009 at 07:42
Bruce
Well Ill be blowed I was under the impression that most Rodeo bits were interchangeable with the MU.
Thank you for that.
Ian
659007
Follow Up By: Isuzumu - Saturday, Nov 14, 2009 at 08:48
I will see if I can take a photo of the new one and post it for you Ian
659014
Reply By: Isuzumu - Saturday, Nov 14, 2009 at 08:51
ok poppy here is the no's you need...Hayman Reese. P.No 1532 it's for Mitsubishi Payero 83 ON Max towing cap 1250 KGs and Ball 80 KGs hope that helps.
391182
Follow Up By: poppyg2 - Saturday, Nov 14, 2009 at 12:46
Hi Bruce. thanks for that. I will give it a go today and see what happens. Did they have to make any modifications to get it to fit? Mark
659029
Follow Up By: Isuzumu - Saturday, Nov 14, 2009 at 13:04
No mods needed for that one Mark if you have a steep on the back it just comes off and there is four threaded bolt holes there. How luck are you to be given an MU great, don't forget to check out the club site we are all very pleasant people there hahahaha
659033
Reply By: Isuzumu - Saturday, Nov 14, 2009 at 09:07
Here is a couple of shots, it still needs the top bolts put in and a coat of paint.
Image Could Not Be Found
And for those who want to know about engineering cert no it does not have one but it is strong enough to hold a bull out to p""s
391183
Follow Up By: Member - Kevin J (Sunshine Coa - Saturday, Nov 14, 2009 at 09:26
Hate to be a 'wet blanket' but it will matter little if you have an accident which ends up in the Coroner's Court. No cert. and they throw away the book regardless of how
well it was built.
Kevin J
659016
Reply By: RV Powerstream P/L - Saturday, Nov 14, 2009 at 11:23
Hi Bruce
You polluted an MU with a Mr Bitchi bar.
Ive checked
mine and the 94Auto has a Hayman Reece R1136 Holden Jackaroo LWB 89/3-93 1500KG 120KG.
The 95 Manual has a Trailboss OTHD300B Tongue No 5000 GTM 1800KG Ball 180KG.
What ever mods are done if they do not detract from the stated capacity and you do not tow in excess of the stated capacity then you are still legal and an engineering assessment would shut down an overt Insurance Company trying to deny liability.
If you tow in excess of the stated capacity you can be legally charged regardless of how strong it is as you are obligated to plate it correctly.
NSW Technical RTA advised me you can build your own and plate it and then you have a valid argument that can only be proven wrong if it is not up to an engineering standard that would be the correct standard for what it is plated for.
The legal costs to prove it may exceed an initial engineering report as to its adequasy.
Ian
391186
Follow Up By: RV Powerstream P/L - Saturday, Nov 14, 2009 at 11:26
I should have stated that both my vehicles have no mods at all they fit.
Ian
659022
Follow Up By: Isuzumu - Saturday, Nov 14, 2009 at 12:53
Ian the MU Wizard we have has a Trailboss....2500kg/250kg ball, but it is coil sprang so that bar won't fit the MU which I was hoping for. And those two you have would be a little to small for my needs, the old Viscount is 1700 kg ATM, oh in the sh't again it is only suppose to be 990 kg ATM by the reg cert.
If I did every thing 100% legal I would not be game to take a leak or breath air, and as for most van out there if the owner was to put them over a weigh bridge I think they would find them to be over. So Kevin tell me your van is 100% legal cause if it is not your in the same sh't as me.
659030
Follow Up By: Isuzumu - Saturday, Nov 14, 2009 at 13:01
Sorry Ian, I just re read your last post, yes I will check out the situation here in Qld see what has to be done.
We can legal tow what the Jackaroo of the same vintage can with the MUs, I think it is 2250 kg. I got that from DGA whom I am insured with. Ge I think I need a beer after all this lol
659032
Follow Up By: poppyg2 - Saturday, Nov 14, 2009 at 13:09
Fellow MU owners. The my camper trailer comes no where near the weight capacities mentioned even with the bride sitting on the trailer. I so I will speak to Holden & a trailboss distributor as
well if I can find one in WA. Regards Mark
659034
Follow Up By: poppyg2 - Saturday, Nov 14, 2009 at 13:18
Ian I tried registering with the club at www.clubisuzu.com but it didnt seem to work. but will try again. mark
659035
Follow Up By: RV Powerstream P/L - Saturday, Nov 14, 2009 at 13:18
Try the wreckers also there has to be some Jacks of that vintage around.
Can you post a photo of your wifes chair on the draw bar or are you flat out on the ground by now.
Ian
659036
Follow Up By: RV Powerstream P/L - Saturday, Nov 14, 2009 at 16:21
The club isuzu site is working Ok you must have done something wrong.
You have to get a return email of acknowledgement and then activate from the link on the email.
Ian
659051
Follow Up By: poppyg2 - Saturday, Nov 14, 2009 at 16:57
Hi Guys. You wont believe this but I jut picked up a legit bar & wiring from a wrecked MU at a nearby wreckers for $90. It must be the only wrecked mu in WA. Cheers and thanks everyone for your invaluable advice. I will certainly be getting on the isuzu site. Mark
659053
Follow Up By: RV Powerstream P/L - Saturday, Nov 14, 2009 at 18:06
Good one Mark Enjoy.
Ian
659064
Follow Up By: Member - Malcolm (Townsville) - Saturday, Nov 14, 2009 at 21:10
Hey Bruce
Thanks for that link to the Isuzu site. I looked at that once before and (obviously didn't look hard enough) thought it was american :-)
Malcolm
BTW I signed up and saw your message for a trip in June. No mexican trips for me that time of the year ;-)
659084
Follow Up By: Isuzumu - Sunday, Nov 15, 2009 at 10:28
Good one Malcolm, that trip will probably not eventuate, may even end up up your way then for the V8s. Actually I just talked the Boss into take a weeks long service leave after the June/July school holidays so we can do a northern trip for a change. So I will do that other trip in September.
659123
