viscus fan testing
Submitted: Tuesday, Sep 23, 2003 at 14:09
ThreadID: 7376 Views:2421 Replies:5 FollowUps:1
Hi All
What is the best way to test a viscus fan to ensure it is working properly
Reply By: David N. - Tuesday, Sep 23, 2003 at 14:33
Been down that track.... very simple really.
If it's hot, and if your donk is hot, then when you rev the engine the fan should "roar".
If it's not "roaring" then it's probably not working.
(you probably hear it "roar" when you first start from cold in the morning for a short time.- it should make that same noise when it cuts in when HOT.)
AnswerID: 31766
Follow Up By: Member - Oskar(Bris) - Tuesday, Sep 23, 2003 at 20:44
Been down that track myself.
You are right.
You cannot tell by turning the fan by hand cold or hot.
At cold start-up it should "roar" for a few seconds and then settle down.
Then as David says it should start to "roar" again when it gets hot.
But I like the idea of filling with new sil. oil.
OskarMrs Oskar on Big Red
FollowupID: 22692
Reply By: Hughesy - Tuesday, Sep 23, 2003 at 17:38
Simon, should be a slight/mild amount of resistance when turning it by hand (with engine off). If there is no resistance or a heap of resistance than it probably needs looking at. Look for signs of fliud leak around the hub too, good indication that it might be stuffed.
Hughesy
AnswerID: 31778
Reply By: howesy - Tuesday, Sep 23, 2003 at 18:31
In the end there is no real way of knowing. My hilux was getting hot under extreme load at slow speed and Several mechanics said the hub seemed fine. I stripped the hub and cleaned it and toyota sold me the correct silicone oil for $10 a vial. I put three vials in it from completely dry and for two years now the temp dont budge.
Things are not always as they seem
Discount all the other possibilities and if you are still drawing blanks do the reco.
AnswerID: 31783
Reply By: Steve - Tuesday, Sep 23, 2003 at 21:27
And don't take it to your local Toyo dealer either ... they have no way of knowing.. I can tell you having been ripped off by the dealer on south coast of Victoria..
AnswerID: 31815
Reply By: simon - Wednesday, Sep 24, 2003 at 11:16
thanks guys
i tracked it down through toyota is $11 a vial
AnswerID: 31863
