70 series cruiser wiring ideas
Submitted: Sunday, Nov 15, 2009 at 13:08
Rockape
Here are some photo's of how I run me aux power out of and into my old 75 series.
Some may wish to use the same method so here goes.
The sockets and plugs are from RS (radio spares), they are very
water resistant having O- ring seals and compression fittings on the leads. They are rated at 10amps wish is fine for most uses.
The outlets run my fridge, general/trouble light and led flood light + I plug in my battery charger and reverse feed the battery's to keep them topped up. Have also fitted the same outlet on the caravan.
I have fitted my 50a Anderson plug into the Kaymar bar through an existing in the bar, it is a perfect fit and is kept up out of harms way.
Hope this helps someone.
Image Could Not Be Found
