Tuesday, Nov 17, 2009 at 22:58
Daryl,
no real smart solar supplier will give you the regulator attached to a panel, unless the panel sits beside the battery, they will tell you to fit the Solar regulator adjacent to the battery system.
In any long (extension) power cable there will always be a voltage drop when the cable is undersized, and most are.
When the regulator is near the panel, not the battery, the power is regulated for a lesser output and then that further reduces as the Voltage is further lost in the cable.
However when the solar reg is placed where it should be, beside the battery, it regulates whatever voltage it gets from the solar system, sending it to the battery beside it with no further voltage loss incurred.
Maîneÿ . . .
659458
