Toyota Hilux Bluetooth Pairing Problems
Submitted: Sunday, Nov 15, 2009 at 15:38
ThreadID: 73767 Views:36376 Replies:8 FollowUps:2
I just bought a new SR5 Hilux with bluetooth mobile phone accessories and I'm having problems connecting.
I have paired my phone with the car and authorised it to make automatic connection everytime I get in the car, but it will not work. As soon as it connects it instantly disconnects again. When I then try to manually reconnect, it connects then automatically disconnects again straight away...
Any advice?
Reply By: a convict - Sunday, Nov 15, 2009 at 17:10
Question...?
Do you have any other "Bluetooth" equipped devices in the vehicle ?
AnswerID: 391303
Reply By: Hoogz - Sunday, Nov 15, 2009 at 17:41
No, the Nokia E71 is the only bluetooth system in the car. When I set it up to pair with the hilux bluetooth it works fine initially. But if I turn the car off and back on, or get out and back in, the phone automatically re-pairs itself, then instantly disconnects again... does it everytime, even if I go back and try to manually reconnect. The only way to re-pair it with the bluetooth is to delete the phone from the system and start again from scratch.
I have read this is a common problem but have heard no solutions as yet...
AnswerID: 391305
Reply By: Curry Lamb - Sunday, Nov 15, 2009 at 19:37
Toyota have currently got some problems with the head units which control bluetooth connectivity in hiluxs.Talk to your dealer as they may have to replace to rectify problem.
AnswerID: 391315
Follow Up By: time waster - Sunday, Nov 15, 2009 at 20:32
I had a 6110 and had no troubles, I broke the phone and bought the next model and did the same as you, then tried my wifes lg and no probs so took it back and they tried a software update on the phone and still did not work, then they gave me another 6110 and worked fine so it may be the phone.
FollowupID: 659186
Reply By: Stu-k - Sunday, Nov 15, 2009 at 21:59
It will be your phone for sure check Nokia site for software update
AnswerID: 391338
Reply By: Member - Graham H (QLD) - Sunday, Nov 15, 2009 at 22:07
Could I suggest you take your phone to a Nokia service centre (not the dealer)
I had probs witha 6120 and flshed it but it didnt fix it so took it to a service centre where they told me they can reflash it in a way that a user cant.
Sounds good but didnt fix it It just shuts down without turning off and wont revive unless I take the battery out.
AnswerID: 391340
Reply By: Hoogz - Sunday, Nov 15, 2009 at 22:29
Thanks for the advice :-)
Seems to be a common problem with my phone... Will try with the wifes phone when she gets back from brisvegas... that should determine whether it's the phone or car that has problems
AnswerID: 391341
Follow Up By: Stu-k - Sunday, Nov 15, 2009 at 22:36
There is a few Nokias with probs and the iclone is not to flash either, not to mention the handsfree in the lux.
This may help you ou also http://www.newhilux.net/phpbb/
FollowupID: 659202
Reply By: janineandy - Monday, Nov 16, 2009 at 01:07
Hi Hoogz,
I have a Hilux SR5 also and after some initial issues (senior moments) I have been successful in pairing a motorola mobile and now my blackberry, so perhaps it is the phone.....
AnswerID: 391352
Reply By: Member - Tour Boy ( Bundy QLD) - Monday, Nov 16, 2009 at 15:12
2007 hilux, Nokia E51 bluetooth has worked perfectly since phone kit installed.
Dave
2015 Fortuner
Had 72 cruisers in my time
AnswerID: 391402
