Monday, Nov 16, 2009 at 14:32
Hi Josh
If it was 6 months later, I would say half your luck, but this time of the year it will be very, very hot. The way the temperatures have been here lately, it will be tipping 50 C out in
the desert.
Adelaide has tipped an all time record with 8 consecutive November days over 35 C (Most days very high 30's and a couple over 40) with Wednesday and Thursday forecasting 41 C.
For safety reasons make sure that you carry extra
water. Also be careful at night and do not go bare footed. It is that time of the year when snakes will be active at night, and the last thing you need is a snake bite a long way from anywhere.
You can get good
water from a solar
bore at Cooper
Hill Bore on the Connie Sue. To get you used to some very serious corrugations, you will have a good starter for about 40 kilometres, from Parallel No 2 Road to Mackenzie Breakaways. The Old Gunbarrel corrugations will top the charts.The track will branch from a single vehicle track to 4 tracks in sections, each as bad as the other.
Bore not working at
Camp Beadell, but a top place to
camp. There are some other good hand pumps on the Old Gunbarrel,
well signposted.
It is top country out there. When you get to Tjukayirla, ask Andrew for a mud map to check out
the caves that he has found. I have submitted a new Trek Note for these, but you will be on the road by the time they are put up on this site. We are back out there again next August, in the cooler weather.
Have a great and safe trip, drink plenty of
water to stop dehydration and make sure that your air conditioner is working 110%.
Image Could Not Be FoundImage Could Not Be FoundImage Could Not Be FoundImage Could Not Be FoundImage Could Not Be Found
391398
Follow Up By: Member - Josh J (NT) - Monday, Nov 16, 2009 at 14:39
Cheers Stephen,
Am
well prepared mate, taking 100ltrs
water,300ltrs
fuel and all required spares etc etc, have the Hf and EPIRB for last resort.
Heard that the
bore was busted at
camp Beadell (Buckets gone in pump), do you know if this was the case and if so what size are they..if i can i'll get some bits before i go and try and get her running.
Josh
659261
Follow Up By: Member - Stephen L (Clare SA) - Monday, Nov 16, 2009 at 15:08
Hi Josh,
The brass rod on the pup was broken, and the yellow tie downs were holding the rest of the
bore section in place. This was the only
bore that was not working, the rest were all working fine. From
camp Beadell, your last chance to top up is at
Geraldton Bore, before you head south on the Hunt. The
bore there was also working fine.
659270
Follow Up By: Member - Josh J (NT) - Monday, Nov 16, 2009 at 15:17
Thanks Stephen,
Bummer,
Would have been great to track down some bits and get her up and running..if anyone out there know's if anything is available some where or has any dimensions for what is required...please let me know, could always chuck the lathe up on the roof rack i suppose......!!!
Josh
659272
