Trailer Spare Wheel Carrier
Submitted: Monday, Nov 16, 2009 at 14:25
Mandrake's Solar Power
Question time again ...
I am trying to free up some space to mount a tool box on the Tardis's A frame - Currently the spare lies flat on it ..
If I put one of these
Wheel Carrier bolted on the opposite side to the Jockey wheel on the A frame am I endangering life and limb and being illegal or are these things pretty safe to use ?
Any info is good info
Rgds
Mandrake
Reply By: Member - Graham H (QLD) - Monday, Nov 16, 2009 at 14:35
A bit low unless you have small
wheels.
Jayco have one which is a bit higher and Camec sell ones which are high enough that a 15 in wheel would not be below the rail of the A frame.
A boat trailer place would also sell one which is normally fixed to the post that the boat winch is on Have seen one of these on the A frame of a Coromal poptop
391399
Reply By: Member - steve. B... (NSW) - Monday, Nov 16, 2009 at 14:39
Hi Mandrake. Have a look at the Tvan set up. They have overcome the problem by putting a bracket at 45 degree angle over the
fuel carrier/ gas bottles. You undo a screw in the centre of the spare and slide the spare down to the A frame. Stand the wheel up and roll it forward to the ground. Then in reverse to reload the Flat spare. If it is too heavy, you roll it onto a block and then up onto the A frame. lay it down and slide it back up and fix in place. It's not hard work for a 73 year youngster like me. It will give you room for a tool box. Cheers Steve. B...
391400
Reply By: Member - Murray R (VIC) - Monday, Nov 16, 2009 at 20:59
Mandrake
If you can mount the spare underneath I have a wind up tyre coupling off an old ute that you can have, just needs winding rod [not hard to make]. You could mount it at the rear of the pod and would possiblly help balance the trailor when tool box is fitted. MM me if you want it.
Murray
391446
Follow Up By: Mandrake's Solar Power- Monday, Nov 16, 2009 at 21:12
Murray ,
Thanks for the offer but thats where I moved the wheel from and put it on the drawbar .. There's provision under the rear for it but it didnt come with the chain lifter doody and I couldn't hold the wheel up to do up the holding bolt !! So I had it moved ..
I think what I should do is weld a good steel box on the drawbar and then mount the wheel upright against the front face of the box ..
I'm gunna go see a welder friend and see what he can do
Mandrake
659324
Follow Up By: Member - Murray R (VIC) - Monday, Nov 16, 2009 at 21:38
Mandrake
Its the thing your calling the chain lifter doody that I have, you place tyre on ground put centre peice in wheel and wind up. You could weld it were the original fitting was.
Murray
659328
Follow Up By: Mandrake's Solar Power- Monday, Nov 16, 2009 at 22:09
Cheers Murray - I might take up that offer - I'll send you a PM later on this week
or ring you -
Rgds
Steve
659332
