Breakaway Brake systems
Submitted: Tuesday, Nov 17, 2009 at 16:27
Member - Bushpig
Hi all
While investigating my caravan I came upon this bit of news.
All
vehiclesregistered in NSW towing a van with breakaway brakes must have a warning light in the vehicle to advise the driver if the van brake battery is failing. Remote monitors are available but how many caravanners would have this monitor. Most new vans are already registered when you pick them up and the caravan yard gets the van registered without using a vehicle with the warning monitor because they are not going to be the normal towing vehicle.
For a monitor to be fitted you would need a van plug with an extra pin to pass the information to the driver, so all vans with breakaway brakes should have a twelve pin plug or an Anderson plug to allow one of the seven pins on a normal plug to be used.
When a caravan is over two tonne it must be inspected the first time at a heavy vehicle inspection station where this rule applies but after that it can be check at a normal vehicle rego checking station which uses another set of rules.
Does this rule apply to Qld? How can I check to see if my Tekonsha breakaway unit is powered after a breakaway?
Cheers Jack
Reply By: Member - Graham H (QLD) - Wednesday, Nov 18, 2009 at 00:19
I would also be interested to know as I have a WA registered van which will be changed to QLD at next reg.
I have a Breaksafe 5000 unit with a Prodigy controller.
The 5000 can have a remote monitor installed Part no 5000RM
One way to check is hook up then pull the pin on the A frame
Brakes should be locked on.
When I did it I couldnt move the van an inch.
391571
Follow Up By: Lex M (Brisbane) - Wednesday, Nov 18, 2009 at 01:00
Been researching this for a while now.
Only seems to apply to NSW and ACT
Some more information here
http://www.rvelectronics.com.au/page.asp?parentid=3&parent2id=8
scroll down to remote battery monitor.
Says "AS REQUIRED BY LAW FOR TRAILERS REGISTERED IN NSW AND ACT"
and gives a link to a RTA bulletin.
Haven't found any mention of it in any QLD regs (where I am).
659464
Follow Up By: Member - Graham H (QLD) - Wednesday, Nov 18, 2009 at 11:39
I go onto the Qld RTA site and they are not required as yet in Qld.
Went thru that thread also and while there is some good info there are the usual smart types who know better than the manufacturers.
659513
