12 Volt Guru's
Submitted: Thursday, Nov 19, 2009 at 11:09
ThreadID: 73844 Views:3819 Replies:3 FollowUps:3
Related Pages
Hi Guys,
In the process of building a new tandem trailer for camping and was thinking of putting a toolbox on the front drawer bar and putting batteries etc in it so I can charge them while driving. I know i need to have large dia wire from the car to the batteries for charging but do I need to run large cables from the box to my fridge and other things?
The fridge sits in our tent and the supplied cable won't reach the trailer so I need an extension. Does this extension wire need to be similar to the charge cables.?
Bruce
Reply By: Member - Tour Boy ( Bundy QLD) - Thursday, Nov 19, 2009 at 13:08
If you don't want it to have a voltage drop or have the fridge cut out you should run at least 5mm wire and don't forget to fuse it seperately.
Dave
Dave
2015 Fortuner
Had 72 cruisers in my time
AnswerID: 391752
Follow Up By: Bruce n Sal - Thursday, Nov 19, 2009 at 13:37
Thanks Dave,
Will make sure i fuse the extension wire didn't think of that.
Bruce
FollowupID: 659691
Follow Up By: Bruce n Sal - Thursday, Nov 19, 2009 at 13:38
Thanks Dave,
Bruce
FollowupID: 659692
Reply By: Robin Miller - Thursday, Nov 19, 2009 at 14:40
Hi Bruce
You don't need thick cables (8mm sq) to go from battery to fridge as well because fridge only draws a few amps (Typical 3amps).
My Waeco using its high speed mode is still only 6amps.
Up to half a volt total drop is ok , if extension is 8m or less then standard size
4mm sq copper cable is fine and will drop only 1/4 volt thru the entire 16m loop of cable.
If your running this extension from an existing fused socket then I would not use a fuse in it as fuses can cause more voltage drop than some cables.
AnswerID: 391765
Follow Up By: Bruce n Sal - Thursday, Nov 19, 2009 at 15:18
Ok Thanks Robin,
Also thanks for the recommendation of Talbotville, we went there over the long weekend and it was fantastic.
Kids loved playing in the river and the Dad's loved driving in them.
But after that trip we definitely need a bigger trailer & a snorkel & UHF, that trip is going to cost me alot of $$$$ :)
Thanks again.
Bruce
FollowupID: 659700
Reply By: Maîneÿ . . .- Thursday, Nov 19, 2009 at 18:04
You will probably have an Anderson plug connection at the tow bar/rear bumper area, I would use the thickest cable that will fit the Anderson plug to go from the Cranking battery via the isolator to the rear storage batteries.
The (FUSED) cable from the rear batteries to the fridge in the tent, will be as you say an "extension cable" because it joins the existing fridge cable connector to the battery. Maybe replace the existing fridge cable connector with a smaller Anderson plug each end of the 'extension cable' so the fridge can be used closer to the battery without the extension cable, if required.
I would use much thicker cable than recommended above because I believe you will get some voltage drop at distance, I would look at some of the voltage loss graphs to see what length cable gives zero (or close to zero) Voltage drop in the distance you are using for the extension cable (plus the original cable)
Maîneÿ . . .
AnswerID: 391796
