Tekonsha or Red Arc?
Submitted: Thursday, Nov 19, 2009 at 17:34
ThreadID: 73857 Views:16088 Replies:4 FollowUps:15
Hi all
I have recently purchased a caravan 17' road star, dual axle approx 1650kg. I want to fit a brake controller unit to my Prado, I was advised by the TJM dealership in Adelaide to fit the Red Arc unit, then I started reading a forum on this web site indicating that the Tekonsha Prodigy is the better unit.
My only concern is the room between my knee caps & the unit if it is mounted in the normal under steering wheel position. The thing I like about the Red Arc unit is the remote head, it looks like a dial on your dash, nothing to bust your knees against.
Your opinions would be appreciated.
Troutlips
Reply By: Shaker - Thursday, Nov 19, 2009 at 18:52
I have the Redarc, it is excellent. Had a Tekonsha Voyager before, far prefer the Redarc.
AnswerID: 391807
Follow Up By: Member - Peter R (QLD) - Thursday, Nov 19, 2009 at 20:19
I have had good experience with the Prodigy.
Fitted it in my Prado, in the Ashtray and it looks like this
No nothing of the Redarc, but the Prodigy has my vote
Pedro
FollowupID: 659740
Reply By: Member - Peter R (QLD) - Thursday, Nov 19, 2009 at 20:21
Know what I mean
Pedro
AnswerID: 391816
Follow Up By: Troutlips - Saturday, Nov 21, 2009 at 15:45
Hi Pedro
Was there any other equipment needed to fit your Prodigy?
Like a wiring loom that connects into to the Prado wiring loom/plug.
Can you text your phone number to me so I can talk tp you about your unit?
My mob is 0417 272 576
Troutlips
FollowupID: 659981
Follow Up By: Member - Peter R (QLD) - Saturday, Nov 21, 2009 at 15:55
Text message sent
Pedro
FollowupID: 659982
Reply By: Member - A J- Thursday, Nov 19, 2009 at 22:42
Troutlips - I just had a redarc fitted to my Prado using remote head - just a light and dial in the two spare switches near the door.
Recommended by the auto electrician who advised that he fitted more of them and other brands & would fit a prodigy if I really wanted one.
Easy to operate does the job as required.
A J
AnswerID: 391834
Reply By: Nomadic Navara - Friday, Nov 20, 2009 at 00:02
There is a little info on brake controllers at Hardings Technical Site This explains the advantages of pendulum brake controllers. The RedArc controller does not have a pendulum in it. For that reason I would suggest you keep away from it. Having a controller without a pendulum is a bit like only using the one weight of your foot every time you brake your vehicle. If you don't drive your tug that way then don't fit a non pendulum controller.
AnswerID: 391838
Follow Up By: Boobook2 - Friday, Nov 20, 2009 at 06:24
Totally agree.
I initially had a Redarc controller fitted and was told by the auto elec that it is a pendulum type - which it isn't. The amount of braking force for the trailer depends only on the setting of the knob. It gradually increases the force to that which you set every time you set the brakes.
Problem is that every time you put the brakes on it is different, different road conditions, wet, dry, dirt, etc; different braking, hard, gentle etc etc and different traffic conditions, open road, city etc etc.
With the Redarc you are constantly changing the knob and predicting what braking will be required next!!!!!
I gave up on it and think it is dangerous.
Got a Prodegy P3. Now I just put the brakes on and the P3 looks at how hard I am braking and applies that to the van.
Simpler, more accurate and much safer.
FollowupID: 659771
Follow Up By: Troutlips - Saturday, Nov 21, 2009 at 15:39
Hello all
Thanks for your information, initially I was looking at the Red Arc because of the remote head, looking at the way Pedro has fitted his Prodigy in the ash tray this will solve my problem of having the controller at my knees.
My decision now is, do i get the prodigy or the prodigy P3?
They both seem to be more than capable controllers & exactly the same dimensions.
Thanks Trout
FollowupID: 659978
Follow Up By: Member -Dodger - Saturday, Nov 21, 2009 at 17:20
Prodigy P3
Cheers Dodg.
FollowupID: 659995
Follow Up By: Shaker - Saturday, Nov 21, 2009 at 17:30
I have never adjusted my Redarc after the initial set up.
FollowupID: 659998
Follow Up By: Troutlips - Saturday, Nov 21, 2009 at 22:45
Hi AJ
Mate, thanks for your help, I really want to go for the pendulum type controller due to the weight of what I will be towing. This is not to say the Red Arc is perfect for your combo, you are the only one who has to be convinced of what you have. If it works do not change it, even better, if it looks great you are on a winner.
All the best & thanks.
Trout
FollowupID: 660037
Follow Up By: Shaz & Col - Sunday, Nov 22, 2009 at 09:30
I fit brake controllers for a living and over the past 3 months I have removed 1 p3 and 1 redarc and swapped them both over for prodigy`s , both customers could not be happier.
Redarc is a great looking unit but I dont believe it is suitable for heavy loads going by feed back from my customers.
The P3 did not always recognise a van was connected and continually gave error codes that did not exist, I have lost count of the amount of Prodigy`s I have fitted and never had a complaint.
Col.
FollowupID: 660068
Follow Up By: Troutlips - Friday, Nov 27, 2009 at 07:47
Hi Col
(Sorry been away)
I am now faced with this decision, Prodigy or Prodigy P3?"
Other than some cosmetic differences I can not find too many differences.
The Tekonsha website has some excellent video clips with these units.
Do you think the P3 you removed was just one lemon or poor compatiblity or is there something more sinister I should be worried about?
I am leaning towards the P3 only because it seems to be the top of their range of the Prodigy's.
Trout
FollowupID: 660817
Follow Up By: Member - Garth J (NSW) - Friday, Nov 27, 2009 at 16:44
Gents,
The newer model controllers are fitted with accelerometers (electronic) as oppossed to pendulums which are mechanical devices.
Hence the set and forget with the prodigy and the P3.
Some brake controllers are not compatible with the braking systems used on vans.
Point in case being the electro-hydraulic unit on my Kimberley Karavan. When used with a Prodigy controller error codes were produced. I had to revert to the older Tekonsha Voyager.
That particular incompatability issue has now been rectified by Hydrostar the manufacturer of the electro-hydraulic unit.
So if compatability is not an issue then the Tekonsha Prodigy or P3 are the way to go.
Garth
FollowupID: 660900
Follow Up By: Shaz & Col - Saturday, Nov 28, 2009 at 09:47
Trout,
the faulty P3 could have been bad luck but until I have 100% confidence in products I sell and fit I will stick with the Prodigy, to me it`s not worth having to return to the customer to rework my job or if the customer is interstate it can create unwanted issues, I think the performance of both controllers is identical regardless of what you tow, I have a Prodigy in my cruiser , and I have had hayman reese, redarc, energiser, accutrak,voyager and primus controllers in my car at different stages to test the operation of these units for customers and I still rate the Prodigy no 1.
Col
FollowupID: 661004
Follow Up By: Nomadic Navara - Saturday, Nov 28, 2009 at 13:12
If your Prodigy is crook go for warranty. Tekonsha are good with warranty. They will still replace the Voyagers if you still have one from the bad batch that came out earlier this decade.
FollowupID: 661017
Follow Up By: Troutlips - Tuesday, Dec 01, 2009 at 12:25
Hello all
Your assistance for my orginal question has helped me narrow my search down to both the Tekonsha Prodigy units.
Both the Prodigy & Prodigy P3 are proportional controllers.
The Prodigy uses "new motion sensor technology" (this must be the pendulum?)
I am still perplexed to identify the difference between these 2 units, other than looks.
This link to the Tekonsha web site details everything on all their units.
http://www.tekonsha.com/product/accessory.asp?cat=1435&titulo=Proportional Controllers
One bad experience by Col with 1 P3 (compatibility issue) & nothing bad to say about the Prodigy by anyone.
Can anyone tell me the difference between the two units?
Trout
FollowupID: 661426
Follow Up By: Troutlips - Sunday, Dec 13, 2009 at 00:39
Well, I have purchased the P3 model & intend on fitting it in the ash tray, it looks a bloody great fit.
Will keep you posted how it operates, I expect no problems.
Over for now Troutlips.
FollowupID: 663206
