tyre size question
Submitted: Thursday, Nov 19, 2009 at 18:15
ThreadID: 73859 Views:3079 Replies:3 FollowUps:2
Related Pages
Hi All
i have 80 L/C with ARB standard 2" lift, currently have 275/70r16 would 285/75/r16 fit ok? also i find that more tyre choice BFG m/t are same price as a/t i thought would be more expensive
cheers steve
Reply By: Tony MD - Thursday, Nov 19, 2009 at 18:34
Steve, I have a similar 80 series running BFG 285/75/16 mud terrains (older type & not the new KM2). No problems. As mine is a standard 1HZ, long highway hills are a slower but the extra ground clearance and grip is great. I only use this set for high country use, Outback etc still use the BFG 265/75/16 ATs
Look also at the Maxxis Big Horns.
The tyre size is 285 (width) 75 is height - expressed as % of width & 16 is the rim size.Image Could Not Be Found
AnswerID: 391802
Follow Up By: steve21 - Saturday, Nov 21, 2009 at 14:29
hi all, thanks replies i forgot to mention also, does the bigger "spare" tyre fit underneath ok?
thanks again
FollowupID: 659976
Follow Up By: Member - Ian H (NSW) - Saturday, Nov 21, 2009 at 16:15
Hi Steve21,
I have 265/75x16 BFG a/t tyres on the road and a 235/85x16 BFG a/t spare. They have the same rolling circumference and are all on 7" rims.
The spare in tucked up above the line between the diff and towbar and never cops and grief. My 80 series has a 2.5 in lift.
Just another way of doing it.
Ian
FollowupID: 659984
Reply By: Member - Robert G (WA) - Thursday, Nov 19, 2009 at 18:49
Steve, I ran 285x75x16 on my old 80 with 2" lift with no issues. As pointed out, it will sap some engine power.
AnswerID: 391803
Reply By: Member - Graham H (QLD) - Thursday, Nov 19, 2009 at 21:31
Speedo will be out a bit check it here
http://www.rims-n-tires.com/rt_specs.jsp
AnswerID: 391823
