Caravan annexe or shade sail sides?
Submitted: Thursday, Nov 19, 2009 at 19:38
ThreadID: 73863 Views:17088 Replies:11 FollowUps:2
Hi there I have a question for you all. I am travelling around Aust next year with my wife and four year old boy in a 22ft caravan, just wondering is it a waste of money getting an annexe made or should i just get a shade sail set made up instead.
Reply By: Member - Peter R (QLD) - Thursday, Nov 19, 2009 at 20:04
If you are going to stay for long periods , and the climate during that time is cold/wet I would go for full annexe.
However, if you are on a short time frame I would have a shade CLOTH set up .
It is probably important to have the side made so that you can have it fitted to each side depending on the sun in each place.
This is done by having a plastic gizmo that fits into eyelet on awning (middle one) on each side of shade cloth ,
Most awnings have three eyelets but for a shade cloth set up the middle one is all that is needed.
It is also advisable to have the top section made of vinyl to keep out western sun.
the long piece which will fit into roll out awning does not need any vinyl but make sure that it has eyelets to secure it, and this also goes for the shade cloth on side.
If you have a full annexe made ensure that the template for it is used to make the side and front. Much cheaper and fits beter.
Pedro
AnswerID: 391810
Reply By: John and Lynne - Thursday, Nov 19, 2009 at 20:15
An annexe gives you an extra 'room' to keep gear or provide a child's safe play area etc. However it takes time to set up and is quite a bit of extra weight to cart around. On our travels we have seen that annexes only get put up when people are staying for an extended time in one spot.
We have never missed having one but there are only two of us. We had a good quality shade sail made to slide into the awning roller. This gives extra shade, rain protection and privacy when needed and is easy to put up and to stow away. We also have a shade sail made for the other side of the van with a sail track installed to cover most of the van and shade the fridge. This has been excellent value in hot conditions up north.
So your decision will really depend on how long you think you will stay in each place to see how much use you would get out of a full annex. If you decide later to get an annexe you could probably get one along the way in any decent sized town. This might be better than carting around something you don't use. Good luck. Lynne and John
AnswerID: 391814
Reply By: Faulic_McVitte - Thursday, Nov 19, 2009 at 20:20
90% shade cloth. One for the awning and one for the off side of the van.
Get an end made that will fit both ends for wind brake. Quick and easy to put up and light and take little space.
Julie Dunkley at CampShades does a fantastic job reasonable price and great service.
Annexe takes up a heap of space, costs a heap and weighs heaps and pain to put up take down and fold. Many never use the annexe.
AnswerID: 391815
Reply By:- Thursday, Nov 19, 2009 at 20:28
Thanks for the quick responses. I am going to do a shade sail for the fridge side of the van for sure, they definitely help the fridge.
The other side is the hard part, I guess i am having trouble deciding as i am already carring extra for my young fella. We are looking at this stage of going for about a year maybe longer if we can afford to keep going, but, i am not sure if the benefits of having a full annexe out weighs the problem of taking it with you and maybe putting it up. The only things i usually keep outside are the engel fridge and some toys, so i dont think theft would be to high on those. The fridge is chained to the wheels.
If leaning towards the shade sails would you get them for both ends or just one end and the roll out side?
AnswerID: 391817
Follow Up By: Member - Graham H (QLD) - Thursday, Nov 19, 2009 at 20:57
After 10 months on the roadI would say both have their advantages and disadvantages.
Pros An Annexe is good if its wet gives you a bit of space and stops "cabin fever"
Also provides cover for stuff like the Engel which I would chain to a chassis rail rather than a wheel which can also be removed if they are keen enough.
We have a large heavy washer welded to the end of a crossrail and chain fridge to that. Also fold chain over lid and lock as meat is expensive out there as well and has been pinched before.
A Canvas one is not too heavy but tends to get grubby in the red dust areas you will encounter.
We carried ours in the back of the car.
Have a Vinyl one for the new van which I intend selling unused.
A shade sail is great Get a heavy duty one made up for the length of the awning and ONE end and fit it depending on wind direction.
We also have a plastic mesh floor which lets the sand and mud through and helps keep the van clean.
Have found in a lot of parks there may not be room for a sail on the off side.
We were going to get one for putting the car under but after talking to friends who had done the big trip decided not to.
Have seen them over fridges but pulled down close to the wall which while shading the fridge prevents the air from getting away.
We have had no probs with fridges in hot temps anywhere even a week of mid 30's in Darwin.
at present in Kalgoorlie and Hyden where its been mid 30's and icecream is still frozen and ice cubes froze in 2 hours in the freezer.
Both places van sitting in sun with no shade
Cons Setting up takes 1/2 an hour and taking it down wet is a pain.
We only put it up if staying more than 4 days and the weather is bad.
When and if you buy something get it made to fit with the awning legs attached to the van.
I have heard insurance companies are going to refuse claims if they are pulled down to the ground.
After seeing 4 awnings folded over vans in wind at Geraldton I dont blame them.
Our 10 months has cost in excess of $35,000 so far.
FollowupID: 659751
Follow Up By: Russ n Sue - Friday, Nov 20, 2009 at 15:15
G'day
We have a sort of combination affair. We got all-mesh sides for the annex walls, plus one end wall that is reversible. With this we are fully enclosed, but in mesh, which breathes reasonably well. In addition, we had a shadecloth long wall that we put up along with the mesh wall for added sun protection.
The shadecloth wall is long enough to be pegged straight down to the ground but most of the time we have it out at an angle. This keeps the Sun out but lets breeze in. If it rains, about 80% of the water runs down the shadecloth and the remainder drops vertically - thus not coming in through the mesh.
To achieve this we purchased a shadecloth drop that has the rope sewn in. Then we had eyelets and reinforcing fitted about every metre. We "pin" the shadecloth to the roller of the annex using tent poles with the spikes coming through the eyelets into holes I drilled in the roller. To tension it the tent poles are stayed with rope. If you want a picture, PM me.
We also have a shadecloth on the 'fridge side of the van and it makes a HUGE difference.
Russ.
FollowupID: 659850
Reply By: Roughit Instyle - Thursday, Nov 19, 2009 at 20:50
We have a 23 ft van and purchased sun shades for our Birdsville Races trip - they made a huge difference. We have the long shade for the awning roller and one end shade only - you only need one to give a feeling of privacy and deflect the glare of the sun. We are lucky that our fridge is on the awning side so no need for a shelter on the other side of the van.
We purchased our shades from Sun Buster Solar Shades - check out their website, no affiliation, just very happy with their product and prompt service.
Cheers - Ngaire
AnswerID: 391821
Reply By: xcamper - Thursday, Nov 19, 2009 at 21:02
We only have a 14ft van, with a 10ft roll out awning, we have a full (10ft) annexe, and a 10 ft sunshade , also a screen that fits either end.
We use the full annexe for long stopovers,and the sun shade for short stops, we find this is ideal for us, but being small (short length) it does not weigh much,and folds up easily.
pete
AnswerID: 391822
Reply By: Member - DAZA (QLD) - Thursday, Nov 19, 2009 at 21:45
G/Day
We have the Roll Out Awning with Deflappers either end, and Annex Walls that fit both ends and the slide on front wall that attaches to the Roll Out Awning, it has large windows at both ends and in the front with the entrance opposite the caravan door, all windows and doors have heavy duty Sand Fly Screens, and there is also a Skirt that fits around the bottom of the Van that acts as a wind break and also stops Critters crawling in, it was made up here in QLD by the Awning Man, it cost just over $2500 we also have a Mesh Screen that slides onto the Roll Out if we are just staying a couple of days, both items come in handy for different applications.
AnswerID: 391825
Reply By: Wilk0 - Friday, Nov 20, 2009 at 08:53
Hi ,
I use a "Pop up pergola" that market stalls use. They set up in a flash and keep a fair amount of sun off.
I've got a full annex on my ct but if I'm stopping the night, I just pop it up and crack a tinny.
Cheers Wilko
AnswerID: 391859
Reply By: Member - Old Girl (QLD) - Friday, Nov 20, 2009 at 16:50
I have the annex, wouldnt be with out it. Like others dont use it for short stays. If you get one made up have the door on the long side. im glad ours is on the side as I can leave the legs attached to the van. Have large windows with dark blue screen. They are not that hard to put up I do it by my self.
Sharon
AnswerID: 391927
Reply By:- Friday, Nov 20, 2009 at 19:38
Thanks for the help, now to speak with the upholsterer. cheers
AnswerID: 391942
Reply By: Member - Carl and Pamela - Tuesday, Dec 01, 2009 at 17:29
Image Could Not Be FoundImage Could Not Be FoundImage Could Not Be FoundImage Could Not Be Found
I hope the 4 pictures above give you some ideas. I used to make shade screens for caravans but have now retired. All the advice I have read in replies to your question are good.
AnswerID: 393396
