Retensioning a Dometic A & E rollout awning.
Submitted: Friday, Nov 20, 2009 at 20:39
ThreadID: 73884 Views:18715 Replies:4 FollowUps:7
I think I have accidentally released the tension on one end of my rollout awning.
Does anyone have any ideas how to fix it if I have.
If anyone can post photo's or instructions from a manual it would be appreciated.
Cruiser
Reply By: xcamper - Friday, Nov 20, 2009 at 22:02
If you google the A&E awning ,you will find the answers to you problem.
I hope you can fix whatever is wrong.
pete
AnswerID: 391952
Follow Up By: xcamper - Saturday, Nov 21, 2009 at 10:42
Hi.
there are springs either end,but be very careful, as Graham points out ,they can cause major injury if it gets out of control.
If you Google the Dometic A&E web site you can get pretty good instructions, and very good photos.
Be very careful!!!!!
pete
FollowupID: 659951
Reply By: Member - Graham H (QLD) - Saturday, Nov 21, 2009 at 01:03
I did that and I put a pair of vice grips on the shaft and turned it about 12 revs and then fitted the end back in and it works fine.
Dont let it slip or it will take your fingers off.
The direction to turn it is on the end of the bracket.
AnswerID: 391961
Follow Up By: Cruiser .- Saturday, Nov 21, 2009 at 10:00
Graham,
Can you tell me if there is a spring in each end of the barrel of the awning.
I seem to have released the tension on the end that doesn't have the lever that you use for roll in/roll out.
I have had a look and there is only one end that has directions for up/down and that is the end that has the lever in it.
At the moment we have the annexe fully setup and in a month when we move I will find out if I have in fact released the tension.
If I have released the tension, I am assuming that I can still roll the awning up.
Cruiser
FollowupID: 659947
Follow Up By: Member - Graham H (QLD) - Saturday, Nov 21, 2009 at 12:18
Yes there is.
You roll both ends towards the van over the top of the roller.
No you wont be able to roll it up if you have released tension At least I couldnt.
I pulled the end off the arm as I broke the cast piece that hold the sliding piece and when I did it unraveled bigtime.
To get it itght i put a small pair of vice grips on the shaft and over the pin through it and wound it 12 times over the top towards the van.
You need someone holding the arm and when you have it tight put the end piece into the arm and put the bolt in
DO NOT LET THE GRIPS GO TILL THIS IS DONE.
I could not find any other way of doing it Tried a screwdiver but then you cant turn the end piece around to fit it in the arm as it will then un ravel again.
Look at the pics on the website as it has the springs and you will get the idea of how they are wound.
You have to tighten them so you wind away from you at the top.
What did you do to make you think it unwound.
I broke both my cast pieces and at $52 each they are not cheap.
The other end is Ok as the lever keeps it tensioned and I took that one off no trouble and it went back Ok.
So I thought the other end would be the same Ha ha it wasnt.
FollowupID: 659965
Follow Up By: Member - Graham H (QLD) - Saturday, Nov 21, 2009 at 12:26
On reading your reply it seems you are misconstruing the up and down bit
It is cast into the end of the arm that comes out from the wall and its a cast
piece that the roller shafts sit in It has a small bolt on the underside which
holds it in.
It has up and down and two arrows on each one.
U put the grips between it and the roller end and make sure they are over the
pin which sticks through the shaft or it will just spin again.
Not much room but i have a small pair the just go in.
Then undo the bolt ,pull the end out while mum holds the rail for you and
wind it up as in my post above. DONT LET GO. It is the equivilent of an
airplane propellor and as deadly.
FollowupID: 659966
Reply By: Patrol GU IV - Saturday, Nov 21, 2009 at 11:49
Hi Cruiser,
What did you do to make you think you may have released the tension ?
Neil
AnswerID: 391975
Follow Up By: Cruiser .- Saturday, Nov 21, 2009 at 13:35
Neil,
At each end arm there is a bolt that goes through the arm and the end of the barrel.
I was replacing that bolt with an eye bolt and when I took it out I heard a spring unwind, which I assume is the spring that gives that end of the barrel its tension.
This is the end that is at front of the van as opposed to the other end which has the lever for Up/Down.
Cruiser
FollowupID: 659972
Reply By: Member - Graham H (QLD) - Sunday, Nov 22, 2009 at 00:04
Which bolt did u take out and why.
There is only one bolt and it holds the cap in the angled arm.
If you take that cap out and not hold it with some sort of tool it will wizz around in circles and unwind the spring.
The only other thing there is a pin thru the rod that goes thru the roller
If its not broke dont fix it is a good thought especially if you dont understand quite what you are doing.
What I have told you will put an unadulterated one back to original
AnswerID: 392111
Follow Up By: Cruiser .- Sunday, Nov 22, 2009 at 08:38
Graham,
I was replacing the bolt you describe with an eye bolt.
Yes I was unaware that it would release the tension, but from your replies have been helpful and I will have a go at retensioning it during the week.
The local caravan repairer has told me there is a trick to it and if I get stuck they will come out and do it for me.
I guess you live and learn.
Thanks for the help.
Cruiser
FollowupID: 660057
Follow Up By: Member - Graham H (QLD) - Sunday, Nov 22, 2009 at 11:48
If you only removed the bolt that holds the cast piece in the movable arm it shouldnt have released the tension.
It would only do so if you pulled the cast piece out of the arm.
If you pulled the pin through the rod that would release it but it would be really hard to move as its under tension all the time.
Would be interested to know the "trick"the repairer has.
The one I rang didnt have a clue even as to which way to tighten it.
FollowupID: 660086
