leaving the fridge on when at home
Hi all ,Just wondering if most people leave there fridge on when parked at home is it better to keep them running or doesn't it make any difference cost of a bit of power is not worrying me if it's better to keep it going it's a dometic 3 way 184lt Cheers and thanks in advance Sue
Reply By: Member. Rob M (QLD) - Saturday, Nov 21, 2009 at 14:59
Hi Sue,
Don't know whether it is right or wrong, but we leave our 150ltr dometic run all the time when parked at home.
Rob
Rob M
AnswerID: 391990
Follow Up By: dry lake racer - Sunday, Nov 22, 2009 at 21:20
the fluid is amonia & water mixed it is best to leave on so they remain mixed & do not settle out, if you find the fridge does not run cold after being off for a long time, remove fridge turn upside down & put in a trailer & drive on a bumpy road for a few mins, then turn upright & switch on, ONLY DO THIS WITH A THREE WAY FRIDGE, NOT A NORMALL COMPRESSOR FRIDGE.
Martin
FollowupID: 660133
Reply By: Member - Rod N (QLD) - Saturday, Nov 21, 2009 at 16:32
I don't think it matters. If we are home for a "long" time we turn ours off and turn it back on a few days before a trip. Always cools down in those couple of days. If you leave it running at home, it is no different to leaving it running while on an extended trip.
AnswerID: 392009
Reply By: Member - Duncs - Saturday, Nov 21, 2009 at 16:51
I was advised by an Engle authorised repairer, to make sure the fridge was run regularly. A couple of days a month.
Mine runs nearly all the time. Got to keep the beer somewhere.
Duncs
AnswerID: 392013
Reply By: Member -Dodger - Saturday, Nov 21, 2009 at 17:11
As Said above,
When at home for any length of time we clean ours out thoroughly and then let it rest turned off with the door on slightly opened for air flow (ours has this facility built into the latch).
Then when we want to head out again we turn it on at least 24hrs before we again load it up with food etc.
We also if at home over xmas use this fridge as a back up for those extras we want to keep cool or frozen.
Cheers Dodg.
AnswerID: 392029
Reply By: kiwicol - Saturday, Nov 21, 2009 at 17:25
Hi, i have an explorer, and have had it for about 10 yrs ands its never been turned off. When at home we fill it with bottles of water fridge and freezer, and turn both thermostats to the lowest setting. A fridge doesnt work efficiently unless it has something in it.
Col
AnswerID: 392036
Reply By: Maîneÿ . . .- Saturday, Nov 21, 2009 at 18:25
I would have thought with a 3 way fridge it would be better for the fridge to turned 'off' when not used for prolonged periods.
I only suggest this because the 3 way works on heating the fluid.
I would think the continual heating of this fluid would cause it to evaporate over time and the heat would deteriate the metal involved in some way.
Sounds logical, but then it does not have to be logical to be correct I spose
What do the varioius 3 way fridge manufactures actually reomend ??
Maîneÿ . . .
AnswerID: 392049
Follow Up By: dbish - Saturday, Nov 21, 2009 at 22:56
Not hard to workout 150 watts X howmany hours it runs for willgive you total watts mulyiply cents/kwh eg 150w X 24Hrs 3600wats =3.6units X .18c unit= .648c X 30 days= $20.40/ Month. Most houshold compressor friges wont cost that to run.
FollowupID: 660039
Follow Up By: Richard Kovac - Sunday, Nov 22, 2009 at 04:16
Mainey
I'm no expet... But if the fluid id enclosed it would have no where to evaporate to.
I must say I run my 3 way in the van all the time as I was told to (so I believe them????) the one in the CT I don't but if I have a problem with it, it's easy to remove and flip over.
Richard
FollowupID: 660051
Follow Up By: Maîneÿ . . .- Sunday, Nov 22, 2009 at 07:43
Richard,
You may be correct, but that then assumes if you heat fluid in a sealed container it will not evaporate, from memory my science teacher explained it differently, but I was never paying attention to what she said anyway :-)
Maîneÿ . . .
FollowupID: 660053
Follow Up By: Fab72 - Sunday, Nov 22, 2009 at 09:28
Mainey...there is some truth in your statement. If a container is sealed(assuming a 100% seal), there is no path for the vapour to escape. In fact, the vapour will condense on the cooler surface (usually the lid) and then "rain" back down into the melting pot, so to speak.
However...... and this is the clincher. If a liquid is heated under pressure, the boiling pont at which that liquid will boil and evapourate will increase significantly depending on the sealing capabilities of the pressurized vessel. Hence, it would be possible to heat water far beyond 100 degrees C without it actually boiling off. The danger is that there will come a time when the pressure in the vessel exceeds the safe working limits and Kaboom.
These principles work all the time in engine cooling systems which often operate above 100 degrees C. The "weak" point is the radiator cap. Designed in a way that it relieves the pressure before the hoses chuck a wobbly or worse still, the radiator core.
Cooling systems need this increased pressure to be able to work efficiently. Without a controlled pressurised system, most cars would require around 150 litres + of coolant to achieve the same efficiency as a 12 litre systems.
FollowupID: 660067
Follow Up By: Fab72 - Sunday, Nov 22, 2009 at 09:30
Whoops...Sorry response was meant to be for Richard, not Mainey.
FollowupID: 660069
Reply By: get outmore - Sunday, Nov 22, 2009 at 11:42
pretty sure my Engle instructions 9before i lost them) recomended running it all the time although i dont
AnswerID: 392168
