Sunday, Nov 22, 2009 at 20:41
The NSW (RTA) VSI 50 changes have nothing to do with going off road.
The RTA believe the press, that you buy a 4WD and it can do all those things in the adverts by the manufacturers.
The RTA main concern is safety.
The concerns are quite obvious.
1. Raised vehicle may be less stable in cornering.
2. That the raised height may cause issues in braking (see tyres later).
3. The raised height may cause vision issues.
We have all seen the 10" lift with no sway bars leaning over going around a bend. These are the 4WD's that non 4WD'er's remember. Same as the little old lady who only see's a big bullbar in her rear view mirror.
The second part with raised
suspension is.
1. If you hit a pedestrian the person is morel likely to go UNDER the vehicle if it is raised.
2. If you hit another car side on the bull bar may go through the window, missing the side intrusion protection and hitting occupants.
3. If you hit a standard car head on that the raised 4WD may go over the standard vehicles airbag points, or crumple zone. (This has happened where a raised 4WD (about 10") hit a car above the airbag pods, touching first part way along the bonnet. the driver had more serious injuries than expected if the bags had gone off.
Tyre....
The concern with tyres are the 35 or 37" muddies on a 10" lift truck.
The concerns are:
1. That children may get dragged under a vehicle if clothing gets caught on the tyre lugs.
2.
Wheels protruding outside the bodywork.
3. That breaking systems are designed for certain sized
wheels and tyres and steering and breaking may be affected.
The RTA don't care that you want to go off road.
SUSPENSION. They do not understand that you and I may:
1. Improve your
suspension to cater for carrying you
camping gear.
2. Improve your
suspension for towing purposed.
3. Improve your
suspension to prevent
suspension fade (shockers) for outback travel.
4. Improve your
suspension to stop vehicle roll when cornering
TYRES.
We change tyres for a multiple of reasons.
1. Change from road rated tyres to the stronger Light Truck tyres, this is for safety.
2. Tread pattern, Highway Terrain, All Terrain, Mud Terrain. This is your choice and for what you intend to do.
The reason why tyre sizes change is easy, to change from a road tyre to an LT often means a change of tyre size, this may only be a few mm, but in some cases this can be 12 to 25 mm.
Again the RTA DO NOT UNDERSTAND THIS....
That is why the
Suspension Survey is so important.
4WD Association Suspension Survey
It is important that even if you do not have raised
suspension or different sized tyres, that you fill this in.
This is being compiled and shared by all State 4WD Associations to fight the battle.
392231
Follow Up By: Member - Tony V (NSW) - Sunday, Nov 22, 2009 at 23:25
The one item that I missed was that heavy trucks have already been through this.
You will notice that most of the newer trucks are between 300mm and 450 mm off the road with the common rear protection bars to stop you going under the back but also the side ones or boxes on the trailers to reduce the possibility.
Truck under run laws this was introduced in September 2009
Woolworths version with under run protection.
660163
