Monday, Nov 23, 2009 at 13:52
Mainey,
I am (at the request of others) trying to stay away from 12v discussions, but I don't get your point. You often trot out this line about how appliances can draw directly from the solar regulator; but so what?
Don't get me wrong, I have the same regulator as you (20 amp one) and I do run my fridge from the regulator, but only because I am interested in measuring how the fridge is using and the Steca lets me measure that, but there is no other practical advantage is there?
In simple terms, on any given day the solar panel will output X amount of power. Similarly, on any given day your appliances will consume Y. Subtract power consumed (Y) from power produced (X) and the left over (or deficit) will go into or come from the battery. Does it matter if the power consumed is being drawn from the battery of directly (via the regulator) from the panel? Surely the equation remains the same?
I must be missing something here or is there a significant loss associated with putting energy into the battery that I am not accounting for in this equation? Not forgetting that if the solar panel can not provide enough power to run and appliance at any given time, then the deficit still gets drawn from the battery and the battery won't maintain full charge anyhow.
Matt.
660251
