is the site broken again
Submitted: Monday, Nov 23, 2009 at 07:57
Member No 1
went thru archives and got this wierd type
It's global warming. Hot air is less dense, therefore when you bring it down to to 21'C you get more than your 100% worth. I would have thought it was obvious. The global finacial meltdown is also adding to the problem ie more heat, so those percentages will need to be reviewed later this year. Click Image to EnlargeStill going there and doing that.Member: My Profile Send Message
Also been slow loading on accasions......
Reply By: Member No 1- Monday, Nov 23, 2009 at 08:06
now that is wierd
it shows some of the stuff I copied that is correct but not all of it
this is what it was
Image Could Not Be Found
392281
Follow Up By: Maîneÿ . . .- Monday, Nov 23, 2009 at 08:21
Do you think it could it be something to do with the electrons being defected, as in a modified sinewave inverter, due to the intense heat there in SA ha ha ha
Maîneÿ . . .
660175
Follow Up By: Member No 1- Monday, Nov 23, 2009 at 09:07
yes
660187
Follow Up By: mikehzz - Monday, Nov 23, 2009 at 10:22
No, I think its classic case of plasma
overflow to the flux capacitors. I've been wrong before though
660201
Follow Up By: ExplorOz - David & Michelle - Monday, Nov 23, 2009 at 11:59
When did you see this text? It is part of my link checking and replacement software that converts links. What you are seeing is the output where only half of the replacments have occured ie: it has converted all the data but has not turned the output back to a readable fashion (this is the last part of the process). So if it does happen I need to know where and what you did to get it?
DM
660224
Follow Up By: Member No 1- Monday, Nov 23, 2009 at 16:16
David, saw it this morning
I'll see if i can replicate what I did and get to you
660262
Follow Up By: Member No 1- Monday, Nov 23, 2009 at 16:24
David
at bottom of page you have a block called "Article Topics"
Clicked on "Technical"
Clicked on
Forum Posts " Turbos and Superchargers"
opened up the first thread (67137) (as I was
young back then am now that old and now cant remember what I typed back in 1949)....and up came the jibberish
660264
Follow Up By: Richard Kovac - Monday, Nov 23, 2009 at 17:42
No. 1
I follwed your directions & I can see it
This is Willem's reply, make about as much sence.. LOL
well..........................hahahahahaClick Image to EnlargeWillem There is more than one way to get a rabbit Member: My Profile My Blog Send Message Reply 1 of 5
Richard
660274
Follow Up By: Richard Kovac - Monday, Nov 23, 2009 at 17:44
thats not fair it turned it back to what it should read and see.. looked better this way..
660275
Follow Up By: Richard Kovac - Monday, Nov 23, 2009 at 17:50
That even fixed it after I added more letters.....
Sorry I give up....
660277
Follow Up By: Member No 1- Monday, Nov 23, 2009 at 19:21
Richard
Thats why I had to copy it to photoshop and turn it into a Jpeg
for some strange reason when you copy from original page and paste to current post it chnages back to what it was...not all of it get pasted but some of it does and in the correct type
660288
Follow Up By: Richard Kovac - Monday, Nov 23, 2009 at 19:32
Your a better man then me.... I tried to do something like that, but couldn't work it out.. LOL
This is what it was to look like.
Richard
I always had a problem reading it's now getting worse
660290
Follow Up By: ExplorOz - David & Michelle - Monday, Nov 23, 2009 at 23:52
It may be related to a search - please let me know if you get one of these again - I need to be sent a copy of the address line (your browser address) in email to david@exploroz.com and this will allow me to duplicate the issue and find.fix the problem if it occurs again.
DM
660337
Follow Up By: ExplorOz - David & Michelle - Tuesday, Nov 24, 2009 at 01:07
Thanks again Richard for your samples in email the problem has been resolved.
DM
660339
Reply By: Member - John (Vic) - Monday, Nov 23, 2009 at 11:01
Richard why don't you email David direct with all the details so he can have a look?
He does not spend all his time on the
forum ya know.
There was some link recognition issues a few days ago which have been fixed but other than that the site is running very
well for me.
392307
Reply By: Member - joc45 (WA) - Monday, Nov 23, 2009 at 11:41
Mmmm, I've been having a lot of trouble with Firefox over the last week or so. Nothing happens, and have to re-try, then it works. On four computers here, too.
IE seems to work fine with ExplorOz at present, so perhaps the current version of Firefox might have a bug.
Gerry
392312
Follow Up By: ExplorOz - David & Michelle - Monday, Nov 23, 2009 at 12:00
Ah should not be a problem I use the and develop most of the time using the latest firefox. What problems are you having?
DM
660225
Follow Up By: Member - joc45 (WA) - Monday, Nov 23, 2009 at 13:51
MM sent
660250
Reply By: Geoff (Newcastle, NSW) - Monday, Nov 23, 2009 at 12:06
Member No.1 when I look at your post I get a mix of yours and GoneTroppo as the posters!
Figure this one:
Geoff
| Geoff,
392317
Reply By: disco driver - Monday, Nov 23, 2009 at 14:04
Hi Member No1,
The gibberish you brung up is a direct result of our esteemed leader, one KRudd, introducing his version of internet censoring by stealth.
It's 100% succesful, no one can read it, no one can understand it, and it therefore achieves absolutely everthing he wants. that is; To keep everyone completely uninformed, a bit like his spoken words too.
Just my thoughts.
Disco, who obviously is NOT a "True Believer".
392330
Follow Up By: Member - Peter W (WA) - Tuesday, Nov 24, 2009 at 02:09
Disco
You're the best
660342
Follow Up By: Richard Kovac - Tuesday, Nov 24, 2009 at 02:27
why because he's NOT a true Believer.. LOL
660343
Follow Up By: Member - Peter W (WA) - Tuesday, Nov 24, 2009 at 03:45
No, because he's picked Kruddy to a T
660344
Reply By: ExplorOz - David & Michelle - Tuesday, Nov 24, 2009 at 01:06
All fixed now thanks to Richard K for sending me a reproducable
test case - the issue was related to searching with a string in double quotes - this has now be resolved.
DM
392393
