X Jack
Submitted: Tuesday, Nov 24, 2009 at 10:25
Member -Tukka - (WA)
Hi all, Im interested in these x jack's as i have recently used them at work. I was told the best one to buy is the BushRanger and they are around $400.
Does anyone know where i can get one cheaper than this or maybe another sort of x jack?
Reply By: Member - Tony V (NSW) - Tuesday, Nov 24, 2009 at 14:00
Reply By: Member - Kroozer (WA) - Tuesday, Nov 24, 2009 at 16:06
Yeah i'd probably stick to the
well known brands. Ironman and Bushranger or ARB if they make them. Though would probably go Ironman, good gear at lower prices. Never used one myself, never had a problem with needing a lift when i owned the old girl. Though i think your better off with one.
392460
Reply By: Member -Tukka - (WA) - Tuesday, Nov 24, 2009 at 16:29
Cheers for the info gents
I'll start hunting around. Probably go with the BushRanger if a can find one with the right price tag
392462
Reply By: Mick O - Tuesday, Nov 24, 2009 at 18:44
I ahve one of the bushrangers. Never been out of the bag. I've always been advised to carry a couple of sheets of thickish rubber or carpet to use as a baffle as they are susceptible to being punctured by the underside of the vehicle if you are not careful.
If you're keen, stake out you local Rays outdoors (if you have them in WA) as they often have them at 26 % off during their members sales.
Cheers Mick
392473
Follow Up By: Member -Tukka - (WA) - Wednesday, Nov 25, 2009 at 10:30
Thanks Mick
The bushranger i used at work was double insulated on top and bottom for this reason. The only thing they said was to try keep it off the exhaust as it will probably burn a hole in it.
see how i go anyway
660487
Reply By: Steve63 - Wednesday, Nov 25, 2009 at 09:16
They should be used with care as they tend not to be that stable. Some of the better ones now have heavy duty ends to prevent damage from sharp bits on the vehicle and ground. I have been advised several times not to use them with turbo charged vehicles. One jack I saw recently had an option to use a compressor instead of the exhaust specifically because of this. May have been a Bushranger. I carted one around for years and never used it. I have had a few times recently when it would have reduced the amount of effort to recover the vehicle so perhaps I should put it back in. :-)
Steve
392528
