Tyre Options for 17" Patrol
Submitted: Wednesday, Nov 25, 2009 at 14:56
ThreadID: 73992 Views:5731 Replies:7 FollowUps:11
Well the Patrol is getting close to the 40,000km mark and the orginal Bridgestones are just about shot, which is pretty typical, so looking at a tyre upgrade. With 17" rims, choice is a bit limited and expensive. I am also wanting to upgrade suspension at same time with 2" lift kit. Now the issue is....
Local tyre dealer tells me BFG only make a 17" in All Terrains in the original tyre size i.e. 275x65x17. I was hoping for a slightly taller tyre to compensate for the lift. Cooper make a 265x70x17 in ATR's, which is probably the ideal size for the lifted Patrol. However, I would prefer the BFG's. I can recall speaking to a guy a couple of months ago who had done a lift on his 17" shod Patrol and sourced some taller BFG's from Interstate. ....
Has anyone done this, or is a taller BFG available in a 17" and am I getting a bum steer from the Dealer?
Reply By: Member - Tour Boy ( Bundy QLD) - Wednesday, Nov 25, 2009 at 15:03
Try thisBFG sizes
Dave
Dave
2015 Fortuner
Had 72 cruisers in my time
AnswerID: 392581
Follow Up By: Spitster - Wednesday, Nov 25, 2009 at 15:09
Thanks Tour Boy
The size I am looking for is certainly on this list. I will re-inqure with the list....
FollowupID: 660525
Follow Up By: Spitster - Wednesday, Nov 25, 2009 at 15:23
Just had a look at this site. This chart is for mud terrains. the relevant size I am looking for in all terrains, doesnt appear to be available.
FollowupID: 660535
Reply By: Member - John (Vic) - Wednesday, Nov 25, 2009 at 15:07
Maybe consider changing to 16" wheels??
The 17" tyres regardless of brand would be a likely problem to source in remote areas if ever required.
AnswerID: 392582
Follow Up By: Spitster - Wednesday, Nov 25, 2009 at 15:18
Yes, John I wasnt too happy when I traded the old Patrol with 16" rims on the newie, to discover it had 17's for this reason, however times do change. I was up around Innamninka recently in a mates new Hilux, when we had to get a 15" tyre, couldnt get one. Years ago these were all you get in the bush, Now its 16's, in the not too distant future it could be 17's.
FollowupID: 660533
Follow Up By: Peter McG (Member, Melbourne) - Wednesday, Nov 25, 2009 at 15:22
As you can see in the chart the 265x70x17 and 265x75x16 tyres have the same diameter - 804mm. I'd go for the 16" on steel wheels and leave the alloys in the shed.
FollowupID: 660534
Reply By: chisel - Wednesday, Nov 25, 2009 at 15:23
265x70x17 is just about the same as 275x65x17, I think.
You can get a Bridgestone 694LT in 275x65x17. I have them.
AnswerID: 392584
Reply By: tdv - Wednesday, Nov 25, 2009 at 15:36
I have 265x70x17 BFG All Terrains on my Prado. Recently replaced by Bob Jane....4 months ago after 80,000 on first set. They were expensive though $375 each...ouch!
AnswerID: 392585
Follow Up By: Spitster - Wednesday, Nov 25, 2009 at 15:38
Yeh, Bob Jane quoted me the same price, however I have another quote for $345 from another independant. Still ouch........ but not as much. By the way the Coopers were quoted at $375
FollowupID: 660539
Reply By: deserter - Wednesday, Nov 25, 2009 at 17:05
I am extremely happy with my 17' Goodyear Wrangler Silent Armour.
AnswerID: 392595
Reply By: Member - TJ (VIC) - Wednesday, Nov 25, 2009 at 20:58
Hi Spitster, I have the same dilemma as you. Same vehicle , km's etc. I'm looking at going to 16 inch wheels. Tyres are cheaper and heaps more options, particulalrly when away from the cities.
TJ...
AnswerID: 392622
Follow Up By: Spitster - Thursday, Nov 26, 2009 at 11:11
Hi TJ, Your right same color and all, hope we dont park next to each other, wont know which is which. what height is your lift and I assume these are the original Dueller tyres?
FollowupID: 660673
Follow Up By: Member - TJ (VIC) - Thursday, Nov 26, 2009 at 16:43
Its a 50mm OME lift with Nitrocharger shocks. It appears to sit a little higher at the rear but I think this is because I went for the Heavy Duty Springs (250kg constant load). Sits very nicely when loaded up and the camper is attached. Rides very nicely too.
It has the Bridgy 693's still. Am going to go for 694LT's on 16inch black sunraysia's. I've been happy with the 693'a. The only fault with them is they cut on the blue metal roads around here.
FollowupID: 660696
Follow Up By: Spitster - Thursday, Nov 26, 2009 at 16:47
I have been disappointed on the original Duellers on my last 2 Patrols, lucky to get 40k out of them. Just out of interest how many k's have you got out of yours?
FollowupID: 660697
Follow Up By: Member - TJ (VIC) - Thursday, Nov 26, 2009 at 18:23
30 thou on 'em now and will probably manage to squeeze another 10 our of 'em.
FollowupID: 660716
Reply By: Star Bug - Wednesday, Nov 25, 2009 at 22:04
Fitted BFG AT 285 70 17 to my 05 patrol about 6 months ago. Got just over 80K from the original rubber
Vehicle has a modest 2" lift and castor corection bushes.
Front tyres at full, lock rubbed on the mud flaps. I cut about 12mm out of the inner mud flap mount "L" section and re joined it with a bit of aluminium angle and some self tappers. This pulls the mudflap back and cures the rubbing problem.
Add a Jaycar speedo corrector kit, and everything is sweet.
AnswerID: 392636
Follow Up By: Spitster - Thursday, Nov 26, 2009 at 08:41
Hi Starbug, This is the size I am looking for and the dealer is telling me is not available for the Patrol. See you are in Vic, Can you advise where you bought them?
FollowupID: 660649
Follow Up By: Star Bug - Thursday, Nov 26, 2009 at 10:50
Something sounds sus there. I had no problem getting them. I'm in Perth. Bought them through Bob Jane, but they are a national chain.
As long as they are in stock in the BFG warehouse there should be no problem.
FollowupID: 660670
