Battery Tester
Submitted: Friday, Nov 27, 2009 at 19:21
ScottW5050
Hi I'm a novice camper just starting out with a camper trailer with a 100amp hout battery. I have a projecta battery tester and need to know how to use / read it? Any info would help.
Reply By: Member - Graham H (QLD) - Friday, Nov 27, 2009 at 20:02
Did it come with instructons.
Usually a battery is tested under load with a diagnostic tester.
392938
Reply By: Richard Kovac - Friday, Nov 27, 2009 at 22:16
Scott
If it is a BLT100
You need to have the battery fully charged hook up the clips to the terminals and flick the toggle switch on longer then 10 sec. then read gauge it will tell you the condition of the battery.
It is a load test see
Instructions
Richard
392953
