cleaning alloy factory wheels
Submitted: Saturday, Nov 28, 2009 at 10:10
ThreadID: 74064 Views:4576 Replies:11 FollowUps:5
hi all , i have a pajero and would like to know if there is an alternative to buying the bloody expensive wheel cleaners .
does any one use alternative products to remove the brake dust etc?
i know i can sit there with a tooth brush and scrub for a couple of hours but surely some one has a better way.
Reply By: subby - Saturday, Nov 28, 2009 at 11:16
zacc
try something called ct18 superwash.you can get it from most auto places. i put it in a spray bottle diluted 50/50 and then leave it for 5 minutes and wash off with a sponge and water.
subby
AnswerID: 393007
Follow Up By: Shaker - Saturday, Nov 28, 2009 at 18:33
Just make sure you keep it off your paint!
FollowupID: 661043
Reply By: a convict - Saturday, Nov 28, 2009 at 11:24
I feel sure there will better suggestions than mine, but I use regular old off the supermarket shelf 'Preen' . I may work well on shirt collars etc, but it works wonders on stainless steel and alloy metals. The trick is to make sure you let it DRY. Come back later and simply wash it off.
Try it on a grubby stainless steel 'laundry tub', you'll see what I mean
AnswerID: 393010
Reply By: Member - Stephen L (Clare SA) - Saturday, Nov 28, 2009 at 11:33
Hi zacc
Just like subby mentioned above CT18 is the product to go for. I have been using it for nearly 20 years now and you can use in many places, under the guards, to clean under the bonnet plus many applications in the general household. All you need is 50mm of CT18 to 500mm of water. The longer that year leave it on the better that it works. I usually spray the wheel, tyres, under the guards, under the car (fuel tanks) the night before I wash the car the next day. I first started buying it in the 1 litre bottle, but because we use it everywhere, I now get the 5 litre container, and am now thinking of buying it in the 20 litre drum.
Give it a go and you will be a convert as well.
AnswerID: 393013
Reply By: Member -Tukka - (WA) - Saturday, Nov 28, 2009 at 12:24
When i was fitting tyres i would use cut and polish to get the tough stuff off.
AnswerID: 393019
Follow Up By: DIO - Saturday, Nov 28, 2009 at 17:46
Cut and Polish would be OK for wheels that are polished. These days many alloy wheels actually have a coating (plastic like) which wouldn't respond too well to anything abrasive. I also use 50/50 Truck Wash. Fiind it to be perfect for the job. Also each time I wax the paintwork I also give the wheels the same treatment. Keeps them looking like new and I think makes cleaning them a lot easier.
FollowupID: 661038
Reply By: Member - Duane A (WA) - Saturday, Nov 28, 2009 at 14:33
Just dont use that Ct 18 on your paint work as its very aggressive and it takes the wax out off your polish or standard car wax wash . I was using it on my bus and when i took her in to get it detailed the people there ask me what i washing the car with and when i told them they said i was killing my paint work with it . just a tip.
AnswerID: 393027
Follow Up By: subby - Saturday, Nov 28, 2009 at 16:15
yes .i should have mentioned that. i was useing the ct 18 on the paint but now use the ct 20 wash n wax much easier on the paintwork.
subby.
FollowupID: 661032
Reply By: zacc - Saturday, Nov 28, 2009 at 15:43
thanks guys for your input i will give it a go .
AnswerID: 393031
Reply By: Member - Michael P (QLD) - Saturday, Nov 28, 2009 at 18:53
Hi, Try Mag Shine manufactured by Chemtech (the manufactures of CT18).A2.5I bottle costs about $19 from Super Cheap.
Mike
AnswerID: 393043
Reply By: Fatso - Saturday, Nov 28, 2009 at 20:58
We do 200,000 k a year with mags & do not have a problem with break dust.
The answer is regular washing.
Have used all kinds of wash from CT18 to Turtle Wax & they all work if you wash regularly.
AnswerID: 393054
Follow Up By: Member - Kroozer (WA) - Saturday, Nov 28, 2009 at 23:01
Jesus, doing that many k's a year, how on earth do you have the time to clean the vehicle. Sounds like you have the job i want.
FollowupID: 661057
Follow Up By: mowing - Sunday, Nov 29, 2009 at 21:28
Struth, doing 200,000 km a year, you would only be using the brakes every blue moon....:)
FollowupID: 661231
Reply By: RedJK - Sunday, Nov 29, 2009 at 13:13
Hi zacc
I tried most things, gave up on the expensive acid based aerosol cleaners.
Best thing I have ever used to remove brake dust is "Ajax floor cleaner"
It works, is biodegradable, cheap, and can be used for other purposes.
No I don't own Colgate Palmolive :)
AnswerID: 393125
Reply By: Member No 1- Sunday, Nov 29, 2009 at 14:53
i gave up cleaning them until i came across Brite Shine also called by many other names such as Nevr Dull
Its a cotton wadding used to clean metals....works on mags.... polished or painted
AnswerID: 393141
Reply By: Member -Tukka (WA) - Wednesday, Dec 16, 2009 at 11:31
G'day Zacc
Found another way to clean alloy rims yesterday.
Good old shower power worked a treat.
AnswerID: 395272
