Sunday History Photo / SA
Submitted: Sunday, Nov 29, 2009 at 01:47
ThreadID: 74078 Views:4737 Replies:4 FollowUps:2
Lake Acraman is a deeply eroded impact crater in the Gawler Ranges of South Australia, a circular lake about 20 km in diameter.
The discovery of the crater and independent discovery of its ejecta were first reported in the journal Science in 1986. The evidence for impact includes the presence of bleep ter cones and shocked quartz in bleep tered bedrock on islands within Lake Acraman. bleep ter cones are found at all impact sites.
The crater is deeply eroded and its original size must be inferred by indirect means. Some estimate an original diameter of up to 85–90 km, while others suggest a smaller size, perhaps only 35–40 km, closer to that of the depression in which Lake Acraman is centred. The larger size estimate would imply an energy release of 5.2 × 106 megatons of TNT.
Image Could Not Be Found
The impact event is estimated to have occurred about 580 million years ago during the Ediacaran Period; this age is not derived from the crater itself but from the position of ejecta within nearby sedimentary basins.
A widespread layer of ejecta, believed to be from the Acraman crater, is found within Ediacaran rocks of the Flinders Ranges at least 300 km east of the crater, and in drill holes from the Officer Basin to the north in Western Australia and South Australia that covers about 410,000 km2 and has a maximum sediment thickness of 10,000 metres.
At the time these areas were shallow seas, and the ejecta settled into mud on the sea floor. The ejecta contains shocked minerals and small bleep ter cones, is composed of rock similar in age and composition to that at the crater and is associated with an iridium anomaly suggesting contamination with extraterrestrial material. An evolutionary radiation within marine microorganisms (acritarchs) occurs just above the level as the ejecta layer, and some authors believe there may be a connection. The proximity of the crater to the type area for the Ediacara Biota is noted, though probably not significant given the likely global consequences of the impact.
At the Bunyeroo Gorge walking trail, 50m north into a small creek and the outcrops of the maroon coloured shales of the Bunyeroo Formation.
The creek cuts through a narrow but prominent band of green shale enclosing a 4 10 cm bed of reddish sand; this is the Acraman ejecta layer, which can be traced throughout the Flinders Ranges.
On the west side of the ranges, it is some 80 m above the ABC Range Quartzite.
A basal lag of angular breccia, embedded in the underlying shale represents the fallout of large fragments of Mesoproterozoic Gawler Range Porphyry, dated at 1590 Ma. Quartz crystals in the clasts show deformed laminae.
A few millimeters above, a swaley cross bedded, feldspar sandstone represents the settling out of finer debris from the ejecta and reworking by tsunami surge, following a meteorite impact on the Gawler Craton at what is now Lake Acraman.
The geochemical signature and textural characteristics of the lithic fragments are identical to that of rock in the center of Lake Acraman, the remnant of a probable astrobleme 300 km WSW on the Gawler Craton.
Although analysis of the melt rock failed to give a reset age of impact, the Bunyeroo Formation is likely to be of the order of 570 580 Million years ago.
Reply By: sandk33 - Sunday, Nov 29, 2009 at 07:57
Morning Doug,
Have tried to contact you ...this will about do me though.... I have a group of original photo,s taken by a sailor during the Dec 7 th raid on Pearl Harbour. They are in an email and I will send them if you want... not much bothered either way. Cheers Kevin
AnswerID: 393089
Follow Up By: Member - Doug T (NT) - Sunday, Nov 29, 2009 at 08:01
sandk33
Thanks all the same, I know the photo's your writing about , I do have the photo's .
Doug
FollowupID: 661098
Reply By: Member - Fred B (NT) - Sunday, Nov 29, 2009 at 09:56
Hi Doug, very interesting. You are slipping though..... thought you would have at least one sepia photo of the original impact in your photo collection..... lol...!
Fred B
VKS 737: Mobile/Selcall 1334
AnswerID: 393099
Follow Up By: Member - Doug T (NT) - Sunday, Nov 29, 2009 at 10:29
FollowupID: 661128
Reply By: equinox - Sunday, Nov 29, 2009 at 10:58
Hi Doug,
I did a huge regional Gravity Survey in the area in the mid-nineties. At that stage the geologists were told not to mentioned to anyone about the impact or what they were doing there.
A lot of the rocks in the overburden were magnetic, quite interesting.
It was also the first and only time I have been lost using only a GPS (Garmin Survey II) which brings back special memories for me!!
AnswerID: 393107
Reply By: Member - Russnic [NZ] - Sunday, Nov 29, 2009 at 15:29
Thanks Doug
As Usual fascinating
Last winter on my travels I come across Brachina Gorge and then the Geological Trail, actually camped the night then went back to the start and did it again, taking time for photos and reading all the information signs.
I carried on my travels to Wilpena Pound where it was very low overcast and steady rain. I wandered into a Tourist Trap there and found if I bought a meal I could get free trip into the pound, not feeling hungry I ended up paying $2.50 for a brochure on the Brachina Gorge, so I went back and did her again, a bit slower again this time.
Saw and photographed evidence of that impact in Lake Acraman.
The old knees ain't so good so I don't walk away to far from the Troopy so only saw what was close to the road.
AnswerID: 393146
