Vehicle Shower Feedback
Submitted: Sunday, Nov 29, 2009 at 11:44
ThreadID: 74084 Views:3711 Replies:3 FollowUps:3
Chasing some advice about a 'basic' solar shower. We're in the Kimberley, so no need to heat water. I was thinking of putting two 20 litre drums on the roof rack, with a hose running into one of those shower tents.
Has anyone got suggestions as to the terminal end at the shower head? Water will be at premium, so I'll need some form of tap inside the tent ( am I making too much of this, and should I just be guided by my local plumber ?)
Reply By: Member - joc45 (WA) - Sunday, Nov 29, 2009 at 12:27
That's 40kg of unnecessary weight you're carrying on the roof rack.
Generally, I've carried no more than 20L of water in the Kimberley, as there is plenty of good water in creeks wherever you go, even in the dry season. I put out a plastic 20L solar shower in the sun when camped, then decant the heated water into a bucket, and use a Jaycar $20 12v shower.
Gerry
AnswerID: 393118
Follow Up By: Serendipity (WA) - Sunday, Nov 29, 2009 at 12:45
Hi Snaggers
I carry an empty 20litre steel bucket - one of those empty paint buckets with a handle. When I travelled through the Kimberleys I would get some water from the creek and go back to camp - put the bucket into the fire for 10mins or less.
Then like Joc45 I just use a cheap 12v shower that you can pick up in any camping store. Fit a switch to it so you don't have to keep unplugging. This bucket of water can shower two adults with comfort.
It was easier and quicker to heat the bucket in the camp fire. The bucket doubled up as storage container for the spare gas bottle.
Problem with the solar shower is you need the daylight (good sunny day) to warm it up - and then you would need to shower soon after. Once the water runs out you need more sunlight to heat up another. I like to shower during the evening when we are getting the kids ready for bed otherwise they would tear around and get dirty again. You can heat more water over and over.
David
FollowupID: 661145
Reply By: snaggers - Sunday, Nov 29, 2009 at 12:38
Is this 'Gerry' from Broome- works at 'Her Majesty's Hotel' ??
AnswerID: 393120
Reply By: Member - Amy G (SA) - Monday, Nov 30, 2009 at 17:59
I discovered after I had wet down, shampooed up and soaped up ready for rinse this weekend that the battery powering my 12V shower was well and truly dead. Fortunately I had my flannel cloth in there with me and used that with my shower-sized billy of hot water for the rinse off. What do you know, I got a better rinse off (yes, even shampoo from long hair) using the flannel with less water than I use with the 12V shower. It might be worth a shot rather than going to the effort of water on the roof...
AnswerID: 393267
Follow Up By: Member - Kroozer (WA) - Monday, Nov 30, 2009 at 18:07
What size battery were you using? Musn't be very big or must have been flat already. You sure it was a 12v shower or a 'D' or 'C' cell battery shower?
Being in the Kimberley also and not needing to heat water i just use a 12v Primus/Jaycar shower. Fill bucket drop in pump and away ya go. I heard some dont last very long, so will be replacing the pump with a RULE bilge pump very soon. Little bit of modifying might be needed but at least i will have a good cheap reliable pump and with only a small current draw.
Should oly need about 5 litres for a shower, unless ya been fishing or crabbing then might need 10.
FollowupID: 661329
Follow Up By: Member - Amy G (SA) - Monday, Nov 30, 2009 at 19:24
I'm home now and have since discovered it was not flat, but the neg terminal had come off inside the battery storage bag and I didn't notice at the time. No wonder it didn't charge... :-)
The battery is a 7 amphour SLA battery- $30 at Jaycar. It is nice and easy to recharge as you can plug it into the 12V sockets in the car while on the move.
I think my shower bucket is around 7L, but using the 12V shower I usually struggle to get my hair rinsed properly with my bucketfull. I still had a few litres left after the flannel wash down. If you don't have long hair I don't imagine you'll have this problem :)
FollowupID: 661343
