HZJ landcruiser Gearbox's, scary or unlucky????
Submitted: Monday, Nov 30, 2009 at 21:26
ThreadID: 74115 Views:6882 Replies:5 FollowUps:8
I'v bee looking round at late 90's and early 20's troopys...
Of the 6 i am a start on, 3 have gearbox's replaced or repaired
This is really scary...
is there a way to tell if they are on there way out?
which models should i stay away from?
the landcruiser's i remember (70's - 90's) didnt have gearbox issues... i thought they were safe buying....
Reply By: Top End Explorer - Monday, Nov 30, 2009 at 23:02
The HZJ 75 or up to 10/99 box was fine, the HZJ 78/79 or 11/99 onwards were a crap gearbox, I rebuilt one 3 times in 2 years.
Cheers Steve.
AnswerID: 393318
Follow Up By: pop2jocem - Monday, Nov 30, 2009 at 23:19
As above with the 1HZ non factory turbo models, the factory turbo ones had a good gearbox h151 I think is the gearbox model from the turbos.
Cheers Pop
FollowupID: 661379
Follow Up By: robertbruce - Tuesday, Dec 01, 2009 at 01:19
thank you for your response...
FollowupID: 661392
Reply By: Member - ross m (WA) - Monday, Nov 30, 2009 at 23:17
The gearbox is the R151F and is based on an old Supra gearbox.
Its also used in the 4 cyl coil sprung Landcruiser 70 series,Prados and Hiluxes.
Just too small for the big landcruisers
AnswerID: 393320
Follow Up By: Member - ross m (WA) - Monday, Nov 30, 2009 at 23:19
They did make some upgrades to improve its longevity in 2001 or thereabouts.
FollowupID: 661378
FollowupID: 661393
Reply By: The Rambler( W.A.) - Monday, Nov 30, 2009 at 23:39
Ihave the 2001 model Troopy and had the upgrade and so far no problems over some very rough stuff.Ithink you have to be unlucky to have a problem but the upgrade gives a lot of piece of mind if you are going bush.It cost me $800.
AnswerID: 393322
FollowupID: 661394
Reply By: robertbruce - Tuesday, Dec 01, 2009 at 01:21
great about the gear box, buy a 99+ hd, or a pre99 hz...
looks like im missing on on coils, great...
AnswerID: 393327
Follow Up By: Ozhumvee - Tuesday, Dec 01, 2009 at 06:25
The NA 1HZ also had problems with them flogging the splines out on the main shaft and transfer input gear. Mine was a 90 model and I rebuilt it every 100k, they continued to have the same problem well into the 90's like 95 or 6 were still having the same problem.
FollowupID: 661399
Follow Up By: racinrob - Tuesday, Dec 01, 2009 at 07:59
G'day Peter, Yep, like you I've had the transfer case rebuilt twice on my 94 1HZ, once at 100 thou and then at 200 thou and now at 275 thou I have a noisy main gearbox, it's making whirring noises which come and go, bit of a worry, I should have updated a while ago methinks. Engine is fine however.
Rob.
FollowupID: 661407
Follow Up By: ob - Tuesday, Dec 01, 2009 at 13:09
A modified transfer case input gear that takes advantage of the gearbox output shaft splines that would drive a pto winch and a spacer that does not do much is available from a mob in Melbourne and I think Don Kyatt Spares or Marks Adaptors do one as well. Saves changing the main gearbox shaft with all the costs that go with that job.
Cheers ob
FollowupID: 661435
Reply By: Member - Kiwi Kia - Tuesday, Dec 01, 2009 at 10:17
As I understand the situation;
If the Troopy has coil springs then you need to look at the gearbox numbers to see if it is one of the ones that needs to be modified. If you have leaf springs then you are ok.
KK
AnswerID: 393349
