connecting solar panels
Submitted: Monday, Nov 30, 2009 at 21:35
scoota
I have a folding 120 w solar panel. Each of the 60w panels have a small black box from which a positive and negative cable exits. Is it ok to run both these pairs of cables straight into a Anderson plug (which will then connect 10m of 6mm cable to the battery via a regulator) ?
Cheers, Scoota
Reply By: ABR - SIDEWINDER - Monday, Nov 30, 2009 at 22:08
Yes if you are charging a 12V system.
393313
Follow Up By: scoota - Monday, Nov 30, 2009 at 22:13
Yes, forgot to mention it is for connecting to a 12v dual battery system on a Defender.
Scoota
661368
Follow Up By: ABR - SIDEWINDER - Monday, Nov 30, 2009 at 22:39
This image may help.
Derek from ABR
661372
Follow Up By: johntoyo - Monday, Nov 30, 2009 at 23:59
Thanks Derek your advice is always straight forward, informative and to the point.
You also stock some good pieces of kit.
661388
Follow Up By: scoota - Tuesday, Dec 01, 2009 at 14:58
The diagram has answered my question - thanks for that, Scoota
661450
Reply By: Maîneÿ . . .- Tuesday, Dec 01, 2009 at 00:30
scoota
I would think a 6mm cable may be a bit thin for a 10 Mt long extension cable
Maîneÿ . . .
393325
Follow Up By: Member - Mary W NW VIC - Wednesday, Dec 02, 2009 at 19:51
Have a similar set up with 2folding panels that I sometimes mount on the roof rack when travelling.They then charge a 100ah fullriver battery which seems to cope very
well with my fridge.My question is that the panel is connected via Anderson plug to another A plug near the battery.Should the regulator be on the roof or inside nearer the battery?
Thanks,
Mary
661612
Follow Up By: Maîneÿ . . .- Wednesday, Dec 02, 2009 at 22:30
Mary,
it has to be beside the battery for optimum performance
Maîneÿ . . .
661639
