Radio interference from battery charger.
Submitted: Tuesday, Dec 01, 2009 at 11:31
racinrob
I hook my caravan battery up to a smart charger while it's sitting at home. It's a new three stage state of the art charger not a cheapie but it causes interference on all the radios in the house, is there a filter or something I can use to remedy this ?
Rob.
Reply By: Member - Fred B (NT) - Tuesday, Dec 01, 2009 at 12:09
If it does that, then it doesn't comply with Australian Standards. Talk to your supplier, you may have a faulty unit.
regards,
393357
Follow Up By: Member - Mike DID - Tuesday, Dec 01, 2009 at 13:13
- agreed, some interference is normal on a radio beside the charger. Interference radiating a long way is a fault or a cheap and nasty and non-compliant design.
661436
Reply By: ob - Tuesday, Dec 01, 2009 at 13:14
My smart charger in the van does not cause any interferance to any radios, as said I think you have a faulty unit. Having said that the charger I use in the shed for cordless drills plays havoc with my shed radio if tuned to an AM station, doesn't bother radio on FM.
Cheers ob
393368
Reply By:- Tuesday, Dec 01, 2009 at 14:07
What brand charger? And does it show the compulsory c-tick logo?
If it's c-ticked, it may be faulty, if not, the seller broke the law by selling it to you.
Sellers are required to produce EMC approval documentation (held by the manufacturer or importer) on request.
Go and get this off him.
If he can't give this to you, you are in a good position to demand another unit from him.
Best regards, batterymeister
393381
Follow Up By: RV Powerstream P/L - Tuesday, Dec 01, 2009 at 17:34
There are two types of switchmode and a lot of makers go for the cheaper switchmode.
The better switchmode has PFC (Power Factor Correction) and this type should pass Cispa 11 or 21 the toughest requirement here for EMC compliance.
ian
661476
Follow Up By: racinrob - Tuesday, Dec 01, 2009 at 20:27
Thanks batterymeister, it's a Durst, I'll give the company a ring.
Rob.
661498
