Landcruiser 100 std electrical issues
Submitted: Tuesday, Dec 01, 2009 at 16:14
ThreadID: 74130 Views:16055 Replies:2 FollowUps:6
Hi all. Has anyone had any experience with 2 electrical issues on a 100 series std. 1) One issue is the immobiliser module on the injection pump blows fuses. Mechanic suggests may be an immobiliser circuit board issue. Replacement immobiliser is approx $800 from Toyota. Anyone have this happen on their vehicle? Wondering what after market replacement part or alternative immobiliser options are available that are also reliable enough for remote travel.
2) The mechanic has temporarily bypassed the immobiliser by jumping the positive wire from the immobiliser directly to the fuel cut solenoid so the vehicle will start. Now my glow plug dash light stays on when driving. Goes off initially after starting but then comes back on after approx 15 sec and stays on - can hear glow plug relay going on/off intermittently when vehicle is idling. Not sure if glow light on related to the by-pass wire or coincidence of another problem developing. If preheating timer, a $400 Toyota part - any experience with replacing with manual (ie button/switch) option?
Appreciate any thoughts/ideas.
Reply By: Member - Tour Boy ( Bundy QLD) - Tuesday, Dec 01, 2009 at 17:06
A couple of fellas on the lcool site have had the same issue. They disconnected the immobiliser permanently.
Lcool
Dave
Dave
2015 Fortuner
Had 72 cruisers in my time
AnswerID: 393392
Follow Up By: dbish - Tuesday, Dec 01, 2009 at 17:23
Hi Takinmytime The glow plug relays will probably keep activating till the engine warmsup, asthe module has a coolant sensor. Id warm up the motor & then see if they have gone off. Cheers Daryl
FollowupID: 661472
Follow Up By: takin my time - Tuesday, Dec 01, 2009 at 21:53
Thanks for the info Tour Boy. Have done a search of LCOOL to try and find the posts you have mentioned - used 'immobiliser' as search term but couldn't find relevant responses. Have undertaken registration with LCOOL - maybe that will help me find the posts. Do you have any keyword suggestions so I can track down the posts you mentioned? Thanks again
FollowupID: 661512
Follow Up By: takin my time - Tuesday, Dec 01, 2009 at 21:55
Thanks dbish - I'll give your suggestion a try.
FollowupID: 661513
Follow Up By: Member - Tour Boy ( Bundy QLD) - Wednesday, Dec 02, 2009 at 08:56
The link I put up goes straight to a thread
Dave
2015 Fortuner
FollowupID: 661543
Follow Up By: takin my time - Wednesday, Dec 02, 2009 at 22:38
thanks Tour Boy. Have registered with LCOOL and am now able to follow the link you sent. Good info, big help!!
FollowupID: 661642
Reply By: pt_nomad - Tuesday, Dec 01, 2009 at 17:44
I had a keyless entry system fitted to my 105. I had to explictly tell them not to connect hte immobilser component - i did not want two.
You could bypass the factory system by fitting keyless entry and get the added bonus of keyless entry without voiding the insurance requirement of having an immobiliser fitted.
Paul.
AnswerID: 393398
Follow Up By: takin my time - Tuesday, Dec 01, 2009 at 21:57
Thanks pt_nomad for the info - That sounds like a good option I'll discuss with an autoelectrician, particularly with respect to satisfying insurance requirements.
FollowupID: 661514
