roof rack water heater
Submitted: Thursday, Dec 03, 2009 at 10:22
ThreadID: 74166 Views:4525 Replies:4 FollowUps:6
Black Poly pipe under the roof rack work for a heater and storage?
I'm sure someone must have tried this but I can't find any reference on the web.
We had a coil of black poly pipe on the farm roof which was our hot water shower for years.
I'm thinking of a couple of large pipes (100mm) either side for storage and black poly pipe between them, all tucked under the roof rack, no good whilst travelling and rack loaded up, but park the car in the sun when camped and hopefully have 20-30l of warm water for showers.
Anyone tried it or similar?
thanks
Frank
Reply By: Member -Tukka (WA) - Thursday, Dec 03, 2009 at 10:39
Franken
i havent done this my self but the idea sounds good. Some thick black poly would be the go.100mm sounds good, that will give you 8 litres per meter lenght so if you want about 20-30 litres maybe put two lenghts of 100mm 1.5-2.0 meters long or so.
AnswerID: 393619
Reply By: Member - Oldbaz. NSW. - Thursday, Dec 03, 2009 at 11:08
Seems like a lot of trouble,cost & weight for a bit of warm water to me, tedious to fill,requires a heap of plumbing. Wont work when covered, black pipe absorbs heat quickly but dissipates just as quickly.
I doubt temp will increase much unless in sun for many hours. Apart from that, probably a great idea..:))). Boil the billy, add to cold water in bucket..connect to
shower & all is well, but I was always a simple bloke..cheers.....oldbaz.
AnswerID: 393623
Follow Up By: franken - Thursday, Dec 03, 2009 at 11:42
idea is to avoid boiling the billy :-)
but it's pretty hard to beat the KISS principle of a billy, bucket, and shower pump.
and I've got to carry the water anyway,
Perhaps just using a black jerrycan on the roofrack would work just as well. now thats simple!
FollowupID: 661716
Follow Up By: Fab72 - Thursday, Dec 03, 2009 at 13:15
Done it myself franken. Had two lengths of 150mm poly pipe connected together on the roof racks. Then I plumbed up a male quick connect fitting (airline type fitting) onto one of the pipes and fitted a female connection onto a shower head with a short extension pipe and ball cock tap.
I'd pull up, pull out the shower head, connect it up, turn the tap on and bingo...warm (not hot) water for a shower.
Stuff boiling the billy, dragging out the bucket, setting up the pump etc, finding a tree of similar and having to use valuable drinking water. I carried my drinking water in containers in the car and (even bore) water on the roof for a shower.
Never regretted it for one minute.
FollowupID: 661733
Follow Up By: franken - Thursday, Dec 03, 2009 at 17:28
any chance of a photo?
FollowupID: 661769
Follow Up By: Fab72 - Thursday, Dec 03, 2009 at 18:30
I'll have a look around for a pic. Should be able to find one somewhere although it was before I went digital so it might be a scanned job.
I'll have to contact you direct as I can't post pix on here, not being a financial member.
FollowupID: 661778
Follow Up By: franken - Thursday, Dec 03, 2009 at 18:49
thanks, you can email me at fdotthomasatcurtindotedudotau
replace dot with . and at with @
frank
FollowupID: 661782
Reply By: bruce - Thursday, Dec 03, 2009 at 12:58
The plastic bag type that you lay on the ground in the sun work quite well(actually very well)....we normally try to park our car in the shade when camped so having pipes on the roof rack would not be much good to us...I doubt very much if being on the car the water would get very hot at all.....on the roof of a house you have the reflection of the heat from the roof helping it and if it was an iron roof then that would be considerable....on the ground the heat reflects as well...cheers
AnswerID: 393641
Follow Up By: racinrob - Thursday, Dec 03, 2009 at 18:33
Probably not an original idea but I saw an old F150 camper going thru Jerilderie the other day with two of the shower bags on the bonnet held in place with occy straps. This was a couple of weeks ago when the temps hit 40 deg, heated from both sides !
Rob.
FollowupID: 661779
Reply By: Member - John and Val - Thursday, Dec 03, 2009 at 13:07
Not quite what you're thinking of, but close - We carry a black 10 litre (ex-oil) bottle full of water lying horizontally on the roof rack. The plan was that it would absorb heat during the day for a couple of minimal showers. Works fairly well in that the water warms up sufficiently for comfortable showers, IF the vehicle is stationary for a few hours. The heat losses to the air if the vehicle is moving though lead to a cold shower. I'm thinking of some simple insulation - maybe wrap in bubble wrap to avoid losses while still collecting heat from the sun? Still to be tried.
Your black polypipe would probably be similar. Lossy if in motion, ok otherwise.
HTH
J and V
- Albert Einstein
AnswerID: 393644
