Sunday, Dec 06, 2009 at 18:24
Seems to me there are two questions here: what would I like to take, and what can I take. Witha big trip like you are planning, I for one would not want to set off with an illegal rig, so here are my thoughts:
Here is my attempt at a checklist for the constant problem of “how much can we take”:
1. What is the caravan Tare weight?
2. What does the caravan weigh with the spares fitted; tanks full; the gas bottle(s) full and fitted; the caravan battery fitted; awning/annex etc; but before you start loading food, utensils, clothes, BBQ, genny, other stuff in the boot of the caravan?
You’ll probably find that (1) is a lot less than (2)
3. What is the caravan ATM?
Now work out (3) minus (2)
This gives you the absolute maximum you have available to add to the van, including all your food and clothing, cooking stuff, everything in the front boot and in the toolbox on the back bumper; and don’t even mention the outboard motor; the collapsible trailer etc. Let’s call this:
4. the available caravan load
Now let’s turn to the tow vehicle.
5. What is the GVM of the tow vehicle?
6. What does the vehicle weigh with
fuel, passengers, normal stuff like spares, jack, but before you start packing for the trip?
Now subtract (6) from (5), and take off the ball weight of the caravan: this will give you:
7. The available capacity of the tow vehicle for things like extra spares; roof rack; rear wheel carrier and jerry cans; high lift jack; extra
water or
fuel; (let’s not mention the tinny on the roof!)
Finally, let’s add (3) and (5) together, and make sure they do not exceed the GCM.
By the way, have you thought about the chairs and tables? the tent and other gear for vehicle-only trips while you are away? Doesn’t your tow vehicle carry everyone’s stuff, like
First Aid, cameras, various personal stuff. Even the dog weighs something!! It all adds up.
Yes, OK, this is getting heavy, but I really think that is what we have to face.
All the best with your planning.
393995
Follow Up By: Member - Graham H (QLD) - Sunday, Dec 06, 2009 at 21:14
All that makes my head spin Ten pounder.
I have quoted the weights of the cruiser for him but as his also has a steel bar and a winch its capacity will be less than normal.
I just took what I thought I needed and weighed it.
Then went home and took stuff including the roofrack out untill it was legal , easiest way to do it.
Same with the van Loaded it up Off to a certified weigh bridge then back
home to sort out what wasnt needed
Took a day or so but we got it right.
Biggest prob was the vans 305kg ball weight.
Nearly had to leave the wife behind LOL
662194
