Monday, Dec 07, 2009 at 19:43
Please tell me different...think about it.
A used filter will always have better filtering properties then a new one as long as it not restrictive.
If a new filter is rated at 35 microns, it will stop anything bigger the 35 microns getting through so every thing below 35 microns will go through.
If the filter catches 35 micron bits, over time it will start catching 34 micron bits and so on to a point of the filter becoming restrictive.
Withs filters there is a big gap between letting enough air through and restriction.
Why do you think they have such large surface areas.
Look at big earth moving gear (80plus liters of engine oil) with restriction gauges on air filters and regularly oil testing.....they change filters(excluding
fuel filters) and oil when needed.
Same as people think they have to change engine oil every 5000k...why?
The only thing you are helping is the pockets of the oil company's.
This came about when engine oils were very basic and had no stabilisers, friction modifiers, detergents or partial suspending additives in them.
This is more a gimmick that had been drummed into peoples heads buy oil company's, and service people.
Sure some vehicles need clean oil for injectors and timing chain tensioner but few and far between.
Look at the Euro vehicles with 30 to 60000K plus service and filter intervals....why...better oils.
Just because the oil goes black doesn't mean it needs changing.
The best thing to do is get the oil tested at 2500k intervals and see whats happening...you might be surprised.
662330
