Removing Element from Electroux RM210
Submitted: Monday, Dec 07, 2009 at 13:42
ThreadID: 74238 Views:2709 Replies:2 FollowUps:0
Been trying to remove the element from this fridge as the 12v element has developed a short. How are these things actually secured into the chimney? Any tips I will post a photos later if that helps?
Reply By: furph - Monday, Dec 07, 2009 at 14:18
Suggest you try:
www.rvmobile.com
Is a good source of info., Dometic fridge's
furph
AnswerID: 394075
Reply By: handy - Monday, Dec 07, 2009 at 15:11
from memory they are only held with a screw.
my element was rusted in and and broke in half i then had to drill a hole thru the van floor and push the rest out with steel rod.
not sure if yours is the same. cheers
AnswerID: 394078
