HUMMER rematch
Submitted: Monday, Dec 07, 2009 at 19:27
ThreadID: 74245 Views:5433 Replies:5 FollowUps:8
Short while ago I posted about a Hummer H2 we had for a Test, well the owner of the vehicle read about the second place I gave the Hummer, wasn't impressed, and soon a head to head no-holds barred re-match was organized.
This trip would be into no-way out tracks on neutral ground.
The huge Hummer was to be supported by 2 V8 rangies, one a competition grade rig who condescended to only use his small 35 inch wheels this trip.
I was feeling a little intimidated as my 4800 Patrol was suddenly the lowest
power car on the trip but at the last minute a more or less normal 3lt Rodeo
turbo diesel came along. I felt much better then, sort of like always going
swimming with a partner to cut your chance of shark attack in half.
We set off to Wesburn in Victoria and the deadend tracks that surround the
Britannia creek road.
We all had different ideas as to what the trip was about.
Some girls thought we were going on a picnic, the competition Rangie was their to test out a full rebuild, but I was convinced they were out to play "Sink the Patrol".
As we headed up the steep Ellis track though the comp rig overheated and I
now took the lead and we drove around till I found some flatter tracks
to play on before lunch.
As we entered a heavily overgrown swampy track I noted an ominous sign nailed to a tree "Crash Recovery, Bulk Rates 0419xxxx"
We wound in and around a medium level track for a while with enough overgrown branches to make the Hummer wince and carefully select his line until we came to a slightly downhill and long multiple deep rutted section which required very careful driving to prevent sliding off. I and all the other cars except the Hummer slid into deep mud ooze at least once but the Hummers extra wide track allowed it to be carefully guided right thru without an embarrassing moment. Impressive !
Image Could Not Be Found
Proceeding on, all of a sudden the track in front of me disappeared, a 3m deep
mud hole was in the track and it was just ooze.
Smelling a rat I backed out, I wouldn't dream of driving this and so we began a complex series of maneuvers up embankments to turn around 5 cars on this very narrow track.
The comp rangie had other ideas and figured he could drive through despite a large boulder right in the middle and so down he plunged.
To those standing back about 10m he completely disappeared below road level
before emerging victorious out the other side a lot wetter and mod splattered with a big grin.
Ok, that was one way and cost a couple of dents, but coming back would be up the near vertical drop off.
He tried hard with multiple attempts using every combination of traction but in the end had to call it.
Some went for a snatch strap but I didn't like this idea as the force required would be great and convinced the group to use the "Tank" instead.
Well the Hummer came into its own here and its huge bulk simply dragged the guttered lightweight Rangie out smoothly and cleanly with just a few rock scraps here and there.
On the way back we had to re-negotiate the bad slippery rutted section.
Somehow I got a perfect line and cleanly drove the rut tops then I pulled the 2nd Rangie out of an awkward angle it got itself on.
The Rangie driver doesn't like being hauled backwards by a Patrol, and in a previous incident had even tried to suggest he was pulling me during a late night bull session, so my wife made sure we got pictures with the reversing lights on this time.
Next was the Rodeo, good effort hear but with its leaf springs it cocked a wheel into the air just trying to enter the ruts but thinking this would happen we had fitted it with snatch straps in advance and I dragged it thru as well. The Hummer and the Comp rangie also followed, to easily for my liking.
On we pressed after doing the picnic thing for an hour to keep the girls happy.
Soon we were into a section that would end our day !
The normal Rangie was in front and entered a section of multiple bog-holes with bypass sections that had long since become bog holes themselves, maybe 10 all together.
No way around so the Rangie entered the sloop, both lockers on and painstaking nudged forward clawing inch by inch and slowly tilting until it was waist deep in mud.
Damm good effort actually but no good, it was stuck hard with its submerged exhaust bubbling and pushing up muddy clumps of ooze.
The driver got out via window but before we had a plan going forward, (love that management talk) up came the comp Rangie to help.
He dove into a parallel bog hole and was looking good until we heard
an awful noise and it stopped, not sure but a submerged log may have been rammed into the underbody.
Anyway he was almost out the other side with front wheels out and onto the flat ground when another bang occurred and his rear tyre deflated.
The massive traction combined with power of the 5.6lt P76 based V8 had been to much for the huge tyres and the rear passenger tyre rotated on the rim and ripped the valve out of the tube.
Two Range Rovers were now stuck fast in mud. Fully blocking the track.
We noted the time, it was now not far from 5 O'clock and the mosquitos were gathering to make the 12 intruders pay for straying into their swamp.
But both cars had winches !
We set up the first Rangies winch only to find if failed to engage under all the mud.
Back to the crippled comp rig, it had a great winch but required a complex setup with pulleys as the relative position of the cars meant we had to get the other car out first.
It was a struggle as we discovered we were pulling the Rangie into vertical wall and had to back off then dig out the leading edge of the hole.
While this was going on we sent off two teams , one to scout the road ahead and another to begin clearing a bypass track as this wasn't a good place to camp overnight.
Eventually we had them both dragged out and began to repair the damage.
Surprize, after nearly an hour idling with door seals under water the touring class Rangie seals had held and inside the car was clean.
Not so the comp rangie, it was wet muddy and dented.
A chainsaw was also needed to make a tall rough jacking plate, and off came the wheel.
I was actually carrying a spare tubeless tyre valve insert and they decided to fit
it as their spare wheel was a different size.
Someone slipped in the mud and the valve insert was dropped into the tyre and despite the delicate handwork of some lovely ladies it was unable to be found.
The spare wheel of wrong size and with a directional pattern running backwards
went on and at least made that car mobile, although it sounded like a scalded cat!
Team 1 reported that the track ahead was even worse and so again we had to turn around.
Team 2 had made a rough bypass and after some more difficult car shuffling we left the scene defeated again.
Now the Patrol and Hummer were the only cars not extracted so far and could have sorted out there differences right their and then but after 8 hours of almost non-stop track fighting neither of us had anything left and we just wanted out, so the whole group left the scene to procure some warm food and sort it out another day !
To be Continued.
Reply By: Out of here - Monday, Dec 07, 2009 at 19:54
Robin - Looks like too many vehicles use this track when it is wet :-) Also vehicles with large lift kits and tyres
Also I would never put my car in that much unless I had to - causes too much damage to the running gear.
Anyways I hope you had fun :-) Cheers
AnswerID: 394106
Follow Up By: Robin Miller - Tuesday, Dec 08, 2009 at 07:43
My feelings to OutofHere , only just got a dent near fuel filler pushed out by a paintless dent remover the previous week and when I slipped into one of those ruts you could hear the panel slap the side of a deep rut , hence I chickened out of the big hole , just to expensive !
FollowupID: 662391
Reply By: Member - Fred B (NT) - Monday, Dec 07, 2009 at 20:37
Hi Robin,
from the pics, it looks like the whole track is a man made "bear trap" for 4x4's.... lol..! Hope you had a good day. How many hours in the shower to get the mud off you? How many hours and $$$ at the car wash for the 'truck'? Slept like a log after it, did you?
regards
Fred B
VKS 737: Mobile/Selcall 1334
AnswerID: 394112
Follow Up By: Robin Miller - Monday, Dec 07, 2009 at 21:08
Pretty rough all right Fred , these were just mobile phone snaps , I believe some of the others action videos were a bit dramtic but haven't seen them yet we were kept busy with rescue equipment as most others were light on.
all made for a great day though !
FollowupID: 662338
Reply By: Member - Leigh (Vic) - Monday, Dec 07, 2009 at 20:51
Hi Robin
Would have expected to see Roothy at this event!! LOL.
AnswerID: 394115
Follow Up By: Robin Miller - Tuesday, Dec 08, 2009 at 07:39
That would be a setup Leigh, whereas this was just the way in panned out.
FollowupID: 662390
Reply By: Member - Captain (WA) - Monday, Dec 07, 2009 at 23:00
Hi Robin,
Yet another great write-up, much better than the stuff they have in the 4WD mags :) Now when are you going to do one on the 4.8GU vs 200TTD ;)
Captain
AnswerID: 394145
Follow Up By: Member - Beatit (QLD) - Tuesday, Dec 08, 2009 at 08:41
Captain and Robin,
I would second that! Pretty tired of reading comparo's (yes even use the mag language) of 3 litre Nissans up agains V8 cruisers.
Kind regards
FollowupID: 662398
Reply By: Member - Kroozer (WA) - Tuesday, Dec 08, 2009 at 02:42
Looks like beautiful country to drive through, although unfortunately by the looks and sounds of it the track is torn apart by mindless fools with there big wheels, big lifts, big egos etc. Rather selfish i reckon, gives the majority of 4wdrivers a bad name, and spoils it for the rest of us just so they can crack a fat.
AnswerID: 394158
Follow Up By: Robin Miller - Tuesday, Dec 08, 2009 at 07:38
If all places were like that I'd be agreeing Kroozer , but over here our local Parks people do worse than that , and in a real world you have to make room for everbodys interests , even those that don't believe in the obvious like global warming.
FollowupID: 662389
Follow Up By: Member - Paul M (VIC) - Tuesday, Dec 08, 2009 at 09:26
Robin says:
"but over here our local Parks people do worse than that"
Please explain?
FollowupID: 662406
Follow Up By: Robin Miller - Tuesday, Dec 08, 2009 at 09:49
Hi Paul
We have had a number of high profile cases in which tracks have been closed or diverted with excessive large scale earthworks over hundreds of meters which have resulted in downstream erosion and re-work.
Total eyesores that make you wonder what was in the minds of those controlling the bulldozers.
A single track through the bush like I have shown is confined to a relatively small area by comparison.
The excesses I refer to, like Dingo Hill, to have been the subject of articles and pictures in our 4wd associations and have been so prominent that they are referenced on maps like Rooftops Jameison/Licola 2004 etc.
FollowupID: 662412
Follow Up By: Member - Paul M (VIC) - Tuesday, Dec 08, 2009 at 10:24
OK, thanks
FollowupID: 662416
