Patrol Rear Suspension
Submitted: Monday, Dec 07, 2009 at 21:07
leeb1973
We have a 3.0L GU Patrol & will be towing a 24ft Jayco bunk van during the 2nd leg of our "around Oz" trip. We previously had an 18ft Jayco Expanda & travelled for 13 months during which time the back end of the Patrol has sagged quite a bit.
I want to get things right before we head off again but am undecided whether I should install new rear springs or air bags - one or the other or both - I'm not sure.
I'm interested to hear other people's opinions.
Ronnie
Reply By: Robin Miller - Monday, Dec 07, 2009 at 21:18
You should fit new or reset springs anyway Ronnie , then consider helper air bags , not full air bags.
Check all the weights / downforce first though to ensure you get right springs.
394120
Reply By: Mick O - Monday, Dec 07, 2009 at 21:27
Check your rear spring tower supports as
well. I don't imagine your vehicle has taken a pounding over corrugations towing a van but the weights can affect them adversly leading to cracking. There are a few companies/mechanics who strengthen them. I've had
mine done through ATOC Autos in
Melbourne's outer east.
Cheers Mick
394121
Reply By: Member - Graham H (QLD) - Monday, Dec 07, 2009 at 21:38
Is your Patrol an Auto or manual and what is the vans ATM as a 24ft would be
pretty heavy for an auto..
Might be part of the trouble.
A set of Progressive springs may be the answer.
I put them in my Cruiser and am really happy with the ride both full and empty.
394127
Reply By: Motherhen - Monday, Dec 07, 2009 at 21:40
We towed our heavy Bushtracker with our 3 litre Patrol and it rode
well. The Patrol did have a heavy duty
suspension when we bought it ex government.
With the F250 we made the decision to add airbags rather than an extra leaf to
the springs, as the latter would be a hard ride when not under load. We can adjust the airbags to suit the circumstance.
It sounds like you will be towing most of the time, so this may be the answer, but if it is already sagging,
the springs and/or shockies may need replacing first anyway. If in good condition, springs can be re-tempered.
394128
Reply By: Member - Andrew (WA) - Tuesday, Dec 08, 2009 at 00:50
I had a GU for 5 years and travelled around the paddock for 3 months towing a pop up van (about 1500kg's)
I had poly airbags in the rear and highly recommend them. Never an issue, kept the rear end level and no more 'bottoming out' over grids etc.
You can always put in the air bags and see how you go. If you need more support, upgrade
the springs if necessary, the bags just go back in anyway.
Good luck.
394155
