Sun Damage to Awning
Submitted: Tuesday, Dec 08, 2009 at 18:29
PeterInSa
Have a dark Green Dom tic Awning, 4 or so years old, sometime ago came across a van with a similar size awning around 5m with sun damage to the top of the awning when in the rolled up position. I suggested to the owner he just cut the last 30cm off the awning etc, but with an annex this was not an option.
We have our van under cover (plastic roof that stops 99% Ha Ha Sun Light etc.) and want to prevent sun damage to the awning . Thinking about a long curtain with a 50cm drop held up by white electrical conduit laying on the van roof.
Then again the awning shows no
sign of damage after 4+ years is it worth the bother.
Comments appreciated.
Reply By: Member - Kevin B1 (WA) - Tuesday, Dec 08, 2009 at 19:36
Our Van lives outside and has been for five years now, I treat the exposed section of awning with Armour all. It has become a bit discoloured but still seems OK, you can get a new section welded in if need be.
394255
Reply By: Member - Graham H (QLD) - Tuesday, Dec 08, 2009 at 20:08
Get a sail track above the awning and get a little cover made for it when its rolled up.
When you pull it out it will just push it up.
Some vans have metal ones .
394266
Reply By: Member - Carl and Pamela - Wednesday, Dec 09, 2009 at 08:12
Hi Peter,
I used to make caravan awnings before I retired.
The first thing to go will be the cotton stitching not the PVC of the awning. Once this happens it's stuffed.
Carl
394332
