Holden Frontera Dual Battery and Trailer Electronic Brake Controller
Submitted: Tuesday, Dec 08, 2009 at 19:21
ROGER G
Hi All
Doing it myself and need some advice.
The last thing to do on my Electronic brake controller is to tap into the brake light switch with the instructions stating the cold or switched side.
Would I need to tap into the wire coming from the battery or after the switch that is going to the tail light etc.
Dual Battery
I was after the best / easiest point to attach the wire that goes to the on position of the ignition switch. Personally I was thinking the ignition relay switch in the box next to the original battery.
for any help in advance
Reply By: Member - Toyocrusa (NSW) - Tuesday, Dec 08, 2009 at 20:22
Hi Roger. You would need to tap into the wire that activates the BRAKELIGHTS. If you have a combination Cruise Control/ Brakelight switch it may take a bit to work it out. If not it will be the wire from the switch that activates AFTER the pedal is depressed. You may need the ignition on. See if your brakelights work without the key on first. Regards,Bob.
394272
Reply By: Member - Graham H (QLD) - Tuesday, Dec 08, 2009 at 20:22
Think about it If its coming from the battery it will have power ALL the time wont it
The cold side is AFTER the switch You need a multimeter to be sure
Dual Battery
Usually you can tap into a wire on the wiper motor to get power.
What sort of a Battery controller is it A Redarc doesnt need any power other than the batteries.
It has a blue wire which is for hooking the two batteries together by pressing a switch on the dash
If you are so unsure perhaps a sparky is the go.
394273
