Which battery charger setting should I be using?
Submitted: Thursday, Dec 10, 2009 at 09:07
ThreadID: 74304 Views:3781 Replies:5 FollowUps:1
I have one of these batteries (link below) - Picture at the top has 6 batteries in it and mine is the one in the middle on the right hand side. Commander 100 ah.
Batteries
Is this a wet cell battery? My 7 stage charger has several charging options - wet, gel, AGM and calcium. Which one should I be using.
The charger is an IC1500 Prjector 7 stage 15 amp.
Reply By: Mandrake's Solar Power- Thursday, Dec 10, 2009 at 09:50
Looks like there is an access panel between the terminals ?? which would suggest a wet cell type ? Reasonably sure its not Calcium or AGM ... Wet or Gel ?
Rgds
Mandrake
AnswerID: 394474
Reply By: Tenpounder (SA) - Thursday, Dec 10, 2009 at 10:10
Hi there. I've read the brochure, and there's no mention of calcium. The batteries are described in terms of deep cycle but with cranking ability: if so, they are pretty well what I have been using for years in boats, ie not a 'pure' deep cycle, but a deliberate compromise. I have used them as second batteries in 4WD as well, because I was told they can stand a bit more drawing down, but can still be used as cranking batteries if needed. The batteries are wet; not gel or AGM; and not calcium as far as I can read. So I suggest you use the 'wet' option. If you use the calcium setting, then my understanding is that this will apply too high a voltage.
Please understand I am not trying to be the expert, but just passing on my best understanding after a few false starts over the years, including buying wrong batteries on what I though was informed advice!!!!
AnswerID: 394476
Follow Up By: Grass Parrot - Thursday, Dec 10, 2009 at 10:23
Thanks Chris. You sound just like me, Have made some errors with batteries over the years with the same so called advice. I was thinking wet myself as they have water in them and need to be topped up on accaissions - I was using common sense more than anything but sometimes that is not always right.
FollowupID: 662782
Reply By: Fatso - Thursday, Dec 10, 2009 at 13:38
G'day Grass Parrot
I googled up the model of one of my batteries once & was quite surprised just how much info the manufacturer supplied.
What got me the most was my lack of knowledge of charging. The manufacturer gave a charging schedule for the particular battery.
I thought my 4 amp charger would charge it eventually. Manufacturer said it needed a minimum of 10 amps & would take some (i forget exactly how long) incredible amount of time to fully charge.
I would recommend you google your model of battery & see what you come up with.
AnswerID: 394494
Reply By: Member - Ian W (NSW) - Thursday, Dec 10, 2009 at 15:46
Grass Parrot,
Using the link you provided I blew the image out to 200%.
Looking at the illustrations/photos at that magnification I would say you have a wet cell battery.
Regards,
Ian
AnswerID: 394504
Reply By: ob - Thursday, Dec 10, 2009 at 19:30
Hi Grass Parrot,
Have a look at thread 74125 I asked this same question and got what in my estimation was some very good advice
ob
AnswerID: 394532
