caravan suspensiono
Submitted: Friday, Dec 11, 2009 at 21:10
Member - Duane A (WA)
Any one out there have cruise master air bag
suspension on your vans if so whats the gaff any for,s and against,s would be great cheers. keep it safe and all the best to all for the festive season.
Reply By: Member - Royce- Friday, Dec 11, 2009 at 21:13
Is that an Italian
suspension?
394680
Reply By: Member - Duane A (WA) - Friday, Dec 11, 2009 at 21:26
Thats
Suspension people not the italian gear suspensiono .
394682
Reply By: Member - Graham H (QLD) - Saturday, Dec 12, 2009 at 08:45
Ring Richard at Queenland Coromal in Learjet drive in Caboolture
He is building a van with that
suspension so I guess it must be OK
Hes the Parts Manager
394733
Reply By: Member - Toyocrusa (NSW) - Saturday, Dec 12, 2009 at 21:27
Hi. My brother has it fitted to a 24ft Boroma Van. Has covered over 30000 Klm so far without any problems. It is adjustable for height so if you have a side slope you can let the high side down. It can be set low when long term
camping. It takes a bit of
battery power to run the compressor to lift it back up again but his van has two 120 Amp/hour batteries. If you are getting an annex made you need to have the van at your normal stationary height so that the height of the annex walls fit correctly. The internal ride for the van contents is superior as
well. Regards,Bob
394822
Reply By: bob&loz - Saturday, Dec 12, 2009 at 23:31
Hi Duane
We have this
suspension on our van and love it.
it gives everything in the van a soft ride and having 2 trailing arms has no jarring transmitted to the van or tug when hitting potholes or bumps.
Is great for setting up on sloping sites, drop one side and raise the other.
If on flat sites you can drop it onto the bump stops for stability.
We travel as much on dirt roads as we can and have not had any problems with it
394833
Reply By: JAX W - Sunday, Dec 13, 2009 at 11:47
Hullo Duane
We have the fully automatic Cruisemaster Air
Suspension fitted to our van which we took delivery of in July, 2008. We have now travelled about 20,000km.
Prior to this van we had a Golf with fully automatic air
suspension for nine years. Personally I would not have anything else!! If you can afford it go for the fully automatic system. It is at the top of my list of "must haves" in a van. Second would probably be disc brakes, which are fitted to our current van.
Good luck with your deliberations.
Regards, JAX
394866
Reply By: lozza - Sunday, Dec 13, 2009 at 18:39
I have airbag
suspension in a
Southern Cross 22ft van,fantastic the air
suspension and the van.
The actual airbags and compressor and auto system is imported and supplied by the AIRBAG MAN great people to deal with.
394913
