Saturday, Dec 12, 2009 at 18:51
Hi Derek
Thanks for your reply. The battery management system is one of yours a DBi-120.
The aux battery is immediately adjacent to the original battery and connected via sufficient size large cable ( from memory 8mm maybe 10mm but it is was the cable supplied by you with knowledge of the project and vehicle at the time and so I am sure it is adequate)
I also have two other batteries (AGM deep cycle 100ah) under the tray which are also managed / connected via another DBi-120 between the aux and themselves (connected by starter size cable)....which in turn are also managed by a Plasmatronics PL20 solar controller (including shunt for the alternator charge) with 2 x 64 w uni solar on the roof of the canopy!
These two under tray batteries are managed by the PL20 as far as load and LV cut out and are about 5 years old now (from previous vehicle and still working fine)
so a bit of a power house really but over the years I have learnt about being under powered, under cabled and under storage capacity!
The low voltage cut off has for almost from the beginning (Feb 08)disconnected if the vehicle is parked for longer than maybe a week.......something that confused me but I never got around to testing the damn thing until very recently..........discovered that on standby it (the LVCO)is drawing 0.25a (two LED and whatever is chewing it up inside as
well)..........I rang the manufaturers (12 volt
shop - Arrid) and asked innocently what the stand by current draw was and they said they did not know!
I have isolated all circuits and very satisified that the only load on standby is the LV cut out....
in theory this stand by load should have done the battery more good than harm by cycling it?...OR WHAT HAS JUST OCCURED to me as I type
It has continued to draw current on stand by and whilst cutting off the aux circuit has continued to draw down the aux battery and stuffed it. ? 7 days x 24 hours at 0.25ah is = 42a ! and there has been periods exceeding 7 days parked up...JUST MAYBE i HAVE ANSWERED MY OWN QUESTION??
I made an assumption that the battery was fully charged because of
a) the long drive as mentioned at the start
b) the measured voltage about 1 hour after the final drive at the end of the day (12.6v)
c) I measured battery voltage after about 1 hour of the sound system and was
well below 12v.and the sound system dropped out at 10.7V (may have been a bit below that because I lost 2 or 3 mins before i managed to test the battery
your comments appreciated
Graeme
663146
