Israelite Bay - Cape Arid NP
Submitted: Monday, Dec 14, 2009 at 08:40
Plasnart
Hi all,
Just wondering if someone could give me an update on recent track conditions into
Israelite Bay? I am considering a trip over there in early January and would like to know how the conditions are at present.
I am planning on travelling in a single vehicle also. Those of you with experience in this part of the world, would you please let me know if this is unadvisable or is single vehicle access common in this area?
I have read some previous posts on access into this area and seems most nasty track conditions occur in the winter. Am I right in saying this?
Thanks for any info provided.
Rohan.
Reply By: Willem - Monday, Dec 14, 2009 at 08:56
Rohan
If you are travelling along Fisheries Road then the track isn't that bad at all. Single vehicle will be fine. It is due to the texture of the soil (bulldust) that some humungous holes have been formed along the track. In winter they fill with
water and anyone driving in to them could be in trouble. Steer clear of the holes and you will be OK. Also stay off the seaweed at
Israelite Bay as it can be very deceptive and up to 2 metres deep. Keep tyre pressures low on the sandy bits
394972
Reply By: Member - Kevin B1 (WA) - Monday, Dec 14, 2009 at 12:12
From reading your post I take it you are heading over from the east. If so you can get to
Israelite bay from Balladonia. The track is just east of the roadhouse and is marked as Balladonia Road. The track to
Israelite bay forks off it and takes you past Mt Raggard to join the Fisheries Road track. I have travelled that area a few times and you should have no problems in January,it's only when there has been heavy rain in the area that the tracks become a bit boggy.
394988
Follow Up By: Member - John Baas (WA) - Monday, Dec 14, 2009 at 12:20
Hi Rohan, the
ranger at Cape Arid NP would be the source for absolutely up todate before you go. We were in the area in Feb this year and the track down from Balladonia was closed due to previous cyclonic rains, athough the track in from the west was open.
There is also 4WD access from the east - see Nuytsland trek on this site.
Cheers.
663400
Reply By: Member - Phil B (WA) - Monday, Dec 14, 2009 at 12:42
Hi Rohan
In Oct my wife and I towed our CT from Balladonia via Mt ragged to Israelite then took the fisheries Rd to
Esperance - no issues at all, just the usual corros, ruts, rocky and or washed out sections. The track completely dry.
You'll have no probs.
394993
Reply By: Plasnart - Monday, Dec 14, 2009 at 13:21
Thanks for the info so far everyone.
Yes I should have been more specific on my intended route: I am coming over from East so I do intend to use the road south from Balladonia. The replies so far have given me some comfort that the tracks are not too trecherous as long as I follow normal safe driving protocol. I'll contact the
ranger too to see what he/she has to say.
The route to the east from
Israelite Bay also interests me, however being a solo vehicle I will err on the side of caution should any track be deemed "challenging". If anyone else has travelled the track out to the east I would love to hear about it.
Thanks for the info so far, much appreciated.
Rohan.
394996
Follow Up By: get outmore - Monday, Dec 14, 2009 at 16:40
done both tracks several times although not recently. Even after moderate amounts of rain the saltpans between israilite and pt
malcolm are fine as long as you stik to the eastablished track.
the balladonia to israelite track gets very limestoney at the southern end making it rough as opposed to challenging
there is a fair bit to see on this track so allow time
heres a trip report
Balladonia to cape arid
and heres a report that includes Isralite to cape arid although i followed the coast as much as possible rather than just the telegraph track (main track)
South east Coast
663433
Reply By: Member - joc45 (WA) - Monday, Dec 14, 2009 at 13:28
Hi Rohan,
Was out there in Nov/Dec last year, and was unlucky enough to have lots of unseasonal rain, so the Fisheries Road had lots of mudholes. There are tracks around the deep ones, tho, and we had no troubles. Just read the conditions and you'll be right.
Be careful of the salt lakes out there when wet. The telegraph track from Pt
Malcolm to Cape Arid passes thru one, and the track from
Israelite Bay to Pt
Malcolm on the coast also passes alongside one. Both can be very sticky after the rain. If travelling down to Pt
Malcolm after rain, take the track there on the western side of the
salt lake from
the junction of Fisheries Road and Tookle-Jenna Rock (as marked on the 250k topo). As you travel into
Israelite Bay, the Fisheries Road passes around the north edge of a large
salt lake. This is usually ok, even after rain, but again, read the conditions.
Pt
Malcolm is the better spot than Israelite to
camp, as there is wind shelter, shade and the
campsite doesn't get flooded after rain. Also food fresh
water avail from a small
bore there in the dunes and good fishing spots off the southern tip, whereas Israelite is just deep seaweed on
the beach.
If travelling north from Israelite, the track thru Tookle-Jenna Rock is rough but ok, whereas the track from Israelite directly westwards to
Sheoaks Hill can get quite sticky after rain (tho we did get thru!).
Done the area a few times, so drop me a line if any further queries: gezza90 at amnet dot net dot a u.
cheers, Gerry
394997
