clutch burning smell
Submitted: Monday, Dec 14, 2009 at 15:46
ThreadID: 74395 Views:2922 Replies:5 FollowUps:1
For the last couple of days the clutch on my 78 fj40 smells in the first or reverse gear momentarily and it seems to be all good after that no slipping or loss of power that I can feel.
Is that mean it's about to go and I should look into replacement or does it need adjustment or something? also any ideas on the costing if it needs replacement?
any help is much appreciated
Reply By: Member - Tour Boy ( Bundy QLD) - Monday, Dec 14, 2009 at 16:49
It may have a slightly pressureised slave cylinder that releases after a couple of presses of the pedal.
Try pumping the clutch pedal a dozen times after you start the car and see if it does it then when you do the reverse forward thing.
If it was on the way out it would do it all the time. or slip when you put your boot into it when driving.
Dave
Dave
2015 Fortuner
Had 72 cruisers in my time
AnswerID: 395019
Reply By: Member - ross m (WA) - Monday, Dec 14, 2009 at 20:19
A quailty clutch kit would be $400-500 and about 5-7 hrs labour. You may need to get the flywheel machined,$60.
You wont have much left out of a grand.
AnswerID: 395056
Reply By: Member - Andrew L (QLD) - Monday, Dec 14, 2009 at 21:10
(For the last couple of days the clutch on my 78 fj40 smells in the first or reverse gear momentarily and it seems to be all good after that no slipping or loss of power that I can feel.)
Simple answer there...a gearbox is a torque multiplier from the highest gear down to 1st gear, and reverse is even a lower speed (higher) ratio than 1st gear, so I would suggest that you do have clutch/pressure plate slippage in 1st and reverse, and that is the gears that have the most torque multiplication from the engine crankshaft/flywheel.
Time for a new clutch kit and flywheel maching I think.
AnswerID: 395068
Reply By: VR62GT - Tuesday, Dec 15, 2009 at 11:47
Thanks for all the replies, I'll give the pumping a shot see how that goes, I am not sure if it'll take me through the holiday break or not.
I am hoping to have a bit of fun during the X-mas break.
AnswerID: 395134
Follow Up By: Moose - Tuesday, Dec 15, 2009 at 14:51
You will not have much fun if it packs it in somewhere remote!
Sounds like it is on the way out and if so you'll find it will be even worse in low range.
FollowupID: 663581
Reply By: VR62GT - Tuesday, Dec 15, 2009 at 15:12
I am starting to have the same conclusion, last thing I want is to get stock in the middle of nowhere specially when I have had a bit of warning before hand, I am gonna ring around for pricing and availability, not the best time of the year for this sort of job I guess.
AnswerID: 395148
