Car speaker help
Submitted: Friday, Dec 18, 2009 at 11:31
Member - lyndon NT
Hi All
I am trying to find some speakers to put in the rear of my troopy. Don't want to cut the door trim to fit them there.
Looking at mounting them up high in the rear. need to be of good quality with strong brackets. have see some at Wow in
darwin but they are a bit big, made for marine. Picture should give an idea of the shape I am looking for, rectangular box type.
Thanks Lyndon
Site Link
Reply By: offroad_tommo - Friday, Dec 18, 2009 at 11:55
Hi Lyndon,
I had the exact same problem mate.
I picked up a couple of second hand rectangular Boss speakers. I just place them in the back on my false floor. They do the job really
well but I found they had that backgound static. This may have been due to the ouput of the head unit not matching the speakers as when I added an amplifier they cleared right up and now sound fantastic.
You will find you can use just about use any speaker, so long as it has the pos/neg conection to your head unit.
395579
Follow Up By: Member - lyndon NT - Friday, Dec 18, 2009 at 12:41
I have very high drawers in the back and also pack stuff either side, this really only leaves me with the option of roof mounts.
Just don't want something crappy or the size of a shoe box!
What did you have to pay for an amp? Wasn't really thinking of going that far.
Cheers lyndon
664131
Follow Up By: offroad_tommo - Friday, Dec 18, 2009 at 14:40
Yeh ive been looking at mounting them on the roof as
well, was at
Darwin jaycar not long ago, they seem to have a range of universal type speaker mounts, so they could easily be attached to the roof.
In terms of the amp, Im an el'cheapo with my audio gear so I got it second hand but $200 will get you a good amp, possibly even cheaper. Many of these more expensive amps are only really needed if you want a home theatre package like system in your car.
My boss speakers are about the size of a brick, and they sound fantastic.Outdoor speakers are probaly the safest option though, unless its an area where the speakers arent affected by the elements.
664154
Reply By: MrBitchi (QLD) - Friday, Dec 18, 2009 at 12:37
Try Dick Smith. Ask for their outdoor speakers.
Dick Smith speakers
395584
Follow Up By: Member - lyndon NT - Friday, Dec 18, 2009 at 12:45
Thanks mate. Wow, they are 3.5 kg's each! Pity they didn't list dimentions, they look pretty big. Will be happy to pay more for a small quality set.
Thanks for your input.
Lyndon
664134
Follow Up By: MrBitchi (QLD) - Friday, Dec 18, 2009 at 13:10
Hmm...
"Cabinet size : 145 mm (W) x 202 mm (H) x 121 mm (D)"
664139
Follow Up By: MrBitchi (QLD) - Friday, Dec 18, 2009 at 13:13
FWIW, you don't want "small" speakers in the back. They will sound like cr@p. These would go about the same size as a standard 6"x9" speaker.
664141
Reply By: Tenpounder (SA) - Friday, Dec 18, 2009 at 12:48
Hi there. I have bought speakers from Jaycar: they hold a good range, various types of enclosures as
well as speakers, ranging from cheap to quite expensive for top of the range performance. Their catalogue also contains lots of data to help in selection. I've got $800 worth of their speakers in my lounge room - great performance!! Hope this helps.
And yes, I've checked, there's one in
Darwin now!
395586
Jaycar is good. Didn't think they had a store in
Darwin..
664142
Reply By: Member - John and Val - Friday, Dec 18, 2009 at 13:58
Lyndon, have a look at our
Troopy speakers. John made up the enclosures and put a reasonable quality speaker in them. They have worked very
well and do not get in the way - as you can see we sleep in the back of our troopy.
Val
| J and V
- Albert Einstein
395589
Follow Up By: Member - lyndon NT - Friday, Dec 18, 2009 at 15:05
Thanks Val. Very interesting, please send me two :-) Unfortunately I don't have the
tools to knock those up. I have a cargo barrier I was thinking of mounting them too. Main problem is the speaker would be three inches from my head!
Cheers Lyndon
664160
Follow Up By: Member - sdr00y (Beecroft,NSW) - Friday, Dec 18, 2009 at 15:19
Having speakers 3 inches from your head should not be a problem, you only need the volume down low then!
But seriously, My troopy has some brackets in the back corners which I guess may have been speakers from the original owner. Will take a pic tonight (hopefully) and post for you.
664166
Follow Up By: Member - John and Val - Friday, Dec 18, 2009 at 15:35
Lyndon, as above, having the speakers close to your head has not been a problem for us, either in terms of sound or hitting head. As said above, not necessary to wind the volume up too much, and when on gravel its just possible to hear the radio!
Val
| J and V
- Albert Einstein
664170
Reply By: Member - Fred B (NT) - Friday, Dec 18, 2009 at 18:26
Hi Lyndon,
Autobarn on bagot road (and Jaycar is a little further up the same road) usually carry a large range of car audio speakers. I haven't been there for awhile so don't know what they have now.
Also see Sound Spectrum 51 Stuart Hwy Stuart
Park 89815060, OR, talk to Carcom Installations 14 Bishop St Woolner 89418800.
regards,
395625
Reply By: Member - Doug T (NT) - Friday, Dec 18, 2009 at 20:26
Seems your all into size and stremgth, fair enough, but don't forget the Ohms, if the radio is designed to run 8 Ohm speakers then make sure you buy 8 Ohm speakers,
And why not fit them into the doors, that's where
mine are, and have been for the last 8 years without any problems.
395641
Reply By: Member - Allan B (QLD) - Saturday, Dec 19, 2009 at 17:29
Lyndon,
Like Doug says, be sure to match the speaker impedance to the amplifier or radio.
Almost certainly your existing amplifier will be 4 ohms impedance whereas speakers intended for mains-operated systems will be 8 ohms impedance. The reason for 4 ohm in auto application is because of the limits of the 12v supply.
The speakers you referenced on Ebay are rated 8 ohms, as would be most "outdoor" speakers and if connected to a 4 ohm amplifier will have severely limited output and reduced sound quality. (That may be a good thing for your ears LOL)
The safest bet is to go to a Car Audio dealer but could be more expensive than Ebay. I don't believe Jaycar stock enclosed speakers suitable for mounting in the vehicle. Only bare speaker drivers of 4 ohm impedance where you would need to provide your own enclosures.
395699
Reply By: Member - lyndon NT - Sunday, Jan 03, 2010 at 10:50
Hi All
Thanks for all the info above. Have yet to make a purchase. Happy new year to all.
Lyndon & Bernadette
397413
