any one use battery rujuvenators
Submitted: Sunday, Dec 20, 2009 at 17:29
ThreadID: 74536 Views:3705 Replies:8 FollowUps:17
looking at battery de sulphator and has any one used them or are they just another gimmick like the fuel saving devices .on ebay they sell for $52 and i spend alot of money on battery,s mostly my fault due to not looking after them properly and i have decided to educate myself on battery care and maintenance from now on.
Reply By: Austravel - Sunday, Dec 20, 2009 at 17:35
If you mean the pulse type then the theroy is sound and used by many standard chargers now. I have one permanently mounted but how do you know if it's made any difference. For the $ it was worth putting on and forgetting. I think the megapulse was one if not the first to put one out and was tested by CSIRO (I thinks), with good results.
AnswerID: 395846
Follow Up By: Member - warren G (VIC) - Sunday, Dec 20, 2009 at 18:12
i dont think so. it takes power from the battery and sends it back as a surge i think the surge then dislodges the sulphate that has built up on the plates thus giving life back into a battery that wont hold charge .my reading of the item does not charge the battery i think.cheers warren
FollowupID: 664501
Follow Up By: Member - warren G (VIC) - Sunday, Dec 20, 2009 at 18:15
sorry but a pulse might be another term for surge
FollowupID: 664502
Follow Up By: Austravel - Sunday, Dec 20, 2009 at 18:23
yep that's the one.
FollowupID: 664505
Follow Up By: Maîneÿ . . .- Sunday, Dec 20, 2009 at 22:11
I suggest "Megapulse works" on 12v batteries
as is stated on their website
Maîneÿ . . .
FollowupID: 664539
Follow Up By: Top End Explorer - Monday, Dec 21, 2009 at 17:41
Yeah but Mainey you think Hiclones work. LOL
just teasing Steve.
FollowupID: 664652
Follow Up By: Maîneÿ . . .- Monday, Dec 21, 2009 at 19:12
Steve, (good to see you back)
yep and untill someone can actually prove beyond any reasonable doubt they don't work, I will leave my two where they are :) :)
Maîneÿ . . .
FollowupID: 664666
Reply By: outsider - Sunday, Dec 20, 2009 at 17:55
I heard a story once about some farmer that hooked his stuffed battery up to the electric fence for a week or so and it came good.
something about the HV pulse that removes the sulfate.
AnswerID: 395848
Follow Up By: Member - joc45 (WA) - Sunday, Dec 20, 2009 at 19:11
Only problem was that all his cattle got out while the battery was across the fence :-)
FollowupID: 664510
Reply By: qubert - Sunday, Dec 20, 2009 at 22:32
just buy oddesey battery. 4 years warrantee
AnswerID: 395882
Follow Up By: Maîneÿ . . .- Sunday, Dec 20, 2009 at 22:52
At what price $$$
the largest I could see on their web site was only 44 ah
Their warranty is fairly extreme too
GENERAL PROVISIONS:
Manufacturer has no obligation under the limited warranty set forth above in the event the Battery is damaged or destroyed as a result of one or more of the following:
• Willful abuse or neglect or if the top decorative cover has been removed.
• Natural forces such as wind, lightning, hail; damage due to fire, collision, explosion, vandalism, theft, penetration or opening of the Battery case in any manner.
• Overcharging, undercharging, charging or installing in reverse polarity, improper maintenance, allowing the Battery to be deeply discharged via a parasitic load or mishandling of the Battery such as but not limited to using the terminals for lifting or carrying the Battery. Trickle chargers that do not have a regulated trickle charge voltage between 13.5V and 13.8V (no lower than 13.5V and no higher than 13.8V) will cause early failure of the Battery. Use of such chargers with the Battery will also void the Battery’s warranty.
• Failure to properly install the Battery or lack of metal jacket for high temperature or vibration applications.
• Normal deterioration in the electrical qualities or the acceleration of such deterioration due to conditions that accelerate such deterioration.
• If the Battery is used for an application that requires higher cranking power or a greater reserve rating than the Battery is designed to deliver, or the Battery capacity is less than the Battery capacity specified by the vehicle manufacturer, or the Battery is otherwise used in applications for which it was not designed.
• Prolonged storage of vehicles with fuel injection computers, alarms, GPS and other electrical devices that require continuous battery power to support active memories; this power drain must be offset with a maintenance-float charger, periodic charging or disconnecting the battery to prevent the establishment of irreversible crystallized sulphation in the battery plate oxide.
Failure to address this destroys battery capacity and voids the warranty, as this is not a warranted defect in materials or workmanship. A battery with an open circuit voltage (OCV) of equal to or less then 10.0V will be deemed as overdischarged and void from warranty due to misuse and/or neglect
To obtain warranty service:
1. Return the Battery to any authorized ODYSSEY battery wholesaler or dealer.
2. If the Battery is determined by Manufacturer, in its sole discretion, to be defective for material or workmanship under terms of this limited warranty, it will be replaced.
3. Manufacturer's acceptance of any items shipped to Manufacturer shall not be deemed an admission that the items so shipped are defective. Any items shipped back to Manufacturer, shall in Manufacturer’s sole discretion, become Manufacturer’s sole property
Maîneÿ . . .
FollowupID: 664555
Follow Up By: Member - Josh (TAS) - Monday, Dec 21, 2009 at 08:53
With a warranty like that I think getting it replaced would be near impossible. That gives them every way possible to get out of it. What ever happened to if it's broke we will fix it.
Josh
FollowupID: 664584
Follow Up By: CJ - Monday, Dec 21, 2009 at 09:47
Yes but is that very different to other batteries and/or products. Read any product disclosure sheet and you will find similar disclaimers. Don't think it is fair to single out the Oddessy...
That said I believe it is overpriced compared to other AGM's out there
CJ
FollowupID: 664589
Follow Up By: Maîneÿ . . .- Monday, Dec 21, 2009 at 11:16
Definitely overpriced and at only 44ah is hopelessly underpowered too :)
Maîneÿ . . .
FollowupID: 664603
Follow Up By: Member - warren G (VIC) - Monday, Dec 21, 2009 at 18:11
i have used odessy before in my gt falcon it was some time ago but i think it was orange and a metal case .looked great but was crap
FollowupID: 664658
Reply By: Geoff (Newcastle, NSW) - Monday, Dec 21, 2009 at 11:28
Hi Warren,
My mate has a Megapulse on his battery.
He bought and fitted it about 2 months ago. About the time he was having troubles with his nearly 4 year old starter battery in his Landcruiser, the battery he fitted it to is the factory fitted unit in a 79 Series.
On Saturday he went and bought a new AC Delco selaed maintenance free battery.
I suspect the Megapulse was way to late to have any influence on this battery. We'll have to wait and see how he gets on with this one.
One thing I have noticed is it puts a high pitched whistle into the Landcruiser Radio when tuned to AM. If you remove the fuse from the Megapulse the whitle goes away.
Bloody annoying when you're trying to listen to the cricket!
The theory behind the units is sound and proven electrical technology. The recent developments in 3 to 7 stage chargers employs the same pulse to de-sulphate batteries during their float mode.
Geoff
Geoff,
AnswerID: 395923
Follow Up By: Member - Rob S (NSW) - Monday, Dec 21, 2009 at 17:34
This is from the user guide
Pulsing DC current produced by this product may interfere with the correct operation of some
electronic devices when the unit is placed near the antenna. Install the unit away from the antenna.
I only ever made one mistake
FollowupID: 664651
Follow Up By: Geoff (Newcastle, NSW) - Monday, Dec 21, 2009 at 17:47
Thanks Rob,
That's somewhat of a challenge in a 7x Series Landcruiser!
The battery and the radio aerial are both mounted in the LH side mudguard of the vehicle.
I do hope my post suggested I am definitely in favour of the technology.
Thanks again for the information,
Geoff
Geoff,
FollowupID: 664654
Reply By: dbish - Monday, Dec 21, 2009 at 13:12
In stead of waiting untill batterys have sulphated why not fit 5Watt solar panell. I have numerousbatterys in vehicles & boat that dont get used very often all N70ZZ $100 batterys the oldest is 10Yrs still good but 50% capacity. This system is relativy cheep & works only cost is initial purchase. Cheers Daryl
AnswerID: 395937
Reply By: Member - Rob S (NSW) - Monday, Dec 21, 2009 at 17:43
I Have had a megpulse connected to my aux for a few months now.
and have noticed the plates appear to cleaner than previous.
they won't fix a stuffed battery but claim to keep good ones going longer.
Google battery Sulphation more info out there.
Site Link Megapulse.
Rob
AnswerID: 395966
Reply By: Member - Bucky - Tuesday, Dec 22, 2009 at 04:38
warren
Wouldn't Inox battery conditioner do the same thing ?
$10-$12 from my recolection.
From most car accessory joints... autobahn.. supercheep...ect
or .. am I missing the point here ?
Bucky
AnswerID: 396013
Follow Up By: Member - warren G (VIC) - Tuesday, Dec 22, 2009 at 16:54
the only thing that is for sure bucky is that most of my battery problems have been self inflicked. but having said that i will check out the product.cheers warren
FollowupID: 664786
Follow Up By: Alloy c/t - Tuesday, Dec 22, 2009 at 17:56
Inox battery conditioner may work to slow down sulfation in a new battery but just pouring the stuff into a battery that is already sulfated will just hasten its inevitable demise , all the garbage on the plates falls off and collects as a sludge at the bottom between the plates efectively shorting the plates , one dead battery.
FollowupID: 664796
Reply By: Member - Bucky - Wednesday, Dec 23, 2009 at 06:10
Too true, but I have had it work miracles, then the next time up for a new battery.
Do not think that there is no sure fire cure, once the degredation problem starts, then it's just a matter of time.
Bucky
AnswerID: 396145
Follow Up By: Maîneÿ . . .- Wednesday, Dec 23, 2009 at 09:46
Bucky,
I believe you will find if you fit a Megapulse to a new or near new battery, the battery will not form the degradation problem of sulphation crystals to start with.
Your battery will then have clean plates and give good performance.
My first Deep Cycle battery lasted 6 years with a Megapulse fitted, when my Cranking battery died, the DC was put in there to be the cranking battery for the duration as I replaced wetcells with AGM's for storage batteries and I put another Meggapulse in with the two of them too.
(They required a different model Megapulse unit, I put the original Megapulse to the cranking battery)
Maîneÿ . . .
FollowupID: 664871
