A question for a 'fridge-ologist' ??
Submitted: Monday, Dec 21, 2009 at 09:49
signman
What would be an 'average' cycling (percentage) for an 'average' compressor type 12v fridge??
The fridge in question is an Engel 80l upright (drawing rated at 2.5 amps).
I realize the parameters are broad- from say FNQ in the middle of summer (where I DON'T intend to be), or Tassie in the middle of winter (where I DON'T intend to be).
I'm working out my power requirements at this stage !!
Reply By: ctaplin - Monday, Dec 21, 2009 at 10:04
I also have an 80litre upright Engel and they draw closer to 3.5 amps rather than the 2.5amps that the latest 40litre units draw.
Up here in Gove NT, I reckon the fridge would be on at least 50% of the time but perhaps you could work out you figures based on 30% of the time if you're mostly down south in cooler climate.
Chris
395912
Reply By: Mandrake's Solar Power- Monday, Dec 21, 2009 at 10:36
It also depends on the temperature its set at ... Works harder as a freezer than fridge ... I worked on 8 hours per day at maximum for my Solar Calculator .
Rgds
Mandrake
395915
Reply By: Grizzle - Monday, Dec 21, 2009 at 12:27
I have a Waeco CF50 and do all of my calcs based on 2 amps every hour ie 48 amps per day regardless of duty cycle. This has proved itself during trips etc. My fridge draws around 4 amps when running.
Rough guide but good enough.
395928
Reply By: Rod - Tuesday, Dec 22, 2009 at 20:17
My Evakool 60L fridge/freezer runs 36% of the time in an ambient temp of 28 degrees.
* Contents were prechilled
* Fridge was set quite cool with freezer sitting between -11 and -18
* Test was conducted over an hour period
I now run the fridge slightly warmer and expect slightly less run times.
396109
Follow Up By: Member - Mike DID - Wednesday, Dec 23, 2009 at 09:13
Was that test hour during the hottest part of the day; cool morning; or cold night.
It will make a big difference.
To get an average you really need to run it for at least 24 hours.
664864
Follow Up By: Rod - Wednesday, Dec 23, 2009 at 10:49
It was an ambient temperature of 28 degrees during the test
664879
Follow Up By: Rod - Wednesday, Dec 23, 2009 at 10:54
Agree 24 hour test would be ideal. I only had an hour.
Do you have any 24 hour results ?
664880
