Coordinates from Google Maps
Submitted: Monday, Dec 21, 2009 at 11:37
ThreadID: 74549 Views:4212 Replies:5 FollowUps:8
Related Pages
A simple question with hopefully a simple answer. How do I extract coordinates (Latitude & Longitude) from Google maps?
WBS
Reply By: Member - Tony V (NSW) - Monday, Dec 21, 2009 at 12:07
Hi WBS,
Find the location you want, i.e. an address, put your cursor over the location and right click, a "pop up" box will appear and you need to drop down to "Whats Here"
This will give you the coordinates.
AnswerID: 395926
Reply By: Blaze (Berri) - Monday, Dec 21, 2009 at 12:46
Tony has answered it well for you. If you use Oziexplorer also you can export to it.
By the way that was asking a lot from EO... A simple answer LOL
AnswerID: 395932
Reply By: The Explorer - Monday, Dec 21, 2009 at 14:12
This website may have something of use to you
POI converter
You are not very specific about the format you require the data in and there is probably a number of ways to "extract" and save GE coords. The abovementioned site has variety programs that create formats suitable for a wide range of uses. Create placemarks at locations you desire in GE and then use "save as" kml or kmz, then convert as required. As suggested OziExplorer is also good at it but not sure if you need the registered ($) version or not.
AnswerID: 395941
Follow Up By: equinox - Tuesday, Dec 22, 2009 at 13:11
Hi Greg,
Slightly off-thread, but hope you don't mind.
Do you know where I can purchase the most accurate DEM data for the Gibson Desert area?
It's been years since I've used Ozi-3D but might blow the dust off if I can get a good dataset.
I have the old 9sec Natmaps data but am after something more accurate.
FollowupID: 664744
Follow Up By: The Explorer - Tuesday, Dec 22, 2009 at 13:33
Hello
There is new data based on 1 sec ~30m spaced spot heights ..though its not available in a format directly useable by Ozi3d but can be converted if you have suitabel program for the job (eg GlobalMapper). 1 sec data can be downloaded from here (needs registration)..
ASTER GDEM
You will end up with a geotiff file with embedded DEM data. This needs tobe convertedto soem sort of ascii format for Ozi to use.
Discussion about it here
GPS Australia DEM data thread
The 3 sec data (90m spot heights) which can be use in Ozi3D directly is available here
3 Sec DEM Data
Mayeb this suits you needs?
The new 1 sec data requires large files files relative to the 3 sec data but thats the price you pay for the extra detail.
If you get stuck with the 1 sec data send me rough idea of the area required - I will download tile and convert for you (and send disc) when I get time. Too big to email.
I have had plans of downloading the WA 1 sec data one day anyway - just havent got round to it.
FollowupID: 664747
Follow Up By: The Explorer - Tuesday, Dec 22, 2009 at 13:34
sorry about spelling errors ..in a hurry
FollowupID: 664749
Follow Up By: equinox - Tuesday, Dec 22, 2009 at 22:06
Thank you for the detailed reply Greg.
A lot of info there..I'll try and get my head around it :)
FollowupID: 664841
Reply By: Willem - Monday, Dec 21, 2009 at 14:44
Hmmm..even I have some info on this
Google Earth to Oziexplorer
To transfer waypoints:
Placemarks all saved in left hand corner of screen
Place all placemarks into a new folder and give it a name
Copy to Data in Oziexplorer in .kml format
To load into Oziexplorer:
Go to LOAD
Scroll to bottom of page and click on Import Google Earth (kml) file
Then….Go to:
My Computer
Local Disk C
Oziexplorer
Data
And then scroll through Data to find file
Highlight file and click Open
Waypoints will appear on map screen in a few seconds.
Hope this works and is what you wanted :-)
AnswerID: 395947
Follow Up By: Member - Mike DID - Tuesday, Dec 22, 2009 at 12:49
Google Earth is not Google Maps.
FollowupID: 664740
Follow Up By: Willem - Tuesday, Dec 22, 2009 at 12:56
Ah, yes, yer right.
Withdraw suggestion
FollowupID: 664741
Reply By: Member - Sigmund (VIC) - Tuesday, Dec 22, 2009 at 07:50
It's a while since I've done this so take with caution:
If you have a Garmin, there's an IE plugin on their website called Communicator; it allows you to export the coordinates of a point on a Google map to an attached GPS.
AnswerID: 396024
Follow Up By: Member - Sigmund (VIC) - Tuesday, Dec 22, 2009 at 07:53
Yeah, here you go: download
FollowupID: 664705
Follow Up By: The Explorer - Tuesday, Dec 22, 2009 at 08:41
While where on the subject here is the link to GMapToGPX. Good for creating short routes in Google Maps and then transferring it to GPS/other programs.
GMapToGPX
FollowupID: 664715
